RPO Codes
RPO DECODER You can find your RPO Codes either in your glove box or the storage compartment in your trunk. AAA : 4-WAY MANUAL SEAT ADJUSTER AA3 : WINDOW, TINTED, DEEP TINT, ALL EXCEPT W/S, F.D., AA4 : WINDOW, SPECIAL GLAZING, DOMESTIC AA7 : WINDOW, POWER OPERATED, QUICK OPENING AA8 : WINDOW, R/CMPT LIFT AA9 : WINDOW, REAR, BLACKOUT BANDED EDGE AB1 : WINDOW, RR QUARTER, ORNAMENTAL AB2 : WINDOW SIDE BODY, STA LEFT SIDE AB3 : SEATING ARRANGEMENT, SIX PASS AB4 : SEATING ARRANGEMENT, FIVE PASS WITH BUCKET SEATS AB5 : LOCK CONTROL, SIDE DR, ELEC, KEY ACTIVATED AB6 : WINDOW, RR INSERT AB7 : WINDOW, T/GATE, HINGED AC1 : ADJUSTER, PASS ST, POWER, 6 WAY, BKT AC2 : WINDOW, SLIDING RIGHT FRT DR AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER AD2 : WINDOW, RR DR ------ DELETE AD3 : WINDOW, HINGED, ROOF AD5 : WINDOW, SIDE RR SLIDING AD8 : DOOR CHECK, RR AD9 : ADJUSTER, SEAT, POWER 2 WAY DRIVER AE1 : SEAT, FRT BKT, PASS, HIGH BACK, AIR SUSP AE2 : SEAT, DRIVER AE7 : SEAT, FRT SPLIT DRIVER PASS EASY ENTRY AF0 : ADJUSTER, SEAT EASY ENTRY, DRIVER AF1 : ADJUSTER, SEAT MANUAL----DELETE AF2 : WINDOW, STA SIDE, LH, UTILITY BODY AF3 : WINDOW, STA SIDE, RH UTILITY BODY AF4 : ADJUSTER, SEAT, MANUAL, 6 WAY DRIVER, PASS AF5 : ADJUSTER, SEAT, EASY ENTRY, PASS AF6 : SEAT, FRT BENCH, 2 PASS AF7 : SEAT, FRT BENCH SPLIT BACK, CTR ARM REST, 2 PASS AF9 : SEAT, FRT BKT, PASS DRIVER, RECL, OUTSIDE VENDOR AG1 : ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH AG2 : ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH AG3 : ADJUSTER, FRT ST, POWER, 6 WAY, 2 POSITION MEMORY AG4 : ADJUSTER, SEAT, MANUAL, 2 WAY, VERT, DRIVER AG7 : ADJUSTER, SEAT, POWER, 6 WAY, 2 POSITION MEMORY AG9 : ADJUSTER, SEAT, POWER, 6 WAY AH6 : WINDOW, BACK DR, UTILITY BODY AH8 : WINDOW, SIDE ACCESS DR, LH, UTILITY BODY AH9 : WINDOW, SIDE ACCESS DR, RH, UTILITY BODY AJ1 : WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS AJ2 : SEAT RR, FLDG, SIDEWAYS JUMPSEAT AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER AJ4 : RESTRAINT SYSTEM, HEAD MOUNTED GUIDE LOOP AJ6 : TRAVEL BED, RR SEAT AJ9 : TRAVEL BED, RR SEAT RR AK1 : DELUXE BELT AND SHOULDER HARNESS AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR, AK5 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER AK8 : RESTRAINT SYSTEM, FRT SEAT, SHLDR, 3 POINT AK9 : RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT AL4 : SEAT RR, BKT AL7 : SEAT, FRT SPLIT, PASS/DRIVER, 8 WAY ADJ, 2 WAY AM1 : POWER SEAT AM3 : SEAT, FRT BENCH, 2 PASS, CTR ARM REST AM4 : SEAT, FRT BENCH, N/BACK, 2 PASS AM5 : SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, 2 WAY LUMBAR AM6 : SEAT, FRT SPLIT, 3 PASS, CTR ARM REST AM7 : SEAT, RR, FLDG AMB : SEAT, FRT SPLIT, 2 PASS INTEGRAL CONSOLE AM9 : SEAT, RR, SPLIT, BACK, FLDG ANL : SALES PACKAGE, AIR DEFL . AND FOG LP AN1 : SEAT, RR, BENCH AN3 : SEAT, FRT BKT, DRIV, PASS, ELEC BODY SUPT CONT AN4 : RESTRAINT, PROVISION CHILD AN5 : SEAT RR, BUCKET, W/INTEGRAL CHILD SEAT AN6 : ADJUSTER SEAT BACK DRIVER AP1 : RESTRAINT, CARGO PROVISIONS AP7 : PARTITION SLIDING, PLYWOOD AP9 : NET, CONVENIENCE AQ3 : SEAT RR, CTR AQ7 : SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, RECL AQ9 : SEAT, FRT PASS A DRIV, RECL AQ9 : SEAT, FRT BKT PASS DRIVER RECL AR3 : RESTRAINT SYSTEM, HEAD, RR SEAT, CLOTH COVERED, AR4 : RESTRAINT SYSTEM, FRT SEAT, AUTO, PASSIVE AR5 : RESTRAINT SYSTEM, HEAD, RR SEAT, LEATHER COVERED, AR6 : RESTRAINT SYSTEM, SEAT BELT, SHLDR HARN, MAN AR7 : SEAT, FRT BKT, STANDARD AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL AS1 : SEAT, FRT BKT, HIGH BACK, DRIVER AS2 : SEAT, PASSENGER, FRT BKT, HIGH BACK AS3 : SEAT, RR, SUBURBAN AS5 : SEAT, FRT BKT, DELUXE AS7 : SEAT, FRT SPLIT AS8 : RESTRAINT SYSTEM, FRT SEAT, MANUAL, ACTIVE AT2 : SEAT RR, DELETE AT5 : SEAT RR, CTR, FLDG AT6 : ADJUSTER PASS ST BK, MANUAL, RECL AU0 : LOCK CONTROL, REM0TE ENTRY AU1 : LOCK CONTROL, SIDE DR, FUEL FILLER DR, ELEC AU2 : LOCK CONTROL, CARGO DR AU3 : LOCK CONTROL, SIDE DR, ELEC AU4 : LOCK CONTROL, SIDE DR, ELEC, AUT0MATIC AU6 : LOCK CONTROL, END GATE WINDOW, REM CONT ELEC AV3 : HOOK, CARGO TIE DOWN AV5 : SEAT, FRT BKT, HIGH BACK AV7 : SEAT FRT SPLIT, SD/SO AW2 : ADJUSTER, SEAT, MANUAL, 6 WAY, DRIVER AW3 : ADJUSTER SEAT MANUAL, 6 WAY, PASS AW4 : DOOR, SLIDING SIDE EXTENSION AW9 : LOCK CONTROL, QUARTER STOW L L/CPMT AX3 : LOCK CONTROL, KEYLESS ENTRY SYSTEM AX4 : RESTRAINT, CONVERSION SEAT, MAN, EUROPEAN AX5 : PARTITION, EXPANDED METAL, LEFT SIDE AX6 : PARTITION, EXPANDED METAL, WITH RH SLIDING DR AX7 : PARTITION, EXPANDED METAL, WITH CTR SLIDING DR AX8 : SEAT, FRT BKT, PEDESTAL, DRIVER, BELTS AX9 : LATCH RR CARGO DR AY4 : RESTRAINT CONVERSION, HEAD FRT SEAT, LEATHER AY9 : ADJUSTER,SEAT, POWER 6 WAY SPLIT SEAT A01 : WINDOW, TINTED, ALL SHADED, W/S A02 : WINDOW, TINTED, SHADED UPPER A04 : WINDOW, TINTED, RR SIDE, RR A07 : WINDOW, BODY A08 : WINDOW, BODY, RIGHT SIDE A11 : WINDOW, TINTED, ALL A12 : WINDOW, RR, STA BACK DR A13 : WINDOW, SIDE DR, STA, RR A17 : WINDOW, SIDE BODY, LEFT SIDE, SWING OUT A18 : WINDOW, RR, DR, SWING OUT A19 : WINDOW, SIDE DR, RR, SWING OUT A2Q : PACKAGE,'GSI' A20 : WINDOW, RR QUARTER VENT SWING OUT A21 : WINDSHIELD, ADDITIONAL LAMINATE A23 : WINDSHIELD, HEAT REFLECTIVE A26 : WINDOW, EUROPEAN GLAZING, ALL A28 : WINDOW, RR, FULL WIDTH, SLIDING A31 : WINDOW, POWER OPERATED, SIDE A32 : WINDOW, POWER OPERATED, FRT DR A33 : WINDOW, POWER OPERATED, T/GATE OR BACK DR A37 : RESTRAINT SYSTEM, FRT SEAT, DELUXE TYPE A40 : WINDOW POWER OPERATED, RR VENT A42 : ADJUSTER SEAT, POWER, 6 WAY, BENCH A43 : MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER A44 : ADJUSTER PASS ST, MANUAL, 4 WAY A50 : SEAT, FRT BKT A51 : SEAT, FRT BKT PASS, DRIVER A52 : SEAT, FRT BENCH A57 : SEAT PASSENGER AUXILIARY, ONE, FLDG A59 : LOCK CONTROL, RR COMPT LID, REM CONT, MANUAL A65 : SEAT, FRT BENCH, SPLIT BACK, CTR ARM REST A70 : WINDOW, RR QUARTER, REM0TE CONTROLLED A75 : SEAT CUSHION, BACK FRT, HD A78 : ADJUSTER FRT, ST BK, MANUAL, PASS & DRIVER, RECLINING A79 : ADJUSTER FRT, ST BK, MANUAL, DRIVER, RECLINING A80 : ADJUSTER FRT, ST BK, POWER DRIVER, RECLINING A81 : ADJUSTER PASS, ST BK, POWER, RECLINING A82 : RESTRAINT, HEAD A83 : ADJUSTER, SEAT BACK, RECLINING A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE A91 : PULL DOWN, RR COMPT LID A93 : LOCK CONTPOL, QUARTER STOWAGE COMPT A94 : LOCK CONTROL, DR A95 : SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL A96 : LOCK CONTROL, LUGG COMPT A99 : LOCK CONTROL, I/P COMPT BA0 : ORNAMENTATION, EXTR, DOOR, NAMEPLATE BA1 : ORNAMENTATION, EXTR HOOD BA5 : ORNAMENTATION, EXTR CUSTOM BA6 : COMPARTMENT, RR, PACKAGE SHELF, STOWAGE BA8 : COMPARTMENT, FRT SEAT STOWAGE, PASS BA9 : COMPARTMENT, FRT SEAT STOWAGE, DRIVER BB2 : TRIM, LUGG COMPT LINING ---- DELETE BB3 : ORNAMENTATION, INTR, DR POCKET, INNER LINING, BB4 : ORNAMENTATION, INTR, DR POCKET, INNER LINING, LEFT BB5 : ORNAMENTATION, INTR, HEADLINER BC1 : ORNAMENTATION, INTR, I/P BC2 : ORNAMENTATION, INTR, I/P, WOOD GRAIN BC3 : ORNAMENTATION, INTR, I/P, DELUXE BC4 : ORNAMENTATION, INTR, COAT HOOK RETRACTABLE BC5 : ORNAMENTATION, INTR, LOAD COMPT CARPET PANELS BC8 : ORNAMENTATION, INTR, DR MAP POCKETS BC9 : ORNAMENTATION, EXTR HOOD ---- DELETE BD1 : ORNAMENTATION, EXTR MLDG, ROCKER PNL ---- DELETE BD2 : ORNAMENTATION, EXTR ---- DELETE BD3 : ORNAMENTATION, INTR ACCEL/BRAKE PEDAL BF1 : COVERING REAR FLOOR MATS----DELETE BF2 : COVERING, FLOOR CARPET, DELUXE BF3 : COVERING, STEP WELL MAT BF4 : COVERING, FLOOR CARPET, CUSTOM BF9 : COVERING FRT, FLOOR MAT----DELETE BG4 : TRIM OVERRIDE ,INTERIOR, BIG FOUR BG9 : COVERING FLOOR, RUBBER BS1 : INSULATION, ACOUSTICAL PKG BS2 : INSULATION, ACOUSTICAL PKG, ADDED MATERIAL BS4 : INSULATION, BACK PNL BS6 : SEAL, DR BV1 : FLEET INCENTIVE, LAND O'LAKES (J/L/W-TRK CKMST) BV2 : ORNAMENTATION, EXTR RR C0MPT LID BV3 : ORNAMENTATION, INTR, I/P, BLACK BV6 : ORNAMENTATION, EXTR LOCK CYLINDER, PAINTED BV7 : ORNAMENTATION, EXTR PLR APLQ ---- DELETE BV8 : ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER, BV9 : ORNAMENTATION, EXTR MLDG, BODY SIDE, WOOD GRAIN BW1 : ORNAMENTATION, EXTR RR END BW2 : MOLDING B/S, DELUXE BW3 : ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED BW6 : ORNAMENTATION, EXTR PLR APLQ, COLORED BW7 : ORNAMENTATION, EXTR PLR APLQ BW8 : ORNAMENTATION, EXTR, EMBLEM, BODY, RR BX1 : ORNAMENTATION, EXTR FRT END, SPECIAL BX2 : MOLDING B/S, L0WER, EXTRA WIDE BX3 : ORNAMENTATION, EXTR WOOD GRAIN SIDE PNL BX4 : ORNAMENTATION, EXTR MLDG, BODY SIDE, BRIGHT BX5 : ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED BX6 : ORNAMENTATION, EXTR MLDG, APLQ, CAB BACK PNL BX8 : ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL ---- BX9 : ORNAMENTATION, EXTR FRT END PNL BYP : SALES, SPORT EQUIPMENT PKG BY1 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3 BY4 : ORNAMENTATION, INTR, INST PANEL, NAME PLATE BY8 : ORNAMENTATION, EXTR FRT DECOR PLATE B05 : BODY EQUIPMENT ARMORED B1A : PORT OF ENTRY CAMI B1B : MODIFICATION FOUR SEATER B1J : LINER FENDER B1N : TIRE ALL, P165/65R13 BL R/PE ST TL AL3 B1R : TIRE ALL, P185/60VR14/N BL R/PE ST TL AL3 B1Y : MERCHANDISED PKG, SPECIAL COMPONENTS B18 : ORNAMENTATION, INTR, DELUX B19 : ORNAMENTATION, INTR, CUSTOM B2E : SALES, SPRING SPECIAL PACKAGE B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI B2Q : PANEL, RR ROOF, BLACK ---DELETE B2S : SPRING , REAR LEAF TRANSVERSE (LH) B2U : SPRING, REAR LEAF TRANSVERSE (RH) B2W : TIRE ALL, P205/75R15/N R/PE 0WL TL 00R (TRACKER) B2Z : MERCHANDISED PKG, DELUXE VAN B20 : ORNAMENTATION, INTR, LUXURY B22 : ORNAMENTATION, INTR, EMBLEM, DR INNER PANEL B23 : ORNAMENTATION, EXTR WHEEL OPG SPOILER B24 : ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEALs B25 : TRIM EQUIPMENT LUGG COMPT, DELUXE B26 : ORNAMENTATION, INTR, DR PULL HANDLES, FRT B29 : ORNAMENTATION, INTR, DR PULL HANDLES, RR B3D : EQUIPMENT, SCHOOL BUS B3H : COVERING, FLOOR CARPET LOAD FLOOR ---DELETE B3J : EQUIPMENT DIESEL B3K : TIRE ALL, P145/BOR12/N BL R/PE ST TL ALS B3M : EQUIPMENT, SCHOOL BUS, DELUXE B3S : TIRE ALL, P205/50R15/N BL R/PE ST TL HW4 B3W : Advanced Price Sheet Processing Option B30 : COVERING, FLOOR CARPET B32 : COVERING, FRT FLOOR MATS AUX B33 : COVERING, REAR FLOOR MATS AUX B34 : COVERING, FRT FLOOR MATS CARPETED INSERT B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT B36 : COVERING, FLOOR MAT, LUGG COMPT B37 : COVERING, FLOOR MATS, FRT & RR AUX B39 : COVERING, FLOOR CARPET, LOAD FLOOR B4A : PANEL ROOF, BLACK --- DELETE B4C : SALES, SPECIAL SERVICE PKG B4F : PACKAGE, SECURITY LIGHTING B4H : MODIFICATION, NOISE CONTROL , EXPORT B4K : HANDLING CHARGE, TARRYTOWN T0 MIDWAY COACH B4M : VEHICLE, CUSTOM FEATURE PACKAGE B4N : HANDLING CHARGE, TARRYTOWN T0 ESSEX MD T0 T & B IN B4U : PERFORMANCE PACKAGE, SPORT B4Z : IROC PACKAGE B42 : COVERING, FLOOR MAT, LUGGAGE COMPARTMENT FITTED B43 : COVERING, LOAD FLOOR, TEXTURED SURFACE B44 : COVERING, LOAD FLOOR, LOOSE B46 : TRIM EQUIPMENT, SPECIAL ORDER B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT B5A : PACKAGE, INDY CONVERTIBLE B5I : PACKAGE, INDY GT B5S : FLEET INCENTIVE, D & K FINANCIAL B5Z : SALES, EXTR APPEARANCE B51 : MOLDING, ROCKER, EXTRA WIDE B53 : COVERING FRT, FLOOR MATS, CARPETED INSERT DELUXE B54 : COVERING REAR, FLOOR MATS, CARPETED INSERT DELUXE B56 : MOLDING ROCKER,COLORED B57 : ORNAMENTATION P EXTR DELUXE B58 : COVERING, FLOOR MATS FRT & RR, CARPETED INSERT B60 : DECAL PACKAGE, 01 B6Q : DECAL PACKAGE, 02 B6R : DECAL PACKAGE, 03 B6S : TRAVEL BED PACKAGE B65 : COVERING, FLOOR SIDEWALL TRUNK B67 : CONTAINER, RADI0 CASSETTE TAPES B69 : CONTAINER, COMPACT DISCS B7N : BODY EQUIPMENT, PICKUP BOX PANELS (NON-PRIME) B7P : BODY EQUIPMENT, PICKUP BOX PANELS (PRIME) B71 : MOLDING WHL OPENING, COLORED B72 : ORNAMENTATION, EXTR MLDG BELT REVEAL' COLORED B74 : MOLDING WHL OPENING, EXTRA WIDE B75 : TRIM EQUIPMENT, LUGG COMPT LINING B77 : ORNAMENTATION, EXTR MLDG W/S REVEAL, COLORED B79 : ORNAMENTATION, EXTR RR END B80 : ORNAMENTATION, EXTR MLDG ROOF DRIP B81 : MOLDING B/S ---- DELETE B82 : ORNAMENTATION, EXTR EMBLEM ---- DELETE B83 : MOLDING ROCKER, NARROW B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE B85 : ORNAMENTATION, EXTR MLDG BELT REVEAL B87 : ORNAMENTATION, EXTR EMBLEM FENDER---DELETE B88 : MOLDING B/S CUSTOM B89 : ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL, B9K : ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY B9Q : MODEL CONVERSION, HEARSE B90 : ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED