Originally Posted by w8ngladee
I just had the same problem with my Escort. I changed the fuel filter and now the car starts and keeps running. I was advised by 3 different people, two were mechanics, to use Chevron Premium because it's better for your engine parts and you'll have less problems with starting. Good luck.
Thanks man. There aren't any chevron stations around where I live, but I try to stick to Sunoco, or at worst Hess. I don't have a functioning gas gauge, so I know my mileage real well, and use my trip odometer. I don't get nearly the mileage on gas like Sheetz, etc. Premium gas isn't necessarily good for an engine that doesn't require it. Owning an RX7 (Rotary engine), which is one of the pickiest engines on the planet, I have to watch out for dirty fuels to avoid carbon deposits, which can lock my hard seals eventually. It runs best on something like 80-84 octane (No, I can't buy that, but I pre-mix 2 stroke oil into my gasoline because rotarys inject oil into the combustion chamber to lube the seals, but I don't use that system. The pre mix lowers the octane). If I run higher octane fuels the car performs less well, because the fuel is burning slower, and so more of it burns out the exhaust. The interesting thing though, is that if I run good quality, but high octane gas, I get more deposits in my engine because of the additives to raise the octane (usually extra detergents and such). Just some fuel for thought. I'd keep buying chevron if I were you, but run what your owners manual recommends as far as octane.