B92 : ORNAMENTATION, EXTR FRT FENDER NAME B93 : ORNAMENTATION, EXTR MLDG, DR EDGE GUARD B94 : FENDER EMBLEM, Z28 B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I B96 : MOLDING WHL OPENING B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT B98 : STRIP B0DY SIDE, DELETE B99 : MOLDING WHL OPENING,---- DELETE CA1 : ROOF, SUN, STEEL SLIDING, ELEC CA2 : ROOF COVERING, VINYL ---- DELETE CA3 : ROOF COVERING, STAINLESS STEEL CA5 : ROOF COVERING, VINYL, HEAVY PAD, HALO TYPE CA9 : ROOF COVERING, VINYL, PADDED, HALO TYPE CB4 : ROOF COVERING, VINYL, PADDED, RR INTEGRAL PAD CB5 : ROOF COVERING, VINYL, PADDED, FULL CB7 : ROOF COVERING, VINYL, PADDED, FRT INTEGRAL PAD CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS CC2 : ROOF AUXILIARY CC3 : ROOF, HATCH, REMOVABLE PANELS. PLASTIC CD2 : INDICATOR, WSWA JAR FLUID CD4 : WIPER SYSTEM WINDSHIELD, PULSE CD7 : WIPER SYSTEM WINDSHIELD, PULSE, WET ARM CE4 : WASHER, HEADLAMP, HIGH PRESSURE CF3 : ROOF, SUN, REMOVABLE, TRANSPARENT CF4 : ROOF, SUN, GLASS SLIDING, MANUAL CF5 : ROOF, SUN, GLASS SLIDING, ELEC CF7 : ROOF, SUN REMOVABLE NON-TRANSPARENT CF8 : ROOF, COVERING, SIMULATED CONVERTIBLE CG1 : FLEET INCENTIVE, AMERICAN INTERNATIONAL REALTY CH1 : FLEET INCENTIVE, HALLMARK CARD CH2 : FLEET INCENTIVE, AMSCO CJ2 : HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT CJ3 : HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT, CR0 : LAMP, INTR ENG COMPT COURTESY ---DELETE CR1 : LAMP, INTR FRT DR WARNING CR3 : LAMP, INTR I/P READING CR5 : COUNTRY, YUGOSLAVIA CR6 : COUNTRY, POLAND CR7 : COUNTRY, HUNGARY CTF : SALES PACKAGE, INTERIM CONTROL CT1 : COUNTRY, BELGIUM CT2 : COUNTRY, AUSTRIA CT3 : COUNTRY, GERMANY CT4 : COUNTRY, LUXEMBOURG CT5 : COUNTRY, NETHERLANDS CT6 : COUNTRY, ITALY CT7 : COUNTRY, DENMARK CT8 : COUNTRY, PORTUGAL CT9 : COUNTRY, SPAIN CU1 : COUNTRY, NORWAY CU2 : COUNTRY, FINLAND CU3 : COUNTRY, FRANCE CU4 : COUNTRY, SWEDEN CU5 : COUNTRY, SWITZERLAND CU6 : COUNTRY, TAIWAN CU7 : COUNTRY, KUWAIT CU8 : COUNTRY, SAUDI ARABIA CU9 : COUNTRY, UNITED KINGDOM CV1 : COUNTRY, ICELAND CV3 : COUNTRY, MEXICO CV4 : COUNTRY, ISRAEL CV7 : COUNTRY, ENGLAND CV8 : COUNTRY, IRAQ CV9 : COUNTRV, TURKEY CW1 : COUNTRY, KOREA C01 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2 C04 : ROOF COVERING VINYL PADDED, RR C05 : ROOF, CONVERTIBLE FOLDING C09 : ROOF COVERING, VINYL PADDED, FULL,INTEGRAL PAD C1B : LAMP GROUP, COMPONENTS 2 C1F : PACKAGE, ACCENT C18 : ARM & BLADE, WSW C2L : ROOF, PACKAGE DUAL REMOVABLE C2X : MODEL CONVERSION, VALUE LEADER C25 : WIPER SYSTEM, RR WINDOW C27 : ROOF COVERING, SOFT TRIM C3A : PAYLOAD, 1500 LBS C3B : PAYLOAD, 1000 LBS C3C : PAYLOAD, 1625 LBS C34 : HVAC SYSTEM, AIR CONDITIONER HEATER COMBINATION C35 : HEATER, RR COUPT, PROVISIONS FOR C36 : HEATER, AUXILIARY C4B : ??? C4G : GVW RATING, 4935 LBS C4H : GVW RATING, 5050 LBS C40 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN, ELECTRONIC C41 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN C42 : HVAC SYSTEM, HEATER DELUXE OUTSIDE AIR C44 : TAILGATE, PLASTIC C46 : HEATER, HIGH CAPACITY C47 : DEFOGGER, RR WINDOW ---- DELETE C49 : DEFOGGER, RR WINDOW, ELECTRIC C5A : GVW RATING, 4900 LBS C5B : GVW RATING, 15,000 LBS C5C : GVW RATING, 5000 LBS C5D : GVW RATING, 4600 LBS C5E : GVW RATING, 5400 LBS C5F : GVW RATING, 4100 LBS C5G : GVW RATING, 5600 LBS C5H : GVW RATING, 5350 LBS C5J : GVW RATING, 6000 LBS C5K : GVW RATING, 5175 LBS C5L : GVW RATING, 5370 LBS C5U : GVW RATING, 6100 LBS C5P : GVW RATING, 6250 LBS C5Q : GVW RATING, 6400 LBS C5R : GVW RATING, 5800 LBS C5S : GVW RATING, 6600 LBS C5T : GVW RATING, 4200 LBS C5U : GVW RATING, 6800 LBS C5V : GVW RATING, 6850 LBS C5W : GVW RATING, 7000 LBS C5X : GVW RATING, 4650 LBS C5Y : GVW RATING, 7100 LBS C5Z : GVW RATING, 7200 LBS C50 : DEFROSTER, HEATED WINDSHIELD C51 : DEFLECTOR, RR WINDOW, AIR C55 : VENT, ROOF C56 : VENT, FORCED AIR, RIGHT SIDE C57 : VENT, FORCED AIR C6A : GVW RATING, 7300 LBS C6B : GVW RATING, 4785 LBS C6C : GVW RATING, 7400 LBS C6D : GVW RATING, 10100 LBS C6E : GVW RATING, 7500 LBS C6F : GVW RATING, 5150 LBS C6G : GVW RATING, 7600 LBS C6H : GVW RATING, 4350 LBS C6I : GVW RATING, 4850 LBS C6J : GVW RATING, 5100 LBS C6K : GVW RATING, 20000 LBS C6L : GVW RATING, 8000 LBS C6U : GVW RATING, 5950 LBS C6N : GVW RATING, 8200 L85 C6P : GVW RATING, B600 LBS C6Q : GVW RATING, 6875 LBS C6S : GVW RATING, 8900 LBS C6U : GVW RATING, 9000 LBS C6W : GVW RATING, 9200 LBS C6X : GVW RATING, 4810 LBS C6Y : GVW RATING, 9600 LBS C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS C61 : HVAC SYSTEM, AIR CONDITIONER FRT AUTO CONTROLS C65 : HVAC SYSTEM, AIR CONDITIONER FRT SEMI-AUTO CONTROLS C66 : HVAC SYSTEM, AIR CONDITIONER PROVISIONS FOR DEALER C67 : HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS C68 : HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC C69 : HVAC SYSTEM, RR, AIR CONDITIONER C7A : GVW RATING, 10000 LBS C7C : GVW RATING, 10500 LBS C7E : GVW RATING, 11000 LBS C7G : GVW RATING, 11500 LBS C7J : GVW RATING, ll800 LBS C7L : GVW RATING, 12000 LBS C7M : GVW RATING, 14100 LBS C7N : GVW RATING, 12300 LBS C7P : GVW RATING, 16000 LBS C7Q : GVW RATING, 10200 LBS C7S : GVW RATING, 14600 LBS C7U : GVW RATING, 5200 LBS C7V : GVW RATING, 26500 LBS C7X : GVW RATING, 5850 LBS C7Y : GVW RATING, 4700 LBS C7Z : GVW RATING, 4537 LBS C71 : LAMP, INTR, FRT DR, COURTESY C72 : LAMP, INTR, RR DR COURTESY C75 : LAMP, INTR, FRT HEADER, COURTESY AND DUAL READING C77 : LAMP, INTR, FRT HEADER COURTESY C78 : LAMP, INTR, ROOF, COURTESY AND SINGLE READING C8B : PAINT SPECIAL, (SILVER MET) C8K : PAINT SPECIAL, (MED GRAY MET ) C8T : PAINT SPECIAL, (DK MAPLE RED MET) C80 : SWITCH, JAMB, FPT DR C81 : SWITCH, JAMB, RR DR C87 : LAMP, INTR, QTR COURTESY C88 : LAMP, INTR, RR HEADER, COURTESY C89 : LAMP, INTR, QTR, SINGLE READING C9A : PAINT SPECIAL, (WHITE) C9C : PAINT SPECIAL, (BLACK) C9D : PAINT SPECIAL, (DK BLUE MET. ) C9E : PAINT SPECIAL, (LT BLUE MET. ) C9F : PAINT SPECIAL, (DK RED MET) C9Q : PAINT SPECIAL, (DK CHESTNUT MET. ) C9R : PAINT SPECIAL, (CARMINE) C9X : PAINT SPECIAL, (LT CAMEL MET) C90 : LAMP, INTR, FRT AND RR DRS, COURTESY C91 : LAMP, INTR, ROOF, COURTESY C93 : LAMP, OPERA C94 : LAMP, D0ME, DELAYED C95 : LAMP, INTR, ROOF, COURTESY AND DUAL READING C96 : LAMP, INTR, QTR, COURTESY AND SINGLE READING C97 : ILLUMINATED ENTRY, DA0 : ARM REST, FRT SEAT, STORAGE DA1 : ARM REST, RR SEAT, STORAGE DA2 : GVW RATING, 5070 LBS DA3 : GVW RATING, 5700 LBS DA4 : GVW RATING,12 500 LBS DB3 : SUNSHADE, WINDSHIELD, WITH EXTENSION DB4 : SUNSHADE, WINDSHIELD, WITH POCKETS DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS DC5 : MIRROR I/S, RR HEADLINING, ILLUM DC6 : MIRROR O/S, LH & RH, REM CONT, ELEC, LH & RH DEFOG, DC7 : MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY, DC8 : MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY, DD0 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, LT DD1 : MIRROR I/S, R/V TILT, DUAL READING LAMPS, COMPASS DD2 : MIRROR I/S, SUNSHADE, COVERED DD3 : MIRROR O/S, LH & RH, REM CONT 8REAKAWAY, PAINTED DD4 : MIRROR O/S, RH, REM CONT, ELEC, CHROME DD5 : MIRROR 0/S, LH, REM CONT, ELEC, CHROME DD7 : MIRROR I/S, R/V, LT SENSITIVE, C0MPASS DD8 : MIRROR I/S, R/V, LT SENSITIVE DD9 : MIRROR O/S, LH & RH, RE4 CONT, ELEC, 8REAKAWAY, DE1 : SUNSHADE, BACK WINDOW DE4 : SUNSHADE, REMOVEABLE HATCH ROOF DE7 : MIRROR O/S, LH & RH, REM CONT, BREAKAWAY, CHROME DE9 : CONSOLE, FRT COMPT, NONSHIFTING DF1 : MIRROR O/S, CAMPER TYPE, PAINTED DF2 : MIRROR O/S, CAMPER TYPE, SST DF3 : MIRROR O/S, RH, REM CONT, CHROYE DF4 : MIRROR O/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY, DF7 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, CHROME DF8 : MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY, DG0 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED DG1 : MIRROR O/S, LH, DR MTD DG2 : MIRROR O/S, LH & RH, REM CONT, ELEC, CHROYE DG5 : MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE DG6 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED DG8 : MIRROR 0/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY, DG9 : MIRROR O/S, LH & RH, REM CONT, ELEC, SST DH6 : MIRROR I/S, SUNSHADE, ILLUM, LH & RH DK1 : CONSOLE, RR COMPT FLOOR DK2 : MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, PAINTED DK4 : CONSOLE, FRT COMPT FLOOR, MINI OPERATING DK6 : CONSOLE ROOF, INTERIOR DL2 : DECAL, WINDOW DL4 : DECAL, PAINT SCHEME TRITONE, MEDIUM LINE STRIPE DL5 : DECAL, ROADSIDE SERVICE INFORMATION DL8 : MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG DL9 : DECAL, FRT FENDER, RR QUARTER, BLACKOUT DM1 : DECAL, DR DR1 : MIRROR O/S, LH & RH, MAN CONT PAINTED DR2 : MIRROR O/S, LH, MAN CONT, CHROME DR3 : MIRROR O/S, LH & RH, MAN CONT, CHROME DR4 : MIRROR O/S, LH & RH, REM CONT, CHROME DR5 : MIRROR O/S, LH REM CONT, RH MAN CONT, CHROME DT4 : TRAY, ASH, CIGARETTE LIGHTER DV1 : SUNSHADE, WINDOW, ROOF DW1 : STRIPE, BODY SIDE, MIDDLE DX1 : STRIPE, FRT END, HWD DX3 : STRIPE, DELETE DX4 : STRIPE, 2 SIDE DX5 : STRIPE, 3 SIDE DY1 : STRIPE, 3 SIDE, VAR. 2 DY2 : STRIPE, 3 SIDE, VAR. 3 DY5 : STRIPE, DECK LID D02 : PAINT, ENAMEL MASTER D03 : PAINT, PROCESS, WATER BASE D04 : PAINT, LOW GLOSS FINISH D06 : CONSOLE, FRT COMPT FLOOR, ARM REST D07 : CONSOLE, FRT COMPARTMENT FLOOR, CUSTOM D08 : PAINT, HIGH GLOSS FINISH D09 : ARM REST, FRT SEAT D1B : GEAR, SPEEDO DRIVEN D1C : ??? D1D : GEAR, SPEEDO DRIVEN D1E : GEAR, SPEEDO DRIVEN D1F : GEAR, SPEEDO DRIVEN D1G : GEAR, SPEEDO DRIVEN D1H : GEAR, SPEEDO DRIVEN D1R : GEAR, SPEEDO DRIVEN D1S : GEAR, SPEEDO DRIVEN D1T : GEAR, SPEEDO DRIVEN D1U : GEAR, SPEEDO DRIVEN D1V : GEAR, SPEEDO DRIVEN D1W : GEAR, SPEEDO DRIVEN D1X : GEAR, SPEEDO DRIVEN D1Y : GEAR, SPEEDO DRIVEN D1Z : GEAR, SPEEDO DRIVEN (D1Z) D12 : PANEL, REAR SEAT, BACK PKG SHELF D14 : ARM REST, FRT DR, RH & LH D2A : GEAR, SPEEDO DRIVEN D2B : GEAR, SPEEDO DRIVEN D2C : GEAR, SPEEDO DRIVEN D2D : GEAR, SPEEDO DRIVEN D2E : GEAR, SPEEDO DRIVEN D2F : GEAR, SPEEDO DRIVEN D2L : GEAR, SPEEDO DRIVEN D2M : GEAR, SPEEDO DRIVEN D2N : GEAR, SPEEDO DRIVEN D2Q : GEAR, SPEEDO DRIVEN D20 : SUNSHADE, WINDSHIELD, PASS SIDE D21 : SUNSHADE, WINDSHIELD D22 : MIRROR O/S, RH BELOW EYELINE, 6 S X 9, AERODYN D24 : CONTAINER, LITTER D25 : MIRROR O/S, RH BELOW EYELINE, 6.5 X 9, AERODYN, D27 : COVER, RR COMPT, TRUNK STOW D28 : MIRROR O/S ---- DELETE D3A : GEAR, SPEEDO DRIVEN D3B : GEAR, SPEEDO DRIVEN D3E : GEAR, SPEEDO DRIVEN D3H : GEAR, SPEEDO DRIVEN D3P : GEAR, SPEEDO DRIVEN D3Q : GEAR, SPEEDO DRIVEN D3R : GEAR, SPEEDO DRIVEN D3S : GEAR, SPEEDO DRIVEN D3T : GEAR, SPEEDO DRIVEN D3U : GEAR, SPEEDO DRIVEN D3V : GEAR, SPEEDO DRIVEN D3W : GEAR, SPEEDO DRIVEN D3X : GEAR, SPEEDO DRIVEN D3Y : GEAR, SPEEDO DRIVEN D31 : MIRROR I/S, R/V,TILT D33 : MIRROR O/S, LH, REM CONT, PAINTED D34 : MIRROR, VISOR VANITY D35 : MIRROR, OUTSIDE REAR VIEW D36 : MIRROR I/S, R/V, TILT D4A : GEAR, SPEEDO DRIVEN D4D : GEAR, SPEEDO DRIVEN D4H : GEAR, SPEEDO DRIVEN D4K : GEAR, SPEEDO DRIVEN D4L : GEAR, SPEEDO DRIVEN D4P : GEAR, SPEEDO DRIVEN D4Q : GEAR, SPEEDO DRIVEN D4R : GEAR, SPEEDO DRIVEN D4S : GEAR, SPEEDO DRIVE D4U : GEAR, SPEED0 DRIVEN D41 : TRAY ASH, RR QUARTER D42 : SHADE, RR COMPT SECURITY D43 : MIRROR I/S, R/V, TILT, AUTOMATIC, INCREASED VISIBILITY D44 : MIRROR O/S, PAINTED D45 : MIRROR O/S, SST D46 : MIRROR O/S, WEST COAST TYPE, CLEARANCE LIGHTS D47 : CONSOLE FRT COMPT FLOOR D48 : MIRROR O/S, REM CONT, ELEC PAINTED D49 : MIRROR O/S, LH & RH, CHROME D5S : GEAR, SPEEDO DRIVEN D5T : GEAR, SPEEDO DRIVEN D5V : GEAR, SPEEDO DRIVEN D5W : GEAR, SPEEDO DRIVEN D5X : GEAR, SPEEDO DRIVEN D51 : MIRROR O/S, LH, DIRECT CONT, PAINTED D52 : SPOILER, RR END, SPORT D53 : ORNAMENTATION, EXTR HWD APPLIOUE D55 : CONSOLE, FRT COMPT, FLOOR D58 : SPOILER, REAR---DELETE D6D : COLOR OVERRIDE, TRIM AND PAINT COMPATABILITY D6D : GEAR, SPEEDO DRIVEN D6E : GEAR, SPEEDO DRIVEN D6G : GEAR, SPEEDO DRIVEN D6H : GEAR, SPEEDO DRIVEN D6L : GEAR, SPEEDO DRIVEN D6M : GEAR, SPEEDO DRIVEN D64 : MIRROR I/S, RH, SUNSHADE, ILLUM D68 : MIRROR O/S, LH & RH, REM CONT, PAINTED D69 : MIRROR O/S, LH, REM CONT, CHROME D7A : GEAR, SPEEDO DRIVEN D7B : GEAR, SPEEDO DRIVEN D7C : GEAR, SPEEDO DRIVEN D7H : GEAR, SPEEDO DRIVEN D7J : GEAR, SPEEDO DRIVEN D7L : GEAR, SPEEDO DRIVEN D7S : GEAR, SPEEDO DRIVEN D7T : GEAR, SPEEDO DRIVEN D7U : GEAR, SPEEDO DRIVEN D7V : GEAR, SPEEDO DRIVEN D7W : GEAR, SPEEDO DRIVEN D7Z : GEAR, SPEEDO DRIVEN D73 : RAIL, HAND, PICK-UP BOX D74 : MIRROR, I/S, LH SUNSHADE, ILLUM D75 : HANDLE, O/S, DR D77 : MIRROR, O/S, WIDE ANGLE, DUAL SYS, SST D8A : SENSOR, VEH SPD D8B : SENSOR, VEH SPD D8C : SENSOR, VEH SPD D8D : SENSOR, VEH SPD D8E : SENSOR, VEH SPD D8F : SENSOR, VEH SPD D8G : SENSOR, VEH SPD D8H : SENSOR, VEH SPD D8I : SENSOR, VEH SPD D8K : SENSOR, VEH SPD D8L : SENSOR, VEH SPD D8M : SENSOR, VEH SPD D8N : SENSOR, VEH SPD D80 : SPOILER, RR END PNL D81 : SPOILER, RR, AERO WING D83 : PAINT, MONOTONE D84 : PAINT, CUSTOM TWO-TONE D85 : STRIPE, B0DY SIDE LOWER ACCENT D86 : PAINT, TWO-TONE, DELUXE D88 : DECAL, STRIPE, SPORT D89 : PAINT, SPECIAL DECOR D9A : SENSOR, VEH SPD D9B : SENSOR, VEH SPD D9C : SENSOR, VEH SPD D9D : SENSOR, VEH SPD D9E : SENSOR, VEH SPD D9Z : GEAR, SPEEDO DRIVEN, SELECTION NOT REQUIRED D90 : STRIPE, FRT END, B0DY SIDE D91 : PAINT, TWO-TONE WITH RR QUARTER, UPPER PAINT BREAK D92 : STRIPE, EXTR DR HANDLE D96 : STRIPE, B0DY SIDE UPPER D98 : STRIPE, ACCENT D99 : PAINT, SPECIAL TWO-TONE, BODY PROVISIONS FOR EJ8 : EQUIPMENT, FLEETWOOD BODY CO. ENV : HVAC PROVISIONS, ENGINE DRESS, COMPRESSOR & CONDENSER EN2 : HVAC PROVISIONS, DELETE E1G : ADAPTER, SPEEDO (EIG) E20 : HANDLE, CONVERTIBLE RELEASE E24 : WWR SIDE, CARGO, HINGED E26 : PUMP, TILT CAB ASSIST E28 : HANDLE ASSIST E30 : B0DY EQUIPMENT, ALUMINUM 14 FT X 96 IN E31 : BDDY EQUIPMENT, STEEL 10 FT INCR WIDTH E32 : BODY EQUIPMENT, FORWARD CONTROL VAR 3 E33 : BODY EQUIPMENT, FORWARD CONTROL VAR 4 E34 : BODY EQUIPMENT, STEEL 10 FT STD WIDTH E35 : BODY EQUIPMENT, FLEETSIDE LESS TAILGATE, PUBX E36 : BODY EQUIPMENT, ALUUINUM io FT E37 : BODY EQUIPMENT, UTILITY E38 : BODY EQUIPMENT, STEEL 12 FT X 96 INCH E39 : BODY EQUIPMENT, ALUMINUM 12 FT X 96 INCH E46 : DOOR, RR, 66 INCH, OVERHEAD SLIDING WITH WINDOW E48 : COVER BODY SIDE, PROTECTIVE E50 : ROLL BAR E52 : DOOR RR, 83 INCH, WRAP AROUND E53 : DOOR RR, 87 INCH, WRAP AROUND E54 : BODY EQUIPMENT, RR DOOR, W/END GATE WINDOW E55 : BODY EQUIPMENT, END GATE E56 : BODY EQUIPMENT, PLATFORM E5Z : SPEEDOMETER ADAPTER (DELETE) E9Z : SPEEDOMETER KEY (DELETE) E62 : BODY EQUIPMENT, STEPSIDE, PUBX E63 : BODY EQUIPMENT, FLEETSIDE, PUBX E65 : BODY HEIGHT, INCR INTR TO 80 INCH E67 : BODY LENGTH, INCR 12 INCH E6E : SLEEVE, SPEEDOMETER GEAR E70 : WHEEL HOUSINGS, RR DUAL WHEELS E71 : FLOOR, CARGO, STEEL E72 : BODY LENGTH, INCR I8 INCH E73 : BODY WIDTH, INCR INTR TO 86.4 INCH E74 : BODY WIDTH, INCR INTR TO 90.5 INCH E75 : BODY EQUIPMENT, FORWARD CONTROL VAR 5 E76 : DOOR, RR, 60 INCH E79 : DOOR, RR, 74 INCH STRAP HINGES E80 : LID, RR C0MPT DELETE E81 : FLOOR, CARGO, WWD E88 : POCKET, STOWAGE E89 : PANEL, CAB, DRIVER DR OPENING FILLER WITH WINDOW E94 : CONVENIENCE PKG, BEAUVILLE FE0 : SUSPENSION SYSTEM, FRT & RR, ACTIVE FE1 : SUSPENSION SYSTEM, S0FT RIDE FE2 : SUSPENSION SYSTEM, RIDE HANDLING FE3 : SUSPENSION SYSTEM, SPORT FE5 : SUSPENSION SYSTEM, RIDE l HANDLING ---- DELETE FE7 : SUSPENSION SYSTEM, FRT & RR HD, VAR 3 FF4 : ARM, TORS BAR SPRING ADJ (C) FF5 : ARM, TORS BAR SPRING ADJ (D) FF6 : ARM, TORS BAR SPRING ADJ (E) FF7 : ARM, TORS BAR SPRING ADJ (F) FG2 : SHOCK ABSORBERS, FRT & RR, FIRM RIDE FG3 : SHOCK ABSORBERS, FRT & RR, GAS PRELOADED FK2 : ARM, TORS BAR SPRING ADJ (A) FK3 : ARM, TORS BAR SPRING ADJ (B) FNT : FENDERS DELETION FP2 : RATIO, TRANSAXLE FINAL DRIVE 3.58 FP3 : RATIO, TRANSAXLE FINAL DRIVE 2.73 FP5 : RATIO, TRANSAXLE FINAL DRIVE 2.95 FP7 : RATIO, TRANSAXLE FINAL DRIVE 3.73 FQ1 : AXLE FRONT, STD RATIO FQ2 : RATIO, TRANSAXLE FINAL DRIVE 3.48 FQ6 : RATIO, TRANSAXLE FINAL DRIVE 4.12 FQ8 : RATIO, TRANSAXLE FINAL DRIVE 2.96 FQ9 : RATIO, TRANSAXLE FINAL DRIVE 3.21 FS3 : SUSPENSION SYSTEM,I-BEAM CONSTRUCTION FVM : AXLE FRONT, F050, 5000 LBS CAPACITY, HYD FVO : RATIO, TRANSAXLE FINAL DRIVE 3.67 FV1 : RATIO, TRANSAXLE FINAL DRIVE 3.72 FV3 : RATIO, TRANSAXLE FINAL DRIVE 3.11 FV4 : RATIO, TRANSAXLE FINAL DRIVE 3.71 FWX : SPRING FRONT,5OOO LBS CAPACITY FW1 : RIDE AND HANDLING, MANUAL ELECTRONIC CONTROLLED FW2 : RATIO, TRANSAXLE FINAL DRIVE 3.06 FWS : RATIO, TRANSAXLE FINAL DRIVE 4.10 FW7 : RATIO, TRANSAXLE FINAL DRIVE 3.83 FW9 : RATIO, TRANSAXLE FINAL DRIVE 3.43 FX1 : RATIO, TRANSAXLE FINAL DRIVE 3.94 FX2 : RATIO, TRANSAXLE FINAL DRIVE 2.66 FX3 : RIDE AND HANDLING, AUTOMATIC ELECTRONIC CONTROLLED AAA FX4 : RATIO, TRANSAXLE FINAL DRIVE 3.35 FX8 : RATIO, TRANSAXLE FINAL DRIVE 3.61 FY1 : RATIO, TRANSAXLE FINAL DRIVE 2.36 FY3 : RATIO, TRANSAXLE FINAL DRIVE 3.79 FY5 : RATIO, TRANSAXLE FINAL DRIVE 3 52 F01 : FRAME, HEAVY DUTY F16 : RATIO, TRANSAXLE FINAL DRIVE 2.53 F17 : RATIO, TRANSAXLE FINAL DRIVE 2.84 F25 : RATIO, TRANSAXLE FINAL DRIVE 3.32 F40 : SUSPENSION SYSTEM, FRT, RR, HD, VAR I F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING F42 : SUSPENSION SYSTEM, FRT, HD F44 : CHASSIS, HEAVY DUTY F47 : AXLE FRONT, 2 73 RATIO F51 : SHOCK ABSORBERS, FRT & RR, HD F58 : STASILIZER SHAFT FR, HD F59 : STABILIZER SHAFT FR, F60 : SPRING FRONT, HEAVY OUTY F61 : STABILIZER SHAFT,RR F62 : RATIO TRANSAXLE FINAL DRIVE 2.39 F66 : SUSPENSION SYSTEM, FRT, AIR BAG & SEATS, HD F67 : RATIO, TRANSAXLE FINAL DRIVE 3.19 F68 : RATIO, TRANSAXLE FINAL DRIVE 3.45 F72 : SPRING HEAVY DUTY, VAR 2 F73 : DRIVE, ALL WHEEL F75 : RATIO, TRANSAXLE FINAL DRIVE 3.18 F77 : RATIO, TRANSAXLE FINAL DRIVE 3.737 F79 : RATIO, TRANSAXLE FINAL DRIVE 2.97 F93 : SPRING FRONT,6000 LB, MULTILEAF GH0 : AXLE REAR, 3.54 RATIO GH2 : AXLE REAR, 2.29 RATIO GH3 : AXLE REAR, 2.77 RATIO GH4 : AXLE REAR, 2.92 RATIO GK9 : AXLE REAR, 4.63 RATIO GL3 : AXLE REAR, 6.17 RATIO GM1 : AXLE REAR, 2.59 RATIO GM3 : AXLE REAR, 3.45 RATIO GM8 : AXLE REAR, 2.56 RATIO GQ1 : AXLE, STD RATIO GS4 : AXLE REAR, 3.70 RATIO GTY : AXLE, WIDE TRACK GT4 : AXLE REAR, 3.73 RATIO GT5 : AXLE REAR, 4.10 RATIO GT7 : AXLE REAR, 3.33 RATIO GT8 : AXLE REAR, 4.10 RATIO GU1 : AXLE REAR, 2.41 RATIO GU2 : AXLE REAR, 2.73 RATIO GU4 : AXLE REAR, 3.08 RATIO GU5 : AXLE REAR, 3.23 RATIO GU6 : AXLE REAR, 3.42 RATIO GV2 : AXLE REAR, 5.83 RATIO GV4 : AXLE REAR, 3.36 RATIO GV8 : AXLE REAR, 2.72 RATIO GW4 : AXLE REAR, 3.31 RATIO GW6 : AXLE REAR, 3.27 RATIO GW9 : AXLE REAR, 2.93 RATIO GX3 : RATIO,TRANSAXLE FINAL DRIVE 3.33 GYS : RATIO TRANSAXLE FINAL DRIVE 3.65 G44 : AXLE REAR 3.07 RATIO G5O : SPRING REAR, HEAVY DUTY, VAR 1 G51 : SPRING REAR, HEAVY DUTY, VAR 2 G52 : SPRING, RR, 15000 LBS G60 : SPRING REAR, AUXILIARY G66 : LEVEL CONTROL, MAN, AIR G67 : LEVEL CONTROL, AUTO, AIR G69 : LEVEL CONTROL, AUTO, AIR, HD G72 : AXLE REAR, 2.14 RATIO G75 : AXLE REAR, 3.62 RATIO G80 : AXLE POSITRACTION, LIMITED SLIP G87 : RING GEAR, 8.50 INCH G89 : RING GEAR, 7.50 INCH G92 : AXLE REAR RATIO, PERFORMANCE G9S : AXLE REAR RATIO, ECONOMY HA3 : AXLE REAR, 5.29 RATIO, SINGLE SPEED HC4 : AXLE REAR, 4.56 RATIO HC7 : AXLE REAR, 5.13 RATIO, 7500 LBS, SINGLE SPEED HC8 : AXLE REAR, 3.21 RATIO, SINGLE SPEED, TRUCK HE3 : AXLE REAR, 3.07 RATIO, 3500 LBS, SINGLE SPEED, HF7 : AXLE REAR, 4.56 RATIO, IOOOO LBS, DANA 70, SINGLE HF8 : AXLE REAR, 4.88 RATIO HK1 : AXLE REAR, 2.87 RATIO HK9 : AXLE REAR, 5.86 RATIO 10000 LBS, SINGLE SPEED HPR : HEADLAMPS, DUAL, RECTANGULAR H04 : AXLE REAR, 4.11 RATIO, SINGLE SPEED IFD : TRIM, INTERIOR DESIGN IF3 : TRIM, INTERIOR DESIGN ILD : TRIM, INTERIOR DESIGN IL3 : TRIM INTERIOR DESIGN IPC : TRIM- INTERIOR DESIGN JAF : BRAKE, PROVISIONS EUROPE JA1 : BRAKE, LIGHT WEIGHT DISC DRUM JA2 : BRAKE, HEAVY WEIGHT DISC DRUM JA3 : BRAKE, SYSTEM, WAGON DISC DRUM JA4 : BRAKE, SYSTEM, PWR FRT DISC, RR DRUM, CAST IRON JA5 : BRAKE, SYSTEM, SPORT COUPE DISC DRUM JA6 : BRAKE, EXTRA LIGHT WEIGHT DISC DRUM JA7 : HANDLE, PARK BRAKE RELEASE, LEATHER JA8 : BRAKE, MEDIUM WEIGHT DISC DRUM JB1 : BRAKE, MANUAL, DISC/DRUM, 4300 LBS JB3 : BRAKE, POWER, DISC/DRUM, 4600 LBS JB5 : BRAKE, POWER, DISC/DRUM, 6400 LBS JB6 : BRAKE, POWER, DISC, DRUM 7200 LBS JB7 : BRAKE, POWER, DISC, DRUM 8400 L85 JB8 : 8RAKE, POWER, DISC, DRUM 10000 LBS JC4 : BRAKE, POWER, DISC, DRUM 5600 LBS JC7 : BRAKE, POWER, DISC/DRUM, 12000 LBS JCB : BRAKE, POWER, DISC/DISC, 20000 LBS JD3 : BRAKE, HYD POWER, DISC/DRUM JD5 : BRAKE, DUAL POWER, DISC/DRUM, 6400 LBS JD6 : BRAKE, HYD POWER, DISC/DRUM, 7200 LBS JD7 : BRAKE, HYD POWER, DISC/DRUM, 8400 LBS JE1 : BRAKE, SYSTEM, EUROPE JF9 : BRAKE, HYD POWER, 4 WHEEL DISC JG1 : SHAFT, PROP, ALUMINUM JL2 : BRAKE, FRT DISC, SINGLE PISTON JL6 : BRAKE, SYSTEM, MAN, FRT DISC, RR DRUM, CAST IRON JL9 : BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W JM3 : BOOSTER, BRAKE, 240MM TANDEM, HIGH FLOW JM4 : BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON, JM5 : BOOSTER, BRAKE, 200MM TANDEM, HIGH FLOW JM7 : BOOSTER, BRAKE HYD HI PERF, DELCO-MORAINE JM8 : BRAKE SYSTEM PWR, FRT DISC RR DRUM, ALUMINUM, JIF : BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON J42 : BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM J50 : BRAKE SYSTEM, POWER J55 : BRAKE SYSTEM, HEAVY DUTY J65 : BRAKE SYSTEM, PWR, FRT & RR DISC J85 : BRAKE SYSTEM, PWR, FRT & RR DISC KA1 : HEATER SEAT KB2 : HEADS ENGINE CAST IRON KB9 : CONTROL, ELECTRONIC, TRANS SHIFT KC4 : COOLING SYSTEM, ENG OIL KD1 : COOLING SYSTEM, TRANS OIL KD5 : HEATER, ENGINE BLOCK----------------\ KG0 : GENERATOR, 74 AMP ] KG6 : GENERATOR, 96 AMP ] KG9 : GENERATOR, 140 AMP ] KL5 : CONVERSION, NATURAL GAS ] KL7 : CONVERSION, LP GAS ] KM9 : MANIFOLD, INLET, ALUMINUM ] KP2 : TIMER, RETAINED ACCESSORY POWER ] K42 : GENERATOR,124 AMP ] K01 : FAN, CLUTCH DRIVE, ON/OFF ] K05 : HEATER ENG, BLOCK-------------------/ K06 : FAN, ENG COOLING K07 : HEATER, FUEL K09 : GENERATOR, 120 AUP K10 : CORD, ENG BLOCK HTR ----- DELETE K15 : LINES, FUEL VAPOR RETURN K19 : REACTOR SYSTEM, AIR INJECTION K20 : MODULE, ELECTRONIC COHTROL K22 : GENERATOR, 94 AMP K30 : CRUISE CONTROL, AUTOMATIC K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC K35 : CRUISE CONTROL, VACUUM RESUME K45 : AIR CLEANER, HEAVY DUTY K46 : AIR CLEANER, HEAVY OUTY, PRE-CLEANER K60 : GENERATOR, 100 AMP K61 : GENERATOR, 97 AMP K64 : GENERATOR, 78 AMP K65 : GENERATOR, 9S AMP K68 : GENERATOR,105 AMP K69 : KEY ADDITIONAL IGNITION K70 : PULSAIR, AIR INJECTION, ENGINE K73 : GENERATOR, 70 AMP K77 : GENERATOR, 56 AMP K79 : GENERATOR, 42 AMP K8I : GENERATOR, 66 AMP K82 : GENERATOR, 75 AMP K85 : GENERATOR, 37 AMP K90 : GENERATOR,108 AMP K91 : GENERATOR, 65 AMP K96 : GENERATOR, 55 AMP, BUILT-IN REGULATOR K97 : GENERATOR, 80 AMP, BUILT-IN REGULATOR K99 : GENERATOR, 85 AMP LA5 : ENGINE, GAS, 4 CYL, 1.8L, MFI, OHC, TUR80 LA7 : ENGINE, DIESEL, 4 CYL, 1.5L, ISUZU LB1 : ENGINE, GAS, 6 CYL, 4.3L, 4BBL, V6, 90 DEG LB4 : ENGINE, GAS, 6 CYL, 4.3L, TBI, V6, 90 DEG LB6 : ENGINE, GAS, 6 CYL, 2.8L, UFI, V6, TRANSVERSE LB8 : ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, LONGITUDINAL LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO LC0 : ENGINE, GAS, 4 CYL, 1.8L, UFI, TUR80 LC1 : ENGINE, GAS, 6 CYL, 2.8L, 2B8L, V6, LONGITUDINAL LC2 : ENGINE, GAS, 6 CYL, 3.8L, 4FI, V6, TURBO, HO LC3 : ENGINE, GAS, 6 YL, 3.8L, 2B8L, V6, 90 DEG LC5 : ENGINE, GAS, 4 CYL, 1.5L, 2B8L LC6 : ENGINE, GAS, 6 CYL, 2 0L, MFI, OHC LC7 : ENGINE, GAS, 8 CYL, 4 IL, MFI LC9 : ENGINE, GAS, 4 CYL, 1.6L, 2BBL, TOYOTA L02 : ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC LD4 : ENGINE, GAS, 6 CYL, 4.1L, 4FI LD5 : ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6 LE2 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, TRANSVERSE LE3 : ENGINE, GAS, 6 CYL, 4.1L, 2BBL, VARAJET STANDARD LE4 : ENGINE, GAS, 4 CYL, 2.0L, MFI, OHC LE8 : ENGINE, GAS, 8 CYL, 7.4L, 4BBL, HO LE9 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HI COMP LF3 : ENGINE, GAS, 8 CYL, 5.0L, TRUCK LF5 : ENGINE, GAS, 8 CYL, 5.7L, 2BBL, HO LF7 : ENGINE, DIESEL, 4 CYL, 3.6L LF8 : ENGINE, GAS 6 CYL 3.0L, MFI, V6, REGULAR FUEL LF9 : ENGINE, DIESEL, 8 CYL, 5.7L LG0 : ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC, HO LG2 : ENGINE, GAS, 6 CYL, 3.8L, SFI, V6 LG3 : ENGINE, GAS, 6 CYL, 3.8L, MFI V6, HO LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL LGS : ENGINE, GAS, 6 CYL, 3.1L, 4FI, V6, TURBO LG6 : ENGINE, GAS, 6 CYL, 3.1L, TBI, V6, LG7 : ENGINE, GAS, 6 CYL, 3.3L, MFI, V6 LGB : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO LG9 : ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, TURBO LH0 : ENGINE, GAS, 6 CYL, 3.1L, MFI, V6 LH6 : ENGINE, DIESEL, 8 CYL, 6.2L LH7 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, 60 DEG, TRANSVERSE LH8 : ENGINE, GAS 4 CYL, 1.8L, 1 TBI, OHC LJ5 : ENGINE, DIESEL, 4 CYL, 1.8L LK9 : ENGINE, GAS, 6 CYL, 3.OL, 2BEL, V6 LL2 : ENGINE, GAS, 6 CYL, 2.8L, 1 TBI V6 60 DEG, HO LL4 : ENGINE, DIESEL, 8 CYL, 6.2L, HEAVY DUTY LL8 : ENGINE, GAS, 4 CYL, 2.OL, 1 TBI, HO LM1 : ENGINE, GAS, 8 CYL, 5.7L, 4BBL LM3 : ENGINE, GAS, 4 CYL, 2.2L, 1 TBI LM9 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, TUR8D LN2 : ENGINE, GAS, 4 CYL, 2.2L, MFI LN3 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6 (3800 SERIES) LN7 : ENGINE, GAS, 6 CYL, 3.0L, MFI V6 HO LN8 : ENGINE, GAS, 4 CYL, 2.5L 1 TBI LONGITUDINAL LP2 : ENGINE, GAS, 3 CYL, 1.OL TBI, OHC, SUZUKI LPS : ENGINE, GAS, 8 CYL, 5.7L 2BBL, HO L01 : ENGINE, GAS, 6 CYL, 3.4L, MFI, OHC, V6, HO L02 : ENGINE, GAS, 4 CYL, 2.OL, MFI L03 : 5.0 LITER V-8 TBI ENGINE L05 : ENGINE, GAS, 4 CYL, 2.OL, 1 TBI L06 : ENGINE, GAS, 8 CYL, 4.5L, MFI, HO LQ7 : ENGINE, DIESEL, 4 CYL, 2.2L, ISUZU LQ9 : ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, LONGITUDINAL LR1 : ENGINE, GAS, 4 CYL, 1.95L, 2BBL LR2 : ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, 60 DEG, TRUCK LR6 : ENGINE, GAS, 8 CYL, 4.5L, 2TBI LR8 : ENGINE, GAS, 4 CYL, 2 .8L, 1 TBI, LR9 : ENGINE, GAS, 4 CYL, 2.0L, 2BBL LSA : ENGINE, DRESS KIT, 4.3L, UPS RETROFIT LST : ENGINE, DIESEL, 4 CYL, 3.9L, CUMMINS MBT LS3 : ENGINE, GAS, 3 CYL, 1.OL, MFI, OHC, TURBO, SUZUKI LS5 : ENGINE, GAS, 4 CYL, 1.6L. I TBI, OHC, ALUMINUM, LS9 : ENGINE, GAS, 8 CYL, 5.7L, 4BBL LT1 : ENGINE, GAS, 8 CYL, 5.7L, TPI, HO LT2 : ENGINE, GAS, 4 CYL, 2.OL, TBI, OHC LT3 : ENGINE, GAS, 4 CYL, 2.OL, MFI, OHC, TURB0 LT5 : ENGINE, GAS, 8 CYL, 5.7L, MFI, OHC LT6 : ENGINE, DIESEL, 6 CYL, 4.3L, V6, LONGITUDINAL LT7 : ENGINE, DIESEL, 6 CYL, 4.3L V6, TRANSVERSE LT8 : ENGINE, GAS, 8 CYL, 4.1L, 2T8I LT9 : ENGINE, GAS, 8 CYL, 5.7L, 488L, HD LU2 : ENGINE, GAS, 6 CYL, 4.3L, TBI V6, 90 DEG, HO LV2 : ENGINE, GAS, 8 CYL, 5.OL, 4BBL LV4 : ENGINE, GAS, 4 CYL, 1.6L, OHC, TURB0, PREMIUM FUEL LV6 : ENGINE, GAS, 4 CYL, 1.8L, MFI LW0 : ENGINE, GAS, 4 CYL, 1.6L, MFI, OHC, HO LA2 : ENGINE, GAS, 8 CYL, 4.5L, MFI LAS : ENGINE, GAS, 6 CYL, 3.0L, TURB0 LX8 : ENGINE, DIESEL, 4 CYL, 2.OL TURBO LY5 : ENGINE, GAS, 4 CYL 1.6L 2BBL REGULAR FUEL LY9 : ENGINE, GAS, 3 CYL 1.OL 2BBL OHC, SUZUKI L01 : ENGINE, GAS, 4 CYL 1.6L MFI, OHC L03 : ENGINE, GAS, 8 CYL 5.OL TBI L04 : ENGINE, DIESEL, 4 CYL, 3.0L L05 : ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8 L11 : ENGINE, GAS, 4 CYL, 1.9L, PREMIUM FUEL L17 : ENGINE, GAS, 4 CYL, I.6L, 2BBL L19 : ENGINE, GAS, 8 CYL, 7.4L, 1TBI, VB L22 : ENGINE, GAS, 6 CYL, 4.1L, 1BBL L25 : ENGINE, GAS, 6 CYL, 4.BL, 1BBL L26 : ENGINE, GAS, 8 CYL, 4.9L, MFI, V8 L27 : ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES) L32 : ENGINE, GAS, 6 CYL, 3.4L, MFI, V6 L34 : ENGINE, GAS, 4 CYL, 2 OL, MFI, DOHC L35 : ENGINE, GAS, 6 CYL, 4 3L, CPI, V6, 90 DEG L37 : ENGINE, GAS, 8 CYL, 4.6L, V8 OHC L38 : ENGINE, GAS, 4 CYL, 2.SL, 1 TBI, HO L40 : ENGINE, GAS, 4 CYL, 2.3L, MFI SOHC L44 : ENGINE, GAS, 6 CYL, 2.8L, MFI V6, HO L48 : ENGINE, GAS, 4 CYL, 1.4L, MFI, PREMIUM FUEL L49 : ENGINE, DIESEL, 8 CYL, 6. SL L54 : ENGINE, GAS, 4 CYL, 1.8L, MFI, REG FUEL L65 : ENGINE, DIESEL, 8 CYL, 6.5L. TURB0, HO L67 : ENGINE, GAS, 6 CYL, 3.8L, YFI, V6, SUPERCHARGED L68 : ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, SHORTER LENGTH L69 : ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO L73 : ENGINE, GAS, 4 CYL, I 6L, T8I, REGULAR FUEL L78 : ENGINE, ALCOHOL, 4 CYL, 2.0L, MFI, OHC L80 : ENGINE, GAS, 6 CYL, 2.5L, MFI, HO L82 : EN6INE, GAS, 6 CYL, 3.lL, MFI, V6, HO L91 : ENGINE, GAS, 4 CYL, I.6 L, UFI, WHC L92 : ENGINE, DIESEL, 4 CYL, 1.9 L, TURBO L93 : ENGINE, DIESEL, 6 CYL, 2.5L, TURB0 L96 : ENGINE, GAS, 8 CYL, 5.7L, MFI L98 : 5.7 LITER V8 TPI ENGINE MAE : MARKETING AREA, EUROPE MAG : MARKETING AREA, GULF STATES MAI : MARKETING AREA, ISRAEL MAJ : MARKETING AREA, JAPAN MAK : MARKETING AREA, ENGLAND UNITED KINGDOM) MAQ : MARKETING AREA, IRAQ MAS : MARKETING AREA, SAUDI ARABIA MAU : MARKETING AREA, UNREGULATED MB1 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03 MB4 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.76 MB6 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03 MC0 : TRANSMISSION, MAN 4 SPD, GETRAG, 64MM, 1ST, 4.00 MC4 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.35 MC5 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 774M, 2.55 MC9 : TRANSMISSION, MAN 4 SPD, B0RG WARNER, 77MM, 4.03 MD2 : TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180C, MD3 : TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180, OPEN MD5 : TRANSMISSION, MAN 5 SPD, GETRAG, 76MM, 3.92 IST, MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4 MD9 : TRANSMISSION, AUTO 3 SPD, THU 125 CLUTCH ME2 : TRANSMISSION, MAN 5 SPD, NEW PROCESS 55OO, 6.29 ME9 : TRANSMISSION, AUTO 4 SPD, THM 440 T4 MF2 : TRANSMISSION, MAN 4 SPD, B0RG WARNER, 774M, 3.76 MF4 : TRANSFER CASE, NP205, 1.96 LO RANGE MG1 : TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM 3.50 1ST, MG2 : TRANSMISSION, MAN 5 SPD, GETRAG, 76MM 3.50 1ST, MG3 : TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM, 3.92 1ST, MG4 : TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 1ST, MGS : TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 4.00 1ST, MH1 : TRANSMISSION, AUTO 4 SPD, THM F-4, ELECTRONIC CONV MH2 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50 MH3 : TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50 MH5 : TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88 MK2 : TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88 MK4 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76 MK5 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.50 MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D MK7 : TRANSMISSION, MAN 5 SPD, ISUZU, 3.91 IST, 1.45 3RD, ML2 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 4.03 ML3 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76 ML8 : TRANSMISSION, MAN S SPD, BORG WARNER, 77MM , 3 SO ML9 : TRANSMISSION, MAN 6 SPD, ZF, 90UM, 2.66 IST, O/D MM3 : MERCHANDISED TRANS, MAN 3 SPD PROVISIONS MM4 : MERCHANDISED TRANS, MAN 4 SPD PROVISIONS MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS MPW : TRANSMISSION, MAN 4 SPD, B0RG KARNER, IO9MM, 4.02 MR2 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST, MR3 : TRANSMISSION, MAN S SPD, ISUZU, 76MM, 3.73 1ST, MR8 : TRANSMISSION, MAN 5 SPD, ISUZU, 76MM, 3.73 1ST, MS7 : TRANSMISSION, AUTO 4 SPD, TOYOTA, ELECTRONIC CONV MT1 : TRANSMISSION, AUTO, 4 SPD, THM R2 MT2 : TRANSMISSION, MAN 5 SPD, ISUZU 76MM, 3.72 1ST, .74 MT8 : TRANSMISSION, MAN 5 SPD, NEW PROCESS, 1O9MM, 6.34 MU1 : TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3 77 1ST, 1.03 MV2 : TRANSMISSION, MAN 5 SPD, 3.42 1ST MV4 : TRANSMISSION, AUTO THM 350, CONV CLUTCH MV5 : TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3. SO 1ST, 1.03 MV9 : TRANSMISSION, AUTO 3 SPD, THM 200, CONV CLUTCH MW1 : TRANSMISSION, MAN 5 SPD, 80RG WARNER, 77MM, 4.03 MW4 : TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 1ST 3.54, MW9 : TRANSMISSION, AUTO 4 SPD, THM 200, CONV CLUTCH MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D MX1 : MERCHANDISED, TRANS, AUTO PROVISIONS MX2 : TRANSMISSION, AUTO 3 SPD, THM 350, CONV CLUTCH 3 MX6 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST, MY1 : TRANSMISSION, MAN 4 SPD, BRASIL, 70MM, 3.75 1ST MY2 : TRANSUISSION, MAN S SPD, HMD, 85MM, 4.D2 1T, O/D MY5 : TRANSMISSION, MAN 5 SPD, HMD, 3.50 1ST, 1.03 MY6 : TRANSMISSION, MAN 4 SPD, NEW PROCESS, 89MM, 3.09 MY7 : TRANSMISSION, MAN S SPD, ISUZU, 3.92 1ST, 1.33 3RD, MY8 : TRANSMISSION, MAN 4 SPD, MUNCIE, 75MM, 3.53 1ST, MZU : TRANSMISSION, MAN 4 SPD, NEW PROCESS, 435 M08 : TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 3.50 M10 : TRANSMISSION, AUTO 4 SPD, IZUZU, ELECTRONIC CONV M13 : TRANSMISSION, AUTO 4 SPD, HMD F31 M17 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST, Ml9 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.53 1ST, M20 : TRANSMISSION, MAN 4 SPD, 117MM, 6.55 1ST M21 : TRANSMISSION, MAN 4 SPD, 82MM, 2.43 1ST M26 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST, M27 : TRANSMISSION, MAN S SPD, GETRAG, 84MM, 2.46 1ST, M29 : TRANSMISSION, MAN 6 SPD, BORG WARNER 85MM, 2.97 M31 : TRANSMISSION, AUTO THM 250 CONV CLUTCH M32 : TRANSMISSION, MAN 5 SPD ISUZU 76MM 3.72 1ST, .70 M33 : TRANSMISSION, AUTO 3 SPD, TORQUE CONV M34 : TRANSMISSION, AUTO 3 SPD, THM 125 M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95 M40 : TRANSMISSION, AUTO 3 SPD, TORQUE CONV VAR 1 M62 : TRANSMISSION, MAN 3 SPD, 76MM, 2.85 RATIO M64 : TRANSMISSION, MAN 3 SPD, 76MM, 3.5O RATIO M73 : TRANSMISSION, MAN 4 SPD, ISUZU, 77.5MM, 4.09 RATIO M75 : TRANSMISSION, MAN 5 SPD, 77MM, 3.40 IST M77 : TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 4.07 M79 : TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 IST, NA1 : EMISSION SYSTEM GVW, LESS THAN 85OO LB NA2 : EMISSION SYSTEM, GERMANY NA4 : EMISSION SYSTEM, GVW,AB0VE 8500 LB NA5 : EMISSION SYSTEM, FEDERAL, TIER O NA6 : EMISSION SYSTEM, HIGH ALTITUDE REQUIREMENTS NA9 : EVAPORATIVE SYSTEM, EMISSION NB1 : EMISSION SYSTEM, CLOSED LOOP NB2 : EMISSION SYSTEM , CALIFORNIA , TIER O NB3 : EMISSION SYSTEM, ABOVE IOO0O LB GVW NB5 : EXHAUST SYSTEM, SINGLE NC3 : TAILPIPE, MODIFICATIONS NC5 : EXHAUST SYSTEM, OVAL VERTICAL TAILPIPES, CHROME NC6 : EXHAUST SYSTEM, SPORTY NC7 : EMISSION OVERRIDE, FEDERAL SYSTEM NC6 : EMISSION SYSTEM, CALIFORNIA, ULEV ND3 : LABEL EMISSION, CONTROL NE2 : FUEL TANK, 151L, 40 GAL NF2 : EMISSION SYSTEM, FEDERAL, TIER 1 NH2 : FUEL TANK, 113L, 30 GAL NJ8 : FUEL TANK, 129L, 34 GAL NJ9 : FUEL TANK 80 GAL LH OR RH FILL NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER NK4 : STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS NK4 : STEERING WHEEL, SPORT LEATHER NK5 : STEERING WHEEL, STANDARD NK7 : FUEL TANK, 117L, 31 GAL NL2 : FUEL TANK, AUXILIARY NL4 : FUEL TANK, 303L, 80 GAL NL6 : FUEL TANK, 13 GAL, SINGLE NL7 : FUEL TANK,I25L, 33 GAL NL8 : FUEL TANK,I32L, 35 GAL, LH, RECT, STEEL NL9 : FUEL TANK,IO2L, 27 GAL NM1 : EMISSION SYSTEM, SWITZERLAND, SWEDEN NM5 : EMISSION SYSTEM, CANADIAN REOUIREMENTS NM6 : EMISSION SYSTEM, RECALIBRATED NM8 : LEADED FUEL SYSTEM, NN1 : EMISSION SYSTEM, DUAL BED MONOLITH CONV NN4 : FUEL TANK, 227L, 60 GAL NN5 : EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL NN7 : LOCK, FUEL FILLER DR ---- DELETE NN8 : EMISSION OVERRIDE, UNLEADED FUEL, EXPORT NN9 : EMISSION SYSTEM, LEADED FUEL, EXPORT NOD : ASSEMBLY PLANT, NORWOOD, OHIO NPG : SHIELD, NOISE ABATEMENT NP1 : TRANSFER CASE, ELECTRONIC SHIFT CONT, TWO SPEED NP5 : LEATHER WRAPPED, STEERING WHEEL AND SHIFT KNOB NP5 : STEERING WHEEL, LEATHER WRAPPED NP7 : STEERING COLUMN, EEC APPROVED NQE : FUEL TANK,20 GAL, SINGLE NQ5 : CAP, STRG WHL HORN, DELUXE NV5 : SHIELD, DIFFERENTIAL CARRIER NV7 : STEERING, POWER, VARIABLE EFFORT NWO : WHEEL, 16 X 6.5, CAST ALUMINUM NW9 : TRACTION CONTROL, ELECTRONIC NXX : EVAPORATIVE SYSTEM, FEDERAL NX1 : WHEEL, I3 X 5.5, LIGHT METAL ALLOY NXB : WHEEL, 14 X 6, LIGHT 4ETAL ALLOY NY1 : SHIELD, FUEL TANK NY7 : SHIELD, TRANSFER CASE NZZ : SALES PACKAGE, SKID PLATE OFF ROAD SPOT N04 : LOCK CONTROL, FUEL FILLER CAP, REM CONT N05 : LQCK CONTROL, FUEL FILLER CAP N08 : LQCK CONTROL, FUEL FILLER DR REM CONT N09 : LOCK CONTROL, FUEL FILLER DR N10 : EXHAUST SYSTEM DUAL N14 : CONVERSION METHANOL FUEL N18 : COVER SIMULATED WIRE WHEEL, LOCKING PACKAGE N23 : FUEL TANK, 83L, 22 GAL N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE N25 : EXHAUST, EXTENSION N27 : STEERING WHEEL, 2 SPOKES STD N31 : STEERING WHEEL, CUSTOM N33 : STEERING COLUMN, TILT TYPE N34 : STEERING WHEEL, WOOD GRAINED PLASTIC N36 : STEERING WHEEL, 4 SPOKES, SPORT N37 : STEERING COLUMN, TILT, TELESCOPING N40 : STEERING, POWER, NON-VARIABLE RATIO N41 : STEERING, POWER, VARIABLE RATIO N45 : STEERING WHEEL, 3 SPOKES N46 : STEERING WHEEL, FOUR SPOKES N51 : STEERING, MANUAL N54 : STEERING WHEEL, 3 SPOKE, SPORT N60 : WHEEL, ALUMINUM, PAINTED N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL N66 : WHEEL, RALLY TYPE , VARI N67 : WHEEL, RALLY TYPE , VAR2 N68 : WHEEL, I5 X 5.5, CHROME N70 : WHEEL, I3 X 5.5 N72 : WHEEL, CUSTOMER PROPERTY N73 : WHEEL, CUSTOM SPORT, VAR 4 N77 : WHEEL, 16 X 7, STEEL STYLED N78 : WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS N81 : TIRES, SPARE FULLSIZE N83 : WHEEL, I5 X 7, CHROME STYLED N84 : TIRES, SPARE ---- DELETE N85 : WHEEL, 14 X 6 HD N89 : WHEEL, TURBO ALUMINUM N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE N91 : COVER, SIMULATED WIRE WHEEL, LOCK N95 : COVER, SIMULATED WIRE WHEEL N96 : WHEEL, 16 X 8, CAST ALUMINUM N97 : WHEEL, 15, HD N98 : WHEEL, CHROME, VAR 2 N99 : WHEEL, HEAVY DUTY PA1 : COVER, WHEEL, VAR 5 PA3 : WHEEL, 15 X 7, ALUMINUM, STYLED PA4 : COVER, WHEEL, PAINTED PA5 : HUBCAPS, WHEEL PA6 : WHEEL, STYLED, PAINTED PB1 : COVER, WHEEL 15 INCH PB2 : COVER, WHEEL TRIM ABS, PLASTIC PB3 : HUBCAPS, COVERS & RETAINERS PB4 : LOCK CONTROL, WHEEL PB5 : WHEEL, 13 X 5.5, MILD STEEL PB6 : WHEEL, INCREASED SIZE PB7 : WHEEL, 14 X 6, PAINTED PB9 : WHEEL, 14 X 5.5, STEEL PC1 : WHEEL, 14 X 6, STEEL PC2 : WHEEL, 14 X 7, STEEL, STYLED PC3 : WHEEL, 14 X 7, STEEL PC4 : WHEEL, 14 X 6, STEEL, STYLED PC5 : WHEEL, 15 X 7, STEEL, STYLED PC6 : WHEEL, 14 X 5.5, LIGHT METAL ALLOY PC7 : WHEEL, 14 X 5.5, STYLED, STEEL PC8 : WHEEL, 13 X 5.5, STEEL STYLED PAINTED PD4 : WHEEL, 15 X 7, LIGHT METAL ALLOY, 5 SPOKES PD7 : WHEEL, 14 X 6.5, CAST ALUMINUM PD8 : WHEEL, 14 X 6, ALUMINUM STYLED PD9 : WHEEL, 13 X 5, MILD STEEL PE0 : WHEEL, 16 X 8, ALUMINUM, LIGHT WEIGHT, STYLED PE1 : WHEEL, 14 X 7, ALUMINUM STYLED PE7 : WHEEL, 13 X 5.5, TRIANGULAR HOLES PF1 : WHEEL, 15 X 6, STEEL STYLED PF2 : WHEEL, 15 X 7, ALUMINUM PF3 : WHEEL, 15 X 6.5, ALUMINUM PF4 : WHEEL, 16 X 7, ALUMINUM PF5 : WHEEL, 16 X 7, LIGHT METAL ALLOY PF6 : WHEEL, 15 X 6.5, ALUMINUM, STYLED PF7 : WHEEL, 15 X 6, ALUMINUM CAST, STYLED PF8 : WHEEL, I4 X 6, STEEL, STYLED, 4 SPOKE PG0 : WHEEL, 16 X 6, ALUMINUM, STYLED PG1 : WHEEL, 15 X 6, STEEL PG2 : WHEEL, 15 X 5.5, STEEL PG4 : WHEEL, 14 X 5.5, ALUMINUM PG5 : WHEEL, 15 X 6, ALUMINUM CAST PG9 : WHEEL, 15 X 6, LIGHT METAL ALLOY PH0 : WHEEL, 15 X 6 FRT, X 7 RR, ALUMINUM PH1 : WHEEL, 15 X 7, STEEL PH3 : WHEEL, 15 X 6, ALUMINUM CAST, 115MM BOLT CIRCLE PH4 : WHEEL, 14 X 5, LIGHT METAL ALLOY PH5 : WHEEL, 14 X 6, ALUMINUM PH6 : WHEEL, 15 X 6, ALUMINUM PH8 : WHEEL, 15, WIRE SPOKE PNV : CARRIER, OUTSIDE SPARE TIRE MOUNT NOT DESIRED PRA : SALES PROCESSING OP, POSTAL SERVICE, COMPANION, AAA PW7 : WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE PW8 : WHEEL, 15 X 6, ALUMINUM, STYLED PW9 : WHEEL, 16 X 9.5, CAST ALUMINUM PX0 : WHEEL, 16 X 7, ALUMINUM, STYLED PX1 : WHEEL, 13 X 5.5 ALUMINUM PX3 : WHEEL, 13 X 5, LIGHT METAL ALLOY PY0 : WHEEL, 16 X 6.5, ALUMINUM PY3 : WHEEL, 16 X 8.5, CAST ALUMINUM PY4 : WHEEL, 14 X 5.5, LIGHT METAL ALLOY PY6 : WHEEL, 13 X 4.5 ALUMINUM P01 : TRIM DISCS, WHEEL, VAR 1 P02 : TRIM DISCS, WHEEL, VAR 2 P03 : COVER, WHEEL, VAR 3 P04 : TRIM DISCS, WHEEL----DELETE P05 : WHEEL, CHROME, VAR 1 P08 : COVER, SUPER DELUXE WHEEL P11 : CARRIER, GLIDE OUT SPARE TIRE P12 : WHEEL, 14 X 6, CHROME P13 : CARRIER, SIDE MOUNTED SPARE WHEEL P14 : CARRIER, INSIDE MOUNTED, SPARE TIRE, LH P15 : CARRIER, INSIDE MOUNTED, SPARE TIRE, RH P16 : CARRIER, RR MOUNTED, SPARE TIRE P17 : COVER SPARE, WHEEL P18 : CARRIER, SPARE TIRE, WITH HOIST P20 : HUBCAPS, WHEEL, STYLED P41 : TIRES, EEC SPECIAL SIDE WALL P42 : TIRES, SELF SEALING P43 : INFLATOR, SPARE TIRE ---- DELETE QAB : TIRE ALL, Pl95/70R14/N BL R/PE ST TL ALS QA1 : WHEEL, 17 X 9 S, ALUMINUM, STYLED OA2 : WHEEL, 17 X 9.5 FRT X 11 RR, ALUMINUM, STYLED QA3 : WHEEL, 16 X 6.0, STEEL QA4 : WHEEL, 15 X 5.5, ALUMINUM QBE : TIRE ALL, LT235/75R15C WL R/PE ST TL OOR OBK : TIRE ALL, P155/8OR13/N BL R/PE ST TL ALS (959127B) OBN : TIRE ALL, LT245/75R16/C BW R/PE ST TBL OOR OBX : TIRE ALL, LT245/75R16/C WOL R/PE ST TEL OOR QBZ : TIRE ALL, P205/55VR16/N BL R/PE ST TL HWY QB4 : WHEEL, 16 X 6, ALUMINIUM QB5 : WHEEL, 16 X 6. 5, STEEL QB6 : WHEEL, 17 X B 5 FRT X 9.5 RR, ALUMINUM, STYLED QCE : TIRE ALL, P205/75R15/N BL R/PE ST TL ALS QCF : TIRE ALL, P205/75R15/N RWL R/PE ST TL ALS QCG : TIRE ALL, P205/75R15/N WS2 R/PE ST TL ALS QCR : TIRE ALL, P205/70R13/N BL R/PE ST TL ALS QCS : TIRE ALL, P205/70R13/N WS1 R/PE ST TL ALS QCT : TIRE ALL, P205/70R13/N RWL R/PE ST TL ALS QCU : TIRE ALL, P215/75RlS/N BL R/PE ST TL ALS QCV : TIRE ALL, P215/75R15/N WS2 R/PE ST TL ALS QCW : TIRE ALL, P215/75R15/N RWL R/PE ST TL ALS QDP : TIRE ALL, P195/70RlS/N BL TBL R/PE ST AL3 QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4 QEB : TIRE ALL, P235/75R15/N WOL R/PE ST TL OOR QEE : TIRE ALL, P205/65R15 BL R/PE ST TL ALS 925 QER : TIRE ALL, P205/65R15 WS2 R/PE ST TL ALS 925 QET : TIRE ALL, P225/75R15/N BL R/PE ST TL ALS QEU : TIRE ALL, P225/75R15/N WS2 R/PE ST TL ALS QFE : TIRE ALL, P185/75R14/N BL R/PE ST TL ALS QFF : TIRE ALL, P185/75R14/N WS2 R/PE ST TL ALS QFL : TIRE ALL, P235/75R15 BW R/PE ST TL ALS lOSS QFN : TIRE ALL, P235/75R15 WL R/PE ST TL ALS lOSS QFT : TIRE ALL, P205/75R14/N BL R/PE ST TL ALS QGK : TIRE ALL,165/60SR14 BL R/ST TL 113 745 (OVERSEAS) QGL : TIRE ALL,175/65SR14 BL TL R/ST 113 B1S (OVERSEAS) QGM : TIRE ALL,175R14 BL TL R/ST HWY 190 BBT (OVERSEAS) QGW : TIRE ALL, P215/60R16/N BL R/PE ST TL AL3 QGY : TIRE ALL, P205/70R15/N BL R/PE ST TL ALS QGZ : TIRE ALL, P205/70R15/N WS R/PE ST TL ALS QHA : TIRE ALL, P235/75R15/X BW R/PE ST TL ALS QHB : TIRE ALL, P235/75R15/X WS2 R/PE ST TL ALS QHE : TIRE ALL, l95/65R15/N BL R/ST TL HWY (9OH 1304PH QHF : TIRE ALL, P205/60R15/N BL R/PE ST TL AL3 QHH : TIRE ALL, P205/60R15/N WOL R/PE ST TL AL3 QHJ : TIRE ALL, P225/70R15/N WS1 R/PE ST TL HWY QHP : TIRE ALL, LT225/75R16/D BW R/PE ST TL ALS QHR : TIRE ALL, LT225/75R16/D BW R/PE ST TL OOR QHS : TIRE ALL, P185/80R13/N BL R/PE ST TL ALS QHT : TIRE ALL, P185/80R13/N WS1 R/PE ST TL ALS QHX : TIRE ALL, P205/70R14/N BL R/PE ST TL ALS QHY : TIRE ALL, P205/70R14/N WS2 R/PE ST TL ALS QID : TIRE ALL, LTl95/75R14/C BL R/PE ST TL ALS QIE : TIRE ALL, P165/70R12/N BL R/PE ST TL ALS QIF : TIRE ALL, P185/60R14/N BL R/PE ST TL ALS QII : TIRE ALL, P215/60R16 8W R/PE ST TL AL3 94H QIM : TIRE ALL, P205/60R15/N BL R/PE ST TL AL2 90S QIN : TIRE ALL, P205/70R15/N BL R/PE ST TL AL2 955 QIP : TIRE ALL, P205/70R15/N WS2 R/PE ST TL AL2 9SS QIQ : TIRE ALL, P205/60R15 WOL R/PE ST TL AL2 90S QIT : TIRE ALL, LT245/75R16/C BL R/PE ST TL ALS QIW : TIRE ALL, LT245/75R16/E BL R/PE ST TL OOR QIX : TIRE ALL, LT265/75R16/C BL R/PE ST TL OOR QIY : TIRE ALL, LT265/75R16/C WOL R/PE ST TL OOR QIZ : TIRE ALL, LT245/75R16/E BL R/PE ST TL ALS QJA : TIRE ALL, P215/60HR14/N BL R/ST TL HWY (OVERSEAS) QJI : TIRE ALL, Pl85/70R14/N BL R/NY TL HWY QJJ : TIRE ALL, 31XlO.50RlSLT/C BW R/PE ST TL OOR QJL : TIRE ALL, P205/75R15/N WOL R/PE ST TL OOR QJR : TIRE ALL, P205/75R14/N WS2 R/PE ST TL ALS QJT : TIRE ALL, P205/75R15/N BL R/PE ST TL OOR QJV : TIRE ALL, LT225/75R15/C BL R/PE ST TL ALS QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4 QLG : TIRE ALL, P205/55R16/N BL R/PE ST TL AL3 QLM : TIRE ALL, P215/60R15/N BL R/PE ST TL ALS QLU : TIRE ALL, P225/55VR16/N BL R/PE ST TL HWY QLV : TIRE ALL, P225/75R15/N WS2/GOLD R/PE ST TL ALS QLW : TIRE ALL, 175R14 BL TL R/ST ALS 120MPH/BBT OVERSEAS QMB : TIRE ALL, P215/60R14/N BL R/PE ST TL AL3 QME : TIRE ALL, Pl95/70R14/N BL R/PE ST TL AL2 QMG : TIRE ALL, P215/60R14/N WOL R/PE ST TL AL3 QMR : TIRE ALL, P205/65R15/N BL R/PE ST TL AL2 QMS : TIRE ALL, P205/55R16 BL R/PE ST TL AL2 B9S QMT : TIRE ALL, P235/55R16/N BL R/PE ST TL AL2 QMV : TIRE ALL, P235/70R15 WS1 R/PE ST TL AL2 1025 QMW : TIRE ALL, Pl95/75R14/N BL R/PE ST TL ALS QMX : TIRE ALL, P195/75R14/N WS2 R/PE ST TL ALS QNJ : TIRE ALL, P215/65R15 BW R/PE ST TL AL3 95H QNM : TIRE ALL, P225/70R15/N BL R/PE ST TL AL2 QNP : TIRE ALL, P2Z5/70R15/N WS1 R/PE ST TL AL2 QNR : TIRE ALL, P215/65R15/N WS2 R/PE ST TL AL3 QNS : TIRE ALL, P215/65R15/N BL R/PE ST TL AL3 QNT : TIRE ALL, P215/65R15/N WOL R/PE ST TL AL3 QNX : TIRE ALL, P225/60R16/N BL R/PE ST TL AL2 QNY : TIRE ALL, P225/60R16/N WS1 R/PE ST TL AL2 QPC : TIRE ALL, Pl85/65HR14/N BL R/ST TL HWY (OVERSEAS) QPD : TIRE ALL, Pl95/65Rl5/N BL R/PE ST TL AL2 B9S QPE : TIRE ALL, P215/60R16/N BL R/PE ST TL AL2 QPH : TIRE ALL, P215/65R15/N BL R/PE ST TL AL2 QPJ : TIRE ALL, P215/65R15/N WS1 R/PE ST TL AL2 QPK : TIRE ALL, P215/70R15/N BL R/PE ST TL ALS 975 QPN : TIRE ALL, P215/70R15/N WS2 R/PE ST TL ALS 97S QPP : TIRE ALL, P215/65R15/N WL R/PE ST TL AL3 95H QPX : TIRE ALL, P225/60R16 BW R/PE ST TL ALS 975 QPY : TIRE ALL, P225/60R16 WS2 R/PE ST TL ALS 975 QQD : TIRE ALL, P235/70RI5 WS2 R/PE ST TL ALS 102S QQG : TIRE ALL, P235/70R15 BL R/PE ST TL AL3 102V QQR : TIRE ALL, P235/70R15 WS1 R/PE ST TL AL3 102V QRF : TIRE ALL, lBSSR14 BL R/ TL lOS TEXTILE (OVERSEAS) QSA : TIRE ALL, P205/75R14/N RWL R/PE ST TL ALS QUK : TIRE ALL, P235/70R15/N WS2/GOLD R/PE ST TL ALS QUS : TIRE ALL, lBS/60HR14 BL R/ST TL 130 (OVERSEAS) QVF : TIRE ALL, P225/60ZR16/N BL R/PE ST TL AL3 QVG : TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97H QVI : TIRE ALL, P175/BDR14 BW R/PE ST TL ALS BBS QWT : TIRE ALL, P245/60R15 WOL R/PE ST TL AL3 lOOT QXJ : TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97U QYH : TIRE ALL, P215/65R15/N WOL R/PE ST TL HWY QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY QZY : TIRE ALL, P255/5OZR16/N BL R/PE ST TL HW4 Q34 : WHEEL SPARE l9.5 X 6 Q4B : GVW RATING 6200 LBS RC1 : TURBO PERFORMANCE SPECIFIC EQUIPMENT RC2 : LAMP GROUP COMPONENTS RRL : WHEEL FRT, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT RRM : WHEEL RR, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT (FI-277B) R04 : WHEEL SINGLE RR R05 : WHEEL DUAL RR R1P : CHASSIS EQUIPUENT HEAVY DUTY, COACHBUILDER/LIVERY R1U : CONVERSION, AUTO-FAB INC. R1V : APPEARANCE PACKAGE R1W : NOISE CONTROL, AIR CLEANER, ECU R1X : NOISE CONTROL, AIR CLEANER, ECU, EXH INTER PIPE R10 : MANUAL, ROADSIDE SERVICE INFO TA6 : RESISTOR, HEADLAMP LW BEAM TB2 : FENDERS, FRT TL1 : GRILLE, SPECIAL TL4 : GRILLE, PAINTED TL6 : GRILLE BLACK TL8 : ORNAMENTATION , EXTR MLDG HOOD, TNQ : BATTERY, ONE DELCO II5O 12V TPS : FANILY CODE, ROOF COVERING TP2 : BATTERY, AUX, CAMPER TP5 : REFLECTOR, BUMPER TR1 : LAMP, TAIL & STOP TR2 : LAMP,TURN SIGNAL, ENLARGED TR4 : HEADLAUPS, RECTANGULAR TR6 : HEADLAMPS CONTROL, LEVELING SYSTEM, MANUAL TR7 : HEADLAMPS CONTROL, LEVELING SYSTEM, AUTOMATIC TR9 : LAMP, GROUP TS6 : LAMP, STOP, HIGH LEVEL TS8 : REFLECTOR, BODY SI TT4 : HEADLAMPS, HALOGEN, 4 TTS : HEADLAMPS, HALDGEN, 2 TU2 : LAMP, MARKER, SIDE TU6 : HEADLAMPS CONTROL, FLASH TO PASS TUB : LAMP, INTR, STOP, HIGH LEVEL ---- DELETE TVR : LAMP, REAR DOME AND READING T1A : IDENTIFICATION, STEERING COLUUN EXPORT REQM'TS T1B : ORNAMENTATION , EXTR, CADILLAC SPRING EDITION T1J : FASCIA,'H' T-TYPE SPECIFICS T1S : SPEEDOMETER, 120 MPH T1U : PACKAGE, DRIVER CONFIDENCE T1X : CONVERSION, EXPORT COMPOSITE HEADLAMP REQM'TS T2F : BRAKE PROVISIONS, SPECIAL T2G : ROOF COVERING, SIMULATED CONVERTIBLE, CAMBRIA T2H : ORNAMENTATION, EXTR, EXPORT UNIQUE REQUIREMENTS T2J : ORNAMENTATION, INTR, EXPORT UNIQUE REQUIREMENTS T2L : IDENTIFICATION ISO SYMBOLS T2U : SHAFT, FRONT STABILIZER, SOLID T2N : SHAFT, FRONT STABILIZER, TUBULAR T2R : LOCK CONTROL, REMOTE FREQ --- DELETE T2T : CONTROL, REMOTE ILLUM ENTRY, RETAINED ACSRY PWR T2V : CONTROL STEERING, TWO FLOW ELECTRONIC T2W : WIRING HARNESS, HI/LOW BEAM, EXPORT T37 : LAMP, FOG, DELUXE T3B : LAMP, PARK & TURN SIGNAL T39 : LAMP, TURN SIGNAL, AUX T43 : SPOILER, RR T46 : HOOD, STEEL T47 : HOOD TURBO T52 : ORNAMENTATION, EXTR FRT FENDER T53 : LAMP PACKAGE, EMER VEH R/CMPT LID T61 : LIGHTING, DAYTIME RUNNING T63 : ALARM, HEADLAMPS ON WARNING SYSTEM T72 : HEADLAMPS, LH RULE OF THE ROAD, EXPORT T73 : HEADLAMPS, RH RULE OF THE ROAD T75 : HEADLAMPS, AUBER T76 : HEADLAMPS, REPLACEABLE BULB TYPE T77 : HEADLAMPS, 2 T79 : LAMP, FOG, RR T80 : HEADLAMPS, AUTO BEAM CONT T81 : LAMP, TAIL AND STOP DELUXE T82 : HEADLAMPS, AUTO ON-OFF CONT T83 : HEADLAMPS, DR, SPECIAL T84 : HEADLAMPS, RH RULE OF ROAD, E MARK RECTANGULAR T85 : HEADLAMPS, LH RULE OF ROAD, E MARK RECTANGULAR T86 : LAMP, BACKUP, PAINTED T87 : LAMP, CORNERING T88 : LAMP, PARKING T89 : LAMP, TAIL & STOP, EXPORT T90 : LAMP, SIGNALING & MARKER EXPORT T93 : TAIL & STOP LAMP, SMOKED T93 : LAMP, TAIL & STOP, SPECIAL T96 : LAMP, FOG UA1 : BATTERY, HEAVY DUTY UA6 : THEFT DETERENT SYS UBO : CLUSTER, INST, OIL, TEMP,TACH ,TURBO BOOST UB2 : CLUSTER, INST, OIL, VOLTS ,TACH ,TURBO BOOST UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH UB4 : LAMP, SIDE MARKER, BOXED FOR SHIPMENT UB7 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, UB8 : HORN, HIGH NOTE UC3 : COMPASS, ELECTRONIC UD1 : CLUSTER, INST, OIL, COOL TEMP UD2 : ALARM, VEHICLE SPEED, 105 K/H UD4 : ALARM, VEHICLE SPEED, 120 K/H UD6 : ALARM, EXHAUST TEMP UD8 : CLOCK, VACUUM FLUORESCENT DIGITAL UE6 : SWITCH, HEADLAMPS UE8 : CLOCK, ELECTRIC, DIGITAL UF2 : LAUP, CARGO UF3 : SWITCH, HIGH IDLE UF6 : LAMP, INTR, CONSOLE, COURTESY UF7 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, FUEL ECON UH1 : INDICATOR, SYS, WARNING LIGHTS UH6 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, INDICATORS UH7 : CLUSTER, INST, COOL TEMP UH9 : CLUSTER, INST, COOL TEMP, TRIP ODOM, TURBO UJ1 : INDICATOR, SYSTEM, BRAKE WARNING UJ2 : INDICATOR, ENGINE OIL LIFE UJ3 : INDICATOR, WATER IN FUEL UJ5 : CLUSTER INST, COOL TEMP, TRIP ODOM, VOLTS UJ6 : INDICATOR, LW TIRE PRESS UJ9 : CLUSTER, INST COOL TEMP, VOLTS, TACH UK1 : FREQUENCIES, JAPANESE RADIO UK2 : LEVER DIRECTIONAL SIGNAL, INCLUDES MULTI FUNCTIONS, UK3 : ELECTRONIC SYSTEM, ACCESSORY CONT UK4 : RADIO, AM/FM STEREO, SEEK/SCAN, ETR UK5 : RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS, ETR UL1 : RADIO, AM/FM STEREO CLOCK ETR UL2 : FREQUENCIES, EUROPEAN RADIO UL5 : RADIO, DELETE UL6 : RADIO, AM, CLOCK, MTR UL9 : RADIO, AM/FM STEREO, PB, CASS CLOCK MTR UM3 : RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, UM7 : RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR UN3 : RADIO, AM/FM STEREO, CASS, MTR UN4 : TAPE CARTRIDGE ---- DELETE UN5 : RADIO, AM/F4 STEREO, SEEK/SCAN, AUTO REV CASS, CB, UN6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC UN8 : RADIO, CITIZENS BAND UN9 : RADIO, SUPPRESSION EQUIPMENT UP2 : RADIO, AM STEREO & FM STEREO, SEEK/SCAN, CLOCK, ETR, ***** UP4 : RADIO AM, ETR UP5 : RADIO AM STEREO-FM STEREO-WX, SEEK/SCAN, AUTO REV UP7 : RADIO PROVISIONS, FOR MONO INSTRUMENTATION UP8 : STEREO RADIO INSTALLMENT PROVISIONS UP9 : RADIO PROVISIONS, FOR STEREO INSTRUMENTATION UQ0 : SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL STD RGE UQ1 : RADIO PROVISIONS, FOR STEREO UQ2 : SPEAKER SYSTEM, 6, DUAL F/D MIR PATCH TWT, DUAL F/D UQ3 : SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO UQ4 : SPEAKER SYSTEM, BOSE, 4 UQ5 : SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL EXTD RGE UQ6 : SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD COAX UQ7 : SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER UQ8 : SPEAKER SYSTEM, 4, DUAL FRT EXTD RGE, DUAL EXTD RGE UQ9 : SPEAKER SYSTEM, DELETE UR3 : INDICATOR, FUEL ECONOMY UR5 : INDICATOR, LOW ENGINE OIL US6 : ANTENNA, FIXED, PAINTED, RADIO US7 : ANTENNA, POWER, PAINTED RADIO UT0 : RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV UT1 : TONE GENERATOR, WARNING UT2 : RADIO, AM/FM STEREO, P3, SEEK/SCAN CLOCK ETR UT3 : RADIO, AM/FM STEREO , SEEK/SCAN, AUTO REV CASS UT4 : RADIO, AM/FM-ST CASS, AUTO NR, TOUCH CONTROL, STEERING WHL CONTROL UT5 : RADIO, AM, CLOCK, ETR UT6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC UT7 : RADIO, AM/FM STEREO, PB, DOLBY , ETR UU0 : RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO REV UU1 : RADIO, AM/FM STEREO-FM STEREO-WX,SEEK/SCAN, COMPACT UU2 : RADIO, AM/FM STEREO, CASS, DOLBY, ETR UU6 : RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS UU7 : RADIO, AM/FM STEREO, CASS, CLOCK ETR UU9 : RADIO, AM/FM STEREO, ETR UV1 : ALARM, VOICE REMINDER UV4 : DISPLAY COMPASS AND RALLY TSD INFO UV5 : DISPLAY , SERVICE REMINDER UV6 : DISPLAY HEAD UP UV8 : TELEPHONE, PROVISIONS FOR MOSILE UV9 : TELEPHONE, MOBILE 6000 SERIES UW0 : SPEAKER SYSTEM, 4, DUAL I/P MTD, DUAL ROOF MTD UW1 : DIAGNOSTIC SYSTEM UW4 : SPEAKER SYSTEM, 6, DUAL FRT DASH MTD F/D, DUAL UW5 : SPEAKER SYSTEM, 6, DUAL I/P MTD, DUAL STD RGE PASS UW6 : SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT UW7 : RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO/REV UW8 : HOUSING GARAGE DOOR OPENER, REM CONT UW9 : GARAGE DOOR OPENER, REM CONT, INCLUDING HOUSING UX0 : SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER UX6 : SPEAKER SYSTEM, FRT DUAL UX7 : SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DL EXTND RGE UY1 : WIRING PROVISIONS , CAMPER UY2 : TELEPHONE, MOBILE, 2000 SERIES UY3 : TELEPHONE, M0BILE, S.E SERIES UY5 : SPEAKER SYSTEM,4,DUAL FRT FLR SILL, DUAL EXT UY7 : WIRING HARNESS, TRUCK TRAILER HD UY9 : CLUSTER, KILO & MILES, MECHANICAL DISPLAY UZ1 : TELEPHONE, PROVISIONS FOR INTEGRATED M08ILE UZ3 : TELEPHONE, M0BILE KEYPAD CONTROL U01 : LAMP, FIVE, ROOF MARKER, TRUCK U03 : HORN, NOISE REGULATION U05 : HORN, DUAL U08 : HORN, DUAL ELECTRIC UO9 : HORN, FOUR NOTE U1A : RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT U1B : RADIO, AM STEREO-FM STEREO SEEK/SCAN COMPACT U1C : RADID, AM/FM STEREO, SEEK/SCAN, COMPACT DISC U1D : RADIO, AM STEREO-FM STEREO-WX, SEEK/SCAN, COMPACT U1E : RADIO, AM STEREO & FM STEREO, SEEK/SCAN COMPACT U1F : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC U1G : RADIO, AM STEREO/FM STEREO, P8, SEEK/SCAN AUTO REV U1H : RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV U1J : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC U1K : RADIO, AM STEREO-FM STEREO SEEK/SCAN, DAT EQUALIZE U1N : RADIO, AM STEREO/FM STEREoiWX/TV, SEEK/SCAN AUTO U1P : RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, AUTO U1Q : RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, CD U11 : CLUSTER, INST, POLICE, CERTIFIED, SPEEDO U12 : SPEEDOMETER, DUAL SCALE WITH KILO ODOMETER U14 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, GAGES U16 : TACHOMETER, ENGINE U17 : CLUSTER INST, OIL, COOL TEUP, VOLTS, CLOCK, FUEL U19 : SPEEDOMETER,INST, KILO & MILES KILO ODOMETER U2A : CLUSTER, INST, COOL TEMP, TRIP ODOM, DR INFO CTR U2S : CLUSTER, INST, OIL, COOL TEMP, TACH, TRIP ODOM U2C : CLUSTER, INST, KILO & MILES, MILES ODOM U2D : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM U2E : CLUSTER, INST, COOL TEMP, TRIP ODOM U2F : CLUSTER, INST, OIL, COOL TEMP, TRIP ODOM, TACH U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH U22 : CLUSTER, INST, OIL COOL TEMP, BATTERY, CLOCK U23 : CLUSTER, INST, TRIM ODOM U25 : LAMP, INTR, RR COMPT, COURTESY U26 : LAMP, INTR, ENG COMPT, COURTESY U27 : LAMP, INTR, I/P COMPT, COURTESY U28 : LAMP, INTR, ASH TRAY, COURTESY U29 : LAMP, INTR I/P, COURTESY U35 : CLOCK, ELECTRIC U37 : LIGHTER CIGARETTE U38 : INDICATOR, LOW COOLANT U39 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM U40 : DISPLAY , DIGITAL DIRECT READOUT, TRIP MONITOR U46 : MONITOR, EXTERNAL LAMP U47 : LAMP, INTR, ENG COMPT, COURTESY, EXTENDABLE U50 : CLUSTER,INST, OIL, COOL TEMP, VOLTS, TRIP ODOM U51 : DISPLAY, FUEL ECONOMY, TSD INFO, SERVICE REM INDER U52 : CLUSTER INST, ELECTRONIC U56 : PLAYER TAPE, CASSETTE U58 : RADIO, AM/FM STEREO, MTR U62 : SPEAKER SYSTEM, DUAL COAXIAL U63 : RADIO, AM, MTR U64 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL STD RGE U65 : SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE U67 : SPEAKER SYSTEM, 8, DUAL F/D 2 TWEET, TWO WOOF, DUAL U68 : DISPLAY,DRIVER INFO CENTER U69 : RADIO, AM/FM, MTR U71 : ANTENNA, ROOF , RADIO U72 : ANTENNA, POWER, FRT, RADIO U73 : ANTENNA, FIXED, RADIO U74 : ANTENNA, RADIO ----DELETE U75 : ANTENNA, POWER, RADIO U76 : ANTENNA, WINDSHIELD, RADIO U77 : ANTENNA, RR WINDOW, RADIO U78 : ANTENNA , POWER , RADIO/TELEPHONE TRISAND U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG U80 : SPEAKER SYSTEM, RR U81 : SPEAKER SYSTEM, RR, DUAL U83 : ANTENNA, POWER, CITIZENS SAND/RADIO TRIBAND U85 : SPEAKER SYSTEM,8 QUAD FRT DR MTD, SHELF QUAD U89 : WIRING HARNESS,CAR TRAILER U93 : ANTENNA, FIXED TELEPHONE U94 : LIGHT CABLE TRAILER, 7 WIRE, VAR 3 U95 : SPEAKER SYSTEM, DOOR U96 : SPEAKER SYSTEM 6, DUAL F/D TWEET & WOOF, DUAL VA2 : RADIATDR SUPPORT STEEL VAN : ASSEMBLY PLANT, VAN NUYS, CA VB1 : LABEL, SHIPPING, JAPAN VB2 : BUMPER,RR STEP, PAINTED, IMPACT STRIP VB3 : BUMPER RR, STEP CHROME, IMPACT STRIP VB4 : PROVISION OPTIONS, GULF STATES ORGANIZATION VB5 : BUMPER FRT PAINTED VB6 : PROVISION OPTIONS, HOT CLIMATE VB7 : BUMPER, FRONT AND REAR SPORT VC9 : OWNERS MANUAL, MERCHANDISED OPTIONS VD1 : PROVISION OPTIONS, EUROPE VD2 : BUMPER, FRT & RR, CHROME, W/IMPACT STRIPS VD4 : BUMPER PROVISIONS, FRT, STEEL VD5 : BUMPER PROVISIONS, RR, STEEL VD6 : BUMPER PROVISIONS, FRT, ALUMINUM VD7 : BUMPER PROVISIONS, RR, ALUMINUM VE1 : PROVISION OPTIONS, JAPAN VE5 : BUMPER, FRT & RR, IMPACT, CHROME VE6 : BUMPER, FRT & RR, IMPACT, COLORED VF1 : BUMPER, RR, CHROME VF6 : BUMPER, RR, STEP, VG2 : PROTECTOR, WAX SPRAY ON ---- DELETE VG3 : BUMPER FRT, IMPACT STRIP VGS : BUMPER RR, IMPACT STRIP VG8 : VEHICLE, BUYER NOTICE LABEL VG9 : PROTECTOR, WAX, EXTERIOR BODY VH4 : MUD FLAPS, VH5 : PLATE, VEHICLE IDENTIFICATION VH6 : BUMPER FRT, BLACK VH7 : BUMPER, CUSTOM VH9 : ENVELOPE, OWNER INFO MAN VJ1 : LICENSE PLATE, RR MOUNTING PKG ---- JAPANESE VJ5 : LICENSE PLATE, MOUNTING INCLUDES BUMPER GUARD, VJ6 : LICENSE PLATE, RR POCKET, DELUXE VJ9 : LABEL, EMISSION, COMPLIANCE, CALIFORNIA VK3 : LICENSE PLATE, FRT MOUNTING PKG VLA : APPEARANCE PACKAGE, WORK TRUCK VL4 : LICENSE PLATE, FRT MOUNTING PKG, EEC VL5 : LICENSE PLATE, RR MOUNTING PKG ---- EXPORT VL6 : LICENSE PLATE, FRT MOUNTING PKG, JAPANESE VND : GOVERNOR, VEHICLE SPEED - 50 MPH VNE : GOVERNOR, VEHICLE SPEED - 55 MPH VNF : GOVERNOR, VEHICLE SPEED - VARIABLE 35-55 MPH VN1 : FLEET PROGRAM, GUARANTEED IOO% REPURCHASE, FAST VN2 : FLEET PROGRAM, GUARANTEED 100% REPURCHASE, CONTROLL VN3 : FLEET PROGRAM, DEALER DAILY RENTAL VP1 : SPOILER FRT VP6 : NOISE CONTROL, VQA : FAN, ENGINE EATON VISCIOUS DRIVE VR2 : TRAILER HITCH, FACTORY INSTALLED VR4 : TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM VR5 : PROVISIONS, SLOW VEHICLE WARNING TRIANGLE MOUNTING VT3 : BUMPER, FRT PAINTED DELUXE, IMPACT STRIPS VT5 : BUMPER RR, COLOR KEYED VT7 : PROVISION OPTIONS, UNREGULATED COUNTRIES VU9 : FLASHLIGHT, MOUNTING PROVISIONS VV1 : FUEL, UNLEADED GAS VV4 : CONTAINER, STOWAGE VV5 : P.O.E. INSTALLATION, AIR CONDITIONER VV6 : P.O.E. INSTALLATION, CRUISE CONTROL VXX : BUMPER FRT,---DELETE--- VYU : PROVISIONS, SNOW PLOW PREP VY7 : KNOB, TRANS CONT LEVER, LEATHER V01 : RADIATOR, HEAVY DUTY, VAR I V02 : RADIATOR, HEAVY DUTY, WITH TRANS OIL COOLER V03 : COOLING SYSTEM, EXTRA CAPACITY V05 : RADIATOR, HEAVY WTY V08 : COOLING SYSTEM, HEAVY WTY V1C : EXHAUST, SINGLE OUTLET EXHAUST V1F : PAINT, SPECIAL METALLIC - CHARGE V1L : TRIM, SPECIAL V10 : PROVISION OPTIONS, COLD CLIMATE V12 : COOLING SYSTEM, POWER STEERING, FLUID V13 : PROVISION OPTIONS, COLD CLIMATE ---- DELETE V2C : WHEEL COLOR, ALUMINUM (MACH FINISHED) V22 : GRILLE, CHROME, RADIATOR V27 : GUARDS, BUMPER, FRT, V28 : GUARDS, BUMPER, FRT, PAINTED V29 : GUARDS, BUMPER, FRT, DELETE V3C : PLANT OPERATION, NON-ASBESTOS BRAKE LININGS V3N : PLANT OPERATION, COLUMN SHIFT V30 : GUARDS, BUMPER, FRT AND RR V31 : GUARDS, BUMPER, FRT, CHROUE V32 : GUARDS, BUMPER, RR V33 : TOOL KIT ROAD EMERGENCY V35 : BUMPER, RR, WITH RECESSED LIGHTING V37 : BUUPER, FRT & RR, CHROME V38 : BUMPER, RR, TRUCK V4A : TRIM, SPRING SPECIAL V4E : MERCHANDISED PKG, CADILLAC BROUGHAM V4F : EQUIPMENT, COACHBUILDER OPTION V4I : NOISE CONTROL, AIR CLEANER, ECM, MUFFLER V4J : IDENTIFICATION, MID-YEAR INTRODUCTION V4N : PROCESSING, GOLD KEY PROGRAM ---- DELETE V4P : TRAILER PROVISIONS, NOT TO EXCEED 7000 LBS V4R : PROVISION OPTIONS, VEHICLE SECURITY V4S : MERCHANDISED PKG, FLEETWOOD D' ELEGANCE V4U : EQUIPMENT, COACHBUILDER, NOT TO EXCEED 7200 LBS V4X : MERCHANDISED PKG, TOURING OPTION V41 : KIT, ACCESSORY V42 : BUMPER RR, STEP, CHROME V43 : BUMPER RR, STEP, PAINTED V46 : BUMPER FRT, CHROME V5O : LICENSE PLATE, FRAME RR ONLY V51 : LICENSE PLATE, FRAME, FRT AND RR V52 : LUGGAGE CARRIER, RR COMPARTMENT V54 : LUGGAGE CARRIER, ROOF, PAINTED V55 : LUGGAGE CARRIER, ROOF CHROME V56 : LUGGAGE CARRIER, RR COMPARTMENT LID, PAINTED V58 : LUGGAGE CARRIER, RR COMPARTMENT LID, CHROME V69 : TRAILER PROVISIONS, NOT TO EXCEED 4000 LBS V70 : HOOK, TOW, FRAME MOUNTED V73 : ANTENNA, FIXED V76 : HOOK, TOW V78 : VEHICLE STATEMENT DELETE V81 : TRAILER PROVISIONS, NOT TO EXCEED 2000 LBS, SAE V82 : TRAILER PROVISIONS 2000 TO 3500 LBS, SAE CLASS 2 V83 : VEHICLE STATEMENT ECE ORGANIZATION V92 : TRAILER PROVISIONS V97 : VEHICLE PREPARATION, EXPORT WA4 : MERCHANDISED PKG, CADILLAC SPECIAL EDITION WB4 : ORNAMENTATION, WOODGRAIN APPLIQUE DELETE WB6 : PACKAGE, DELETE EQUIPUENT LESABRE/SKYLARK WD6 : PROMOTIONAL PROGRAM, MEXICO SALES WE2 : MERCHANDISED PKG, LESABRE 'T' TYPE, GRAND NATIONAL WF1 : MERCHANDISED PKG, CADILLAC DEVILLE TOURING SEDAN WF7 : CONVERSION, FLEETWOOD - SIXTY SPECIAL WG1 : SALES, PROCESSING FOR DR POWER SEAT WJ7 : TRIM OVERRIDE ,INTERIOR 'LEATHER' WL2 : MANIFOLD, EXHAUST, CI WL3 : MERCHANDISED PKG, TROFEO WS4 : MODEL CONVERSION, TRANS AM WS6 : PERFORMANCE PACKAGE, SPECIAL WS9 : MODEL CONVERSION, FORMULA WV9 : MERCHANDISED PKG, VALUE LEADER WW1 : APPEARANCE PACKAGE(WHITE), AERO #l WW2 : APPEARANCE PACKAGE(SILVER), AERO #2 WW3 : APPEARANCE PACKAGE, AERO #3 WW4 : APPEARANCE PACKAGE, AERO #4 WW6 : APPEARANCE PACKAGE, AERO #6 WW7 : APPEARANCE PACKAGE, AERO #7 WW8 : APPEARANCE PACKAGE(BRIGHT RED), AERO #8 WX1 : PAINT, TWO TONE-DELETE WX2 : SALES LEATHER APPOINTMENTS WX7 : WIRING PROVISIONS W02 : PACKAGE SPORT APPEARANCE W03 : SALES, (NOT USED 2-l5-91/OK TO REUSE) W06 : MODEL CONVERSION, CENTURY LIMITED WAGON W09 : M0DEL CONVERSION, CENTURY LIMITED SEDAN W10 : MERCHANDISED PKG, PARK AVENUE MODEL W12 : MERCHANDISED PKG, NINETY-EIGHT TOURING SEDAN W14 : MERCHANDISED PKG, NINETY-EIGHT REGENCY ELITE W16 : APPEARANCE PACKAGE, PGA SPECIAL EDITION W18 : MERCHANDISED PKG, 5OTH ANNIVERSARY NINETY-EIGHT W21 : MERCHANDISED PKG, DRIVER ENTHUSIAST W24 : MERCHANDISED PKG, PARK AVENUE 'ULTRA' W25 : APPEARANCE PACKAGE, SPRING SPECIAL W29 : EXPORT VEHICLE, SEAT BACK LOCK (COUPE) W30 : MERCHANDISED PKG, SPORT W32 : MERCHANDISED PKG, DELUXE SPORT W36 : APPEARANCE PACKAGE, GT LOOK ALIKE W40 : MERCHANDISED PKG, QUAD 442 W41 : MERCHANDISED PKG, HIGH OUTPUT QUAD 442 W44 : MERCHANDISED PKG, SPORTY W45 : MODEL CONVERSION, INTERNATIONAL SERIES COUPE W49 : MODEL CONVERSION, INTERNATIONAL SERIES SEDAN W62 : ORNAMENTATION, AERO PACKAGE W63 : PACKAGE, GROUP 02 W66 : MERCHANDISED PKG, FORMULA W68 : MERCHANDISED PKG, FIREBIRD, SPORT APPEARANCE W81 : WRANGLER, PACKAGE B W90 : APPLICATION, MANDATORY SCHOOL BUS XAA : TIRE FRONT, P255/45ZR17 BL R/PE ST TL HW4 XAU : TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4 XNA : TIRE FRONT, 205/65R15 BW R/PE ST TL HWY 94H X6W : HUB, LOCKING MANUAL X6Z : HUB, LOCKING AUTOMATIC X88 : CONVERSION NAME PLT CHEVROLET YAA : TIRE REAR, P285/40ZR17 BL R/PE ST TL HW4 YAU : TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4 YA2 : DDOR SIDE RR, SLIDING YA9 : AXLE, (3400-LBS) YBE : TIRE REAR, P315/35ZR17/N BL R/PE ST TL HWY YC1 : CONVENIENCE PKG, DECOR LEVEL #1 YC2 : CONVENIENCE PKG, DECOR LEVEL #2 YC3 : CONVENIENCE PKG, DECOR LEVEL #3 YC4 : AXLE (5OOO LB) YC5 : CONVENIENCE PKG, DECOR LEVEL #5 YC6 : CONVENIENCE PKG, DECOR LEVEL #6 YC7 : CONVENIENCE PKG, DECOR LEVEL #7 YC9 : CONVENIENCE PKG, DECOR LEVEL #9 YE2 : CONVENIENCE PKG, DECOR LEVEL #2, LOW TRIM YE3 : CONVENIENCE PKG, DECOR LEVEL #3, HIGH TRIM YE9 : CONVENIENCE PKG, COMFORT & DECOR LEVEL #3 YF3 : CERTIFICATION, EMISSION, FEDERAL YF5 : CERTIFICATION, EMISSION, CALIFORNIA YF7 : SALES PACKAGE, RECREATIONAL VEHICLE UPFITTER YG3 : ORNAMENTATION, BODY SIDE 6 WHL OPENING BRIGHT YG5 : IDENTIFICATION, SEO USAGE YGB : IDENTIFICATION, P E P VEHICLE YG9 : WARRANTY, ENGINE ONLY, 100,000 MILES, 5 YEARS YHX : TIRE REAR, P205/70R14/N BL R/PE ST TL ALS YHY : TIRE REAR, P205/70R14/N WS2 R/PE ST TL ALS YJT : TIRE REAR, P205/75R15/N BL R/PE ST TL OOR YJ3 : DECAL, 4 X 4 YK3 : ORDER PROTECTION, NO CHANGE YL1 : TRIM OVERRIDE, UPHOLSTERY, LEATHER/VINYL YL2 : PAINT SPECIAL, FIREMIST YL4 : TRIM OVERRIDE, UPHOLSTERY, CLOTH YL5 : COMMERCIAL BODY, BUILDER SUPERIOR YL6 : STRIPE COLOR, ACCENT ---- DELETE YL7 : COMMERCIAL BODY, BUILDER S & S COACH YL9 : COMMERCIAL BODY, BUILDER HESS YM5 : STRIPE ACCENT DELETE YM6 : PROCESSING STOCK SALES YNA : TIRE REAR, 205/65R15 BW R/PE ST TL HWY 94H YP1 : MERCHANDISED PKG, CALIFORNIA SEVILLE YP3 : MERCHANDISED PKG, ELDORADO BIARRITZ YP4 : MERCHANDISED PKG, SEVILLE ELEGANTE YP5 : MERCHANDISED PKG, ELDORADO TOURING COUPE YP6 : MERCHANDISED PKG, SEVILLE TOURING SEDAN YP8 : MERCHANDISED PKG, CONVERTIBLE YP9 : MERCHANDISED PKG, SPRING SPECIAL YR1 : SEAT,FRT CUSTOM YR2 : SEAT FRT, CUSTOM YR3 : SEAT FRT LUXURY YS2 : REAR SEAT, DELUXE YT1 : BUILD UP DR & QTR YT2 : BUILD UP DR & QTR, CUSTOM YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS YUB : TIRE REAR,P195/7DR15/N BL TL R/PE ST AL3 YW9 : SALES PACKAGE, UPS RETROFIT KIT YD1 : RING GEAR, 7.50 IN., SAGINAW, (S.P.O.) Y02 : RING GEAR, 7.50 IN., DANA, (S.P.O.) Y03 : RING GEAR, 7.62 IN., SAGINAW, (S.P.O.) Y04 : RING GEAR, 8.50 IN., SAGINAW, (S.P.O.) Y05 : RING GEAR, 8.50 IN., DANA (S P 0.) Y06 : RING GEAR, 9.50 IN., SAGINAW, (S.P 0.) Y07 : RING GEAR, 9.50 IN., DANA (S.P.O ) Y08 : RING GEAR, 9.75 IN., SAGINAW, (S.P.O.) Y09 : RING GEAR, 9.75 IN., DANA (S.P.O.) Y10 : RING GEAR, 10.50 IN., SAGINAW , ( S.P.O . ) Y11 : RING GEAR, 10.50 IN., DANA (S.P.O ) Y12 : RING GEAR, 12.0O IN., ROCKWELL (S.P.O.) Y13 : RING GEAR, 11.50 IN., DANA, (S.P.O.) Y40 : MERCHANDISED PKG, CADILLAC SPCL PGA TOUR EDITION Y48 : MERCHANDISED PKG, ELECTRA - T TYPE Y5E : WARRANTY ENGINE ONLY, 150,000 MILES, 5 YEARS Y56 : MERCHANDISED PKG, GRAN TOURING Y61 : PROVISION OPTIONS, END RELEASE SEAT BELT BUCKLES Y67 : DISPLAY , REMINDER PACKAGE Y70 : PARTS PKG, HEADLINER - VALUE LEADER Y72 : PARTS PKG, HEADLINER Y73 : PARTS PKG, DELUXE HEADLINER Y79 : PROVISION OPTIONS, LOAD BEARING SEAT ADJ Y81 : MERCHANDISED PKG, FIREBIRD Y82 : MERCHANDISED PKG, FORMULA Y83 : MERCHANDISED PKG, TRANS AM Y84 : MERCHANDISED PKG, GTA, TRANS AM Y85 : MERCHANDISED PKG, BONNEVILLE SSE Y86 : MERCHANDISED PKG, CAMARO RS Y88 : PACKAGE, STE SPECIAL TOURING EDITION Y89 : MERCHANDISED PKG, FIREBIRD SE Y91 : MERCHANDISED PKG, LUXURY EDITION Y92 : MERCHANDISED PKG, SPECIAL EDITION Y97 : PACKAGE, GSE SPECIAL EDITION Y98 : CONTROL, RIDE SYSTEM ELECTRONIC Y99 : SALES, HANDLING PKG ZAA : TIRE SPARE, COMPACT ZA7 : PACKAGE, VALUE LEADER-CANADIAN ZE5 : IDENTIFICATION, TRIM LEVEL BASE ZJ2 : FLEET INCENTIVE , PHILLIPS PETROLEUM (A/B/C/H/L/W-TRK ZJ7 : WHEEL,SPECIAL HUB CAP 6 TRIM RING ZK1 : HOOD INSULATION ZL1 : NOISE CONTROL WITH LESS THAN 8000 LB GVW ZL8 : INVOICE, AUTO FAB, INC. ZM3 : INVOICE, AUTO FAB INC . ' CAMEO ' EL ' PICKUP PTI : ON> ZM4 SALES PACKAGE, LUGGAGE CARRIER/RR WINWW DEFLECTOR ZM5 : SALES PACKAGE, UNDERBODY SHIELD ZM6 : CHASSIS PACKAGE, OFF-ROAD SUSPENSION ZM7 : SALES PACKAGE, COMBINATION - INTERMITTENT WIPER/TIL ZM8 : SALES PACKAGE, COMBINATION - ELECTRIC TAILGATE ZN5 : PAINT SPECIAL, TWO TONE SPORT ZP3 : SEATING ARRANGEMENT, FIFTEEN PASSENGER ZP5 : SEATING ARRANGEMENT, FIVE PASSENGER ZP7 : SEATING ARRANGEMENT, SEVEN PASSENGER ZP8 : SEATING ARRANGEMENT, EIGHT PASSENGER ZQ2 : SALES PACKAGE, DRIVER CONVENIENCE ZQ3 : SALES PACKAGE, DRIVER CONVENIENCE II ZQ9 : APPEARANCE PACKAGE, EXTERIOR TRIM, BLACK OUT ZR1 : PERFORMANCE PACKAGE, SPECIAL COUPE ZR9 : APPEARANCE PACKAGE, SYCLONE PICKUP ZVB : MODEL CONVERSION, LUUINA EURO ZW2 : WINDOW PKG, RR DOORS ZW3 : WINDOW PKG, SIDE RR DR, RR DR ZW4 : WINDOW PKG, RIGHT HAND SIDE, RR DRS ZW6 : WINDOW PKG, COMPLETE BODY ZW9 : B0DY EQUIPMENT, BASE BODY OR CHASSIS ZX2 : SEATING ARRANGEMENT, DRIVER & PASSENGER, HIGHBACK ZX4 : WINDOW PKG, LEFT HAND SIDE, SIDE RR DR, RR DR ZX6 : WINDOW PKG, RR DR, SIDE RR DR, SWING OUT ZY1 : COLOR COMBINATION, SOLID ZV6 : COLOR COMBINATION, TWO TONE TREATMENT Z02 : PERFORMANCE PACKAGE, TURBO Z03 : APPEARANCE PACKAGE, 25TH ANNIVERSARY Z04 : MODEL CONVERSION, 'GTZ' BERETTA Z05 : CONVENIENCE PKG Z07 : PERFORMANCE PACKAGE AGGRESSIVE SPORT Z08 : MODEL CONVERSION, CONVERTIBLE 7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 8NB : SPRINT, COMPUTER SELECTED, REAR, LEFT HAND 8NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 8NB : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 8NL : SPRING, COMPUTER SELECTED, REAR, LEFT HAND Z09 : MODEL CONVERSION, CAPRICE CLASSIC Z10 : MODEL CONVERSION, CARGO VAN Z12 : SALES, EXTR FUNCTIONAL & APPEARANCE Z13 : M0DEL CONVERSION, BUICK REGAL GRAN SPORT Z21 : MOOEL CONVERSION 'GT- BERETTA Z22 : MOOEL CONVERSION, ROADMASTER ITT LMTD Z25 : APPEARANCE PACKAGE, 40TH ANNIVERSARY Z26 : MERCHANDISED PKG,OPEL CONVERSION Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE Z34 : MODEL CONVERSION CHEVROLET LUMINA 'Z34' Z41 : CONVERSION OPTION, CANAOIAN PONTIAC Z47 : CONVERSION OPTION, CANADIAN CHEVROLET Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP Z5G : IDENTIFICATION, CALLAWAY ORDERS Z50 : MODEL CONVERSION, PONTIAC TEMPEST Z5I : PACKAGE, PERFORMANCE HANDLING Z52 : MERCHANDISED PKG, SPORT HANDLING Z54 : MODEL CONVERSION, CORSICA LTZ Z62 : CONVENIENCE PKG, COMFORT & DECOR LEVEL #l Z65 : PACKAGE, MONTE CARLO SS Z7H : MODEL CONVERSION, CHEVROLET LUMINA Z7K : MODEL CONVERSION, PONTIAC GRAND PRIX SE Z7L : MODEL CONVERSION, PONTIAC GRAND PRIX LE Z7M : MODEL CONVERSION, PONTIAC GRAND PRIX GT Z7N : MOOEL CONVERSION, PONTIAC GRAND PRIX STE Z7P : MODEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S Z7Q : MOOEL CONVERSION, OLDSM0BILE CUTLASS INTERNATIONAL Z7R : MODEL CONVERSION, OLDSMOBILE CUTLASS SL Z7S : MOOEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S Z7T : MOOEL CONVERSION, BUICK REGAL CUSTOM Z7U : MOOEL CONVERSION, BUICK REGAL LIMITED Z70 : CONVERSION NAME PLT,OLDSMOBILE Z71 : CHASSIS PACKAGE, OFF-ROAD Z72 : TRAILER PPOVISIONS, HITCH, BALL TYPE, L.D. Z73 : CONVENIENCE PKG INTERIOR TRUCK DECOR Z74 : APPEARANCE PACKAGE, SONOMA GT Z76 : CAMPER PROVISIONS , SPECIAL CHASSIS (COMMERCIAL) Z79 : APPEAPANCE PACKAGE, TYPHOON Z8I : CAMPER PROVISIONS, SPECIAL Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0. Z83 : CHASSIS PACKAGE, SOLID SMOOTH RIDE Z85 : CHASSIS PACKAGE, HIGH PAYLOAD FIRM RIDE Z88 : CONVERSION NAME PLT GMTB 00L : SECONDARY COLOR, EXTERIOR, PRIME 00U : PRIMARY COLOR, EXTERIOR, PRIME 01L : SECONDARY COLOR, EXTERIOR, SPECIAL (91) 01U : PRIMARY COLOR, EXTERIOR, SPECIAL, (91) 02A : STRIPE COLOR, ACCENT, TWO TONE, BEIGE/GARNET (93) 02L : SECONDARY COLOR, EXTERIOR, SPECIAL, CHART NOT 02U : PRIMARY COLOR, EXTERIOR, SPECIAL, CHART NOT 04U : PRIMARY COLOR, EXTERIOR, FLAX PEARL, (92) 05P : WHEEL COLOR, ARGENT (91) 06P : WHEEL COLOR, BLACK/SILVER (91) 07A : STRIPE COLOR, ACCENT, TWO TONE, WHITE/MED BEECHWOOD** 07P : WHEEL COLOR, GRAY/RED (91) 08Q : MOLDING COLOR , MARY KAY PINK (91) 08U : PRIMARY COLOR, EXTERIOR, MARY KAY PINK (91) 09A : STRIPE COLOR, ACCENT, TWO TONE, WHITE/DK SAPPHIRE 09U : PRIMARY COLOR, EXTERIOR, OPAQUE WHITE (91) 1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR) 1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE) 1A2 : SEO VEHICLE, PUBLIC SERVICE 1C1 : SEO VEHICLE, EXPORT, NON POLICE VERSION 1K5 : LEVER, AUTO TRANS, LOW GEAR LOCKOUT 1LE : PERFORMANCE PACKAGE COMPONENTS 1M1 : MARKING, REFLECTIVE WHITE, U.S. ARMY 1M3 : MARKING, REFLECTIVE WHITE, U.S. NAVY 1M4 : MARKING, REFLECTIVE BLACK, U S . NAVY 1M5 : MARKING, REFLECTIVE YELLOW 1M6 : MARKING, REFLECTIVE BLUE U.S NAVY 1M8 : MARKING, REFLECTIVE WHITE, OEFENSE LOGISTICS AGENCY 1N4 : MARKING, REFLECTIVE BLACK ARMY NATIONAL GUARD 1NS : MARKING, REFLECTIVE BLACK, U.S. ARMY 1N6 : MARKING, REFLECTIVE YELLOW, U.S. AIR FORCE 1N7 : MARKING, LUSTERLESS BLACK , U S AIR FORCE 1PV : PAINT SCHEME, 21 1SC : PACKAGE, OPTION 03 1SV : PACKAGE, OPTION 20 1SZ : ??? 1TA : AXLE, FULL FLOATING 1T1 : HOSE, RADIATOR & HEATER SI RUB 1Z2 : VEHICLE PREPARATION, ANTI CORROSION HOT MELT 10A : STRIPE COLOR, ACCENT, TWO TONE, LT GRAY/RED (91) 10I : INTERIOR TRIM, ARCTIC WHITE (93) 10N : TRIM COMBINATION, VINYL, ARCTIC WHITE (N) (93) 10P : WHEEL COLOR, GRAY WHITE (91) 10Q : MOLDING COLOR , ARCTIC WHITE (91) 10T : TOP COLOR, ARCTIC WHITE (91) 10U : PRIMARY COLOR , EXTERIOR, ARCTIC WHITE (91) 103 : TRIM COMBINATION, LEATHER, ARCTIC WHITE (93) 11I : INTERIOR TRIM , WHITE (I) (92) 11N : TRIM COMBINATION, VINYL, WHITE (N) (92) 11P : WHEEL COLOR, PINK (92) 11Q : MOULDING COLOR, WHITE 112 : TRIM COMBINATION, LEATHER, WHITE (2) (91) 113 : TRIM COMBINATION, LEATHER, WHITE (3) (91) 114 : TRIM COMBINATION, LEATHER, WHITE (4) (91) 115 : TRIM COMBINATION, LEATHER, WHITE (S) (91) 116 : TRIM COMBINATION, LEATHER, WHITE (6) (91) 119 : SEAT BELT COLOR WHITE (9) (91) 12A : STRIPE COLOR ACCENT SILVER MET (91) 12B : TRIM COMBINATION,CLOTH, GRAPHITE (B) (92) 12C : TRIM COMBINATION,CLOTH, GRAPHITE (C) (92) 12D : TRIM COMBINATION,CLOTH, GRAPHITE (D) (92) 12E : TRIM COMBINATION CLOTH, GRAPHITE (E) (92) 12F : COVERING COLOR FLOOR MAT, GRAPHITE (92) 12H : TRIM COMBINATION CLOTH GRAPHITE (H) (92) 12I : INTERIOR TRIM, GRAPHITE (92) 12K : AUX TOP COLOR WHITE (91) 12L : SECONDARY COLOR, EXTERIOR, SILVER MET (91) 12P : WHEEL COLOR PLATINUM 12Q : MOLDING COLOR, SILVER MET (91) 12U : PRIMARY COLOR, EXTERIOR SILVER MET (91) 122 : TRIM COMBINATION, LEATHER, GRAPHITE (2) (92) 123 : TRIM COMBINATION, LEATHER, GRAPHITE (3) (92) 124 : TRIM COMBINATION, LEATHER, GRAPHITE (4 ) (92) 125 : TRIM COMBINATION, LEATHER, GRAPHITE (S) (92) 126 : TRIM COMBINATION, LEATHER, GRAPHITE (6) (92) 128 : TRIM COMBINATION, CLOTH, GRAPHITE (B) (92) 129 : SEAT BELT COLOR, GRAPHITE (92) 13A : STRIPE COLOR, ACCENT, BRIGHT SILVER MET (91) 13B : TRIM COMBINATION, CLOTH, LT SLATEGRAY (B) (92) 13C : TRIM COMBINATION, CLOTH, LT SLATEGRAY (C) 13D : TRIM COMBINATION, CLOTH, LT SLATEGRAY (D) 13E : TRIM COMBINATION, CLOTH, LT SMOKE GRAY (E) (92) 13G : TRIM COMBINATION, CLOTH, LT GRAY (G) (91T) 13H : TRIM COMBINATION, CLOTH, LT SMOKE GRAY (H) (91) 13I : INTERIOR TRIM, LT SMOKE GRAY (91) 13L : SECONDARY COLOR, EXTERIOR, BRIGHT SILVER MET (91) 13Q : MOLDING COLOR, BRT SILVER MET (91) 13T : TOP COLOR, BRIGHT SILVER MET (91) 13U : PRIMARY COLOR , EXTERIOR, BRIGHT SILVER MET (91) 13V : TRIM COMBINATION, VINYL, LT GRAY (V) 13W : TRIM COMBINATION, VINYL, LT GRAY (W) 132 : TRIM COMBINATION, LEATHER, GRAY (2) (91) 14A : STRIPE COLOR ACCENT, LT GRAY (91) 14B : TRIM COMBINATION, CLOTH, LT GRAY (B) (92) 14C : TRIM C0MBINATION, CLOTH, LT GRAY (C) (92) 14D : TRIM C0MBINATION, CLOTH, LT GRAY (D) (92) 14E : TRIM COMBINATION, CLOTH, LT GRAY (E) (92) 14F : COVERING COLOR, FLOOR MAT, LT GRAY (92) 14G : TRIM COMBINATION, CLOTH, LT GRAY (G) (92) 14H : TRIM C0MBINATION, CLOTH, LT GRAY (H) (93) 14I : INTERIOR TRIM , LT GRAY (I) (92) 14J : TRIM COMBINATION, CLOTH, LT GRAY J (93) 14L : SECONDARY COLOR, XTERIOR, LT GRAY MET (92) 14N : TRIM COMBINATION, VINYL, LIGHT GRAY (N) (92) 14Q : M0LDING COLOR , BLACK 4ET, (91) 14R : TRIM COMBINATION, VINYL, LT GRAY (R) (92) 14U : PRIMARY COLOR , EXTERIOR, LT GRAY 4ET (92) 142 : TRIM COMBINATION, LEATHER, LT GRAY (2) (92) 143 : TRIM COMBINATION, LEATHER, LT GRAY (3) (92) 144 : TRIM COMBINATION, LEATHER, LT GRAY (4) (92) 145 : TRIM COMBINATION, LEATHER, LT GRAY (5) (92) 146 : TRIM COMBINATION, LEATHER, LT GRAY (6) (92) 149 : SEAT BELT, COLOR, LT GRAY (92) 15A : STRIPE COLOR, ACCENT, MED GRAY MET, (91) 15B : TRIM COMBINATION, CLOTH, MED SLATE GRAY (B) (91) 15C : TRIM C0MBINATION, CLOTH, MED SLATE GRAY (C) (91) 15D : TRIM COMBINATION, CLOTH, MED SLATE GRAY (D) (91) 15E : TRIM C0MBINATION, CLOTH, MED SLATE GPAY (E) (91) 15F : COVERING COLOR, FLOOR MAT, MED SLATE GRAY (91 ) 15G : TRIM COMBINATION, CLOTH, SLATE GRAY (G) 15H : TRIM COMBINATION, CLOTH, MED SLATE GRAY (H) (91) 15I : INTERIOR TRIM, MED SLATE GRAY (91) l5J : TRIM COMBINATION, CLOTH, MED SLATE GRAY (J) (91) 15L : SECONDARY COLOR, EXTERIOR, ASTRAL SILVER (91) 15P : WHEEL COLOR SILVER METALLIC (91) l5Q : MOLDING COLOR, MED GRAY MET (91) 15U : PRIMARY COLOR, EXTERIOR ASTRAL SILVER (91) 1.0 : TRIM COMBINATION, LEATHER, MED SLATE GRAY (2) (3t1 154 : TRIM COMBINATION, LEATHER, MED SLATE GRAY (4) (91) 155 : TRIM C0MBINATION, LEATHER, MED SLATE GRAY (5) (91) 156 : TRIM COMBINATION, LEATHER, MED SLATE GRAY (6) (91) 15B : TRIM COMBINATION, CLOTH, MED SLATE (91) 159 : SEAT BELT COLOR, MED SLATE GRAY (91) 16A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/GARNET RED 16L : SECONDARY COLOR, EXTERIOR, WARM GRAY MET (91) 16P : WHEEL COLOR, BRT WHITE (91) 16Q : MOLDING COLOR , BRITE WHITE (91) 16S : ROOF COLOR, GRAY, REMOVABLE PANEL 16T : TOP COLOR, BRITE WHITE (94) 16U : PRIMARY COLOR , EXTERIOR, WARM GRAY 4ET (91) 17A : STRIPE COLOR, ACCENT, SILVER (91) 17F : COVERING COLOR, FLOOR MAT, CHARCOAL (91) 17I : INTERIOR TRIM , CHARCOAL (91) 17L : SECONDARY COLOR, EXTERIOR, LT SLATE MET (91) 17P : WHEEL COLOR, SILVER (91) 17Q : MOLDING COLOR , SILVER (91) 17T : TOP COLOR, PEARL GRAY (91) 17U : PRIMARY COLOR , EXTERIOR, LT SLATE MET (91) 172 : TRIM COMBINATION, LEATHER, CHARCOAL (2) (91) 179 : SEAT BELT, COLOR CHARCOAL (91) 18A : STRIPE COLOR, ACCENT, SLATE GRAY (91) 18B : TRIM COMBINATION, CLOTH, CHARCOAL 18C : TRIM COMBINATION, CLOTH, DK CHARCOAL, (C) 18D : TRIM COMBINATION, CLOTH, DK CHARCOAL, (D) 18E : TRIM COMBINATION, CLOTH, DK CHARCDAL, (E) 18H : TRIM COMBINATION, CLOTH, DK CHARCOAL, (H) 18I : INTERIOR TRIM, DK CHARCOAL, (I) (91) 18P : WHEEL COLOR, CHARCOAL MET (91) 18Q : MOLDING COLOR, SLATE GRAY (91) 18T : TOP COLOR, SLATE GRAY (91) 18U : PRIMARY COLOR, EXTERIOR, SLATE GRAY (91) 18W : TRIM COMBINATION, VINYL, DK CHARCOAL (W) 182 : TRIM COMBINATION, LEATHER, OK CHARCOAL (2) (91) 19A : STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK****** 19B : TRIM COMBINATION, CLOTH, BLACK (B) (91) 19C : TRIM COMBINATION, CLOTH, BLACK (C) (91) 19D : TRIM COMBINATION, CLOTH, BLACK (D) 19E : TRIM COMBINATION, CLOTH BLACK (E) (91) 19F : COVERING COLOR, FLOOR MAT, BLACK (91) 19H : TRIM COMBINATION, CLOTH, BLACK (H) 19I : INTERIOR TRIM, BLACK (I) (91) 19J : TRIM COMBINATION, CLOTH, BLACK (J) 19K : AUX TOP COLOR BLACK (91) 19L : SECONDARY COLOR, EXTERIOR, LAMP BLACK (91) 19R : TRIM COMBINATION, VINYL BLACK (R) 19U : PRIMARY COLOR, EXTERIOR, LAMP BLACK (91) 19W : TRIM COMBINATION, VINYL BLACK (W) 192 : TRIM COMBINATION, LEATHER, BLACK (2) (91 ) 193 : TRIM COMBINATION, LEATHER, BLACK (3) (91) 194 : TRIM COMBINATION, LEATHER, BLACK (4) (91) 195 : TRIM COMBINATION, LEATHER, BLACK (5) (91) 198 : TRIM C0MBINATION, LEATHER, BLACK (6) (92) 198 : TRIM COM8INATION, CLOTH, BLACK (8) (91) 199 : SEAT BELT COLOR, BLACK (91) 20A : STRIPE COLOR, ACCENT, DK ROYAL BLUE (94) 20B : TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (8) (91) 20C : TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (C) (91) 20D : TRIM C0MBINATION, CLOTH. VERY DK SAPPHIRE (D) (91) 20E : TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (E) (91) 20F : COVERING COLOR, FLODR MAT, VERY DK SAPPHIRE (91) 20G : TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (G) (91) 20H : TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (H) (91) 20I : INTERIOR TRIM, VERY DK SAPPHIRE (91) 20J : TRIM COMBINATION,CLOTH, VERY DK SAPPHIRE (J) (91) 20L : SECONDARY COLOR, EXTERIOR, LT QUASAR BLUE MET (92) 20N : TRIM COMBINATION, VINYL(N), VERY DK SAPPHIRE (1991) 20Q : MOLDING COLOR, LT QUASAR 8LUE MET (91) 20U : PRIMARY COLOR, EXTERIOR, LT QUASAR BLUE MET (93) 20V : TRIM COMBINATION, VINYL, SAPPHIRE BLUE (V) (92) 201 : TRIM COMBINATION, VINYL, VERY DK SAPPHIRE (W) 202 : TRIM COMBINATION, LEATHER, VERY DK SAPPHIRE (2) 203 : TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (3) 204 : TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (91) 205 : TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (5) 206 : TRIM C0MBINATION, VINYL, HD, VERY DK SAPPHIRE 207 : TRIM C0MBINATION, CLOTH, HD, VERY DK SAPPHIRE 208 : TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (8) (91) 209 : SEAT BELT, COLOR VERY DK SAPPHIRE (91) 21A : STRIPE COLOR, ACCENT DK SAPPHIRE BLUE (91) 21I : INTERIOR TRIM, DK MONTANA BLUE (I) (94) 21P : WHEEL COLOR, NEON BLUE (91) 21Q : MOLDING COLOR, NEON BLUE MET (92) 21U : PRIMARY COLOR EXTERIOR, NEON BLUE MET (91) 22A : STRIPE COLOR ACCENT LT SAPPHIRE BLUE (91) 22B : TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (B) 22C : TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (C) 22D : TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (D) 22E : TRIM COMBINATION, CLOTH, DK ROYAL BLUE (E) 22G : TRIM COMBINATION, CLOTH, DK ROYAL BLUE (G) 22H : TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (H) 22I : INTERIOR TRIM, DK STEEL BLUE (91) 22L : SECONDARY COLOR, EXTERIOR BAHAMA BLUE MET (91) 22Q : MOLDING CDLOR, LT SAPPHIRE BLUE MET (91) 22T : TOP COLOR, LT SAPPHIRE BLUE MET (91) 22U : PRIMARY COLOR, EXTERIOR BAHAMA BLUE MET (91) 222 : TRIM C0MBINATION, LEATHER DK ROYAL BLUE (2) 223 : TRIM COMBINATION, LEATHER DK STEEL BLUE (3) (91) 224 : TRIM COMBINATION, LEATHER, DK ROYAL BLUE (4) 229 : SEAT BELT COLOR, DK STEEL BLUE (91) 23A : STRIPE COLOR, ACCENT, LT BLUE (91) 23G : TRIM COMBINATION, CLOTH, BLUE (G) 23I : INTERIOR TRIM, LT BLUE (91) 23Q : MOLDING COLOR, MED MAUI BLUE MET (91) 23U : PRIMARY COLOR, EXTERIOR, MED MAUI BLUE MET (91) 23V : TRIM COMBINATION,VINYL, BLUE (V) 23W : TRIM COMBINATION, VINYL, BLUE (M) 24A : STRIPE COLOR, ACCENT , TWO TONE , DK BLUE/SLATE {91 ) 24B : TRIM COMBINATION, CLOTH, DK BLUE (B) (91) 24C : TRIM COMBINATION, CLOTH, DK BLUE (C) (91) 24D : TRIM COMBINATION, CLOTH, DK BLUE (D) (91) 24E : TRIM COMBINATION, CLOTH, DK BLUE (E) (91) 24G : TRIM COMBINATION, CLOTH, DK BLUE (G) (91) 24I : INTERIOR TRIM, DK BLUE (I) (91) 24L : SECONDARY COLOR, EXTERIOR, BRIGHT BLUE MET (91) 24Q : MOLDING COLOR, BRT BLUE MET {91) 245 : ROOF COLOR,BLUE, REMOVABLE PANEL 24U : PRIMARY COLOR, EXTERIOR, BRIGHT BLUE MET (91) 24V : TRIM COMBINATION, VINYL, DK BLUE (V) (91) 24M : TRIM COMBINATION, VINYL, DK BLUE (4) (91) 25A : STRIPE COLOR, ACCENT, TWO TONE, SILVER/BLUE (91) 25U : PRIMARY COLOR, EXTERIOR, STEEL BLUE MET (91) 26A : STRIPE COLOR, ACCENT, TWO TONE, DK SAPPHIRE/RED 26L : SECONDARY COLOR, EXTERIOR, PASTEL BLUE (91) 26T : TOP COLOR, DK BLUE (91) 26U : PRIMARY COLOR, EXTERIOR, PASTEL BLUE (91) 27A : STRIPE COLOR, ACCENT, TW0 TONE, LT BLUE/DK BLUE 27B : TRIM COMBINATION, CLOTH, DK BLUE (B) 27C : TRIM COMBINATION, CLOTH, DK BLUE (C) 27D : TRIM COMBINATION, CLOTH, DK BLUE (D) 27E : TRIM COMBINATION, CLOTH, DK BLUE (E) 27G : TRIM CQMBINATION, CLOTH, DK BLUE (G) 27H : TRIM COMBINATION, CLOTH, DK BLUE (H) 27L : SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE MET 27N : TRIM COMBINATION, VINYL, DK BLUE (N) 27P : WHEEL COLOR, LT BLUE MET (91) 27Q : MOLDING COLOR, MED SAPPHIRE BLUE MET (91) 27R : TRIM COMBINATION, VINYL, DK BLUE (R) 27U : PRIMARY COLOR, EXTERIOR, LT FRENCH BLUE MET (91) 27V : TRIM COMBINATION, VINYL, DK BLUE (V) 27W : TRIM COMBINATION, VINYL, DX BLUE (M) 27X : TRIM COMBINATION, VINYL, DK BLUE (X) 27Y : TRIM COMBINATION, VINYL, DK BLUE (Y) 27Z : TRIM COMBINATION, VINYL, DK BLUE (Z) 272 : TRIM COMBINATION, LEATHER, DK BLUE (2) 273 : TRIM COMBINATION, LEATHER, DK BLUE (3) 274 : TRIM COMBINATION, LEATHER, DK BLUE (4) 275 : TRIM COMBINATION, LEATHER, DK BLUE (5) 276 : TRIM COMBINATION, LEATHER, DK BLUE (6) 28A : STRIPE COLOR, ACCENT, BLUE (91) 28I : INTERIOR TRIM, MED BLUE (91) 28L : SECONDARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91) 28Q : MOLDING COLOR, BLACK SAPPHIRE MET (91) 28T : TOP COLOR, BLACK SAPPHIRE MET (91) 28U : PRIMARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91) 29A : STRIPE COLOR, ACCENT, MED BLUE (91) 29L : SECONDARY COLOR, EXTERIOR, DK BLUE (91) 29T : TOP COLOR, DK SAPPHIRE MET (91) 29U : PRIMARY COLOR, EXTERIOR, DK BLUE (91) 30A : STRIPE COLOR, ACCENT, TWO TONE, LT BLUE MET/GRAY 30L : SECONDARY COLOR, EXTERIOR, GRAY BLUE MET (91) 30U : PRIMARY COLOR, EXTERIOR, GRAY BLUE MET (91) 31A : STRIPE COLOR, ACCENT MINT GREEN MICA (92) 31U : PRIMARY COLOR, EXTERIOR, ARCTIC WHITE PEARL (92) 32A : STRIPE COLOR, ACCENT, LT TEAL MET (92) 32U : PRIMARY COLOR ,EXTERIOR, MED BRIGHT TEAL MT (94) 33A : STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/GARNET 33K : AUX TOP COLOR , LT DRIFTWOOD (91) 33L : SECONDARY COLOR, EXTERIOR, LT MESA BROWN (91) 33P : WHEEL COLOR , LT DRIFTWOOD MET (91) 33Q : MOLDING COLOR, LT DRIFTWOOD MET (91) 33T : TOP COLOR, LT DRIFTWOOD MET (91) 33U : PRIMARY COLOR, EXTERIOR, LT MESA BROWN (91) 34A : STRIPE COLOR, ACCENT, VERMILLION (91) 34K : AUX TOP COLOR, GOLD (91) 34L : SECONDARY COLOR, EXTERIOR, LT MESA BRN MET (91) 34P : WHEEL COLOR, LT MESA BROWN MET (91) 34Q : MOLDING COLOR, LT TEAL MET (92) 34U : PRIMARY COLOR, EXTERIOR, LT MESA BROWN MET (91) 35A : STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BLACK 35L : SECONDARY COLOR, EXTERIQR, YELLOW (92) 35U : PRIMARY COLOR, EXTERIOR, YELLOW (92) 36A : STRIPE COLOR, ACCENT, TWO TONE, LT TEAL/BLACK (93) 36L : SECONDARY COLOR, EXTERIOR, MED DK TEAL MET (92) 36P : WHEEL COLOR, YELLOW (92) 36U : PRIMARY COLOR, EXTERIOR, MED DK TEAL MET (92) 37A : STRIPE COLOR, ACCENT, TWO TONE, DK BRQWN MET/BLACK 37L : SECONDARY COLOR, EXTERIOR, DK BRT TEAL MET (91) 37P : WHEEL COLOR, DK BRIGHT TEAL MET (91) 37Q : MOLDING COLOR, DK BRIGHT TEAL MET 37U : PRIMARY COLOR, EXTERIOR, LT BROWN (91) 38A : STRIPE COLOR, ACCENT, TWO TONE, LT TEAL MET/BEIGE 38F : COVERING COLOR, FLOOR MAT, NATURAL BEIGE (91) 38I : INTERIOR TRIM, NATURAL BEIGE (91) 38U : PRIMARY COLOR, EXTERIOR, CHAMPAGNE MET (91) 382 : TRIM COMBINATION, LEATHER, NATURAL BEIGE (2) (91) 389 : SEAT BELT COLOR, NATURAL BEIGE (91) 39A : STRIPE COLOR, ACCENT, MED BROWN (91) 39U : PRIMARY COLOR, EXTERIOR, DK ADRIATIC BLUE MET (94) 4X8 : SEO-INSTRUMENT PNL DELUXE 4Zl : SEO-SPARE WHL & STO, NO TIRE 4Z2 : SEO-2ND SEAT & BELT 4Z3 : SEO-MATS COLOR KEYED 40A : STRIPE COLOR, ACCENT, WHITE (91) 40L : SECONDARY COLOR, EXTERIOR, WHITE (91) 40P : WHEEL COLOR, WHITE (91) 40Q : MOLDING COLOR, WHITE (91) 40T : TOP COLOR, WHITE (91) 40U : PRIMARY COLOR, EXTERIOR, WHITE (91) 41A : STRIPE COLOR ACCENT BLACK (91) 41L : SECONDARY COLOR, EXTERIOR, BLACK (91) 41P : WHEEL COLOR BLACK (91) 41Q : MOLDING COLOR, BLACK (91) 41T : TOP COLOR, VINYL,BLACK 41T : TOP COLOR, BLACK (91) 41U : PRIMARY COLOR, EXTERIOR, BLACK 42A : STRIPE COLOR, ACCENT TWO TONE SILVER/BLACK (91) 42B : TRIM COMBINATION, CLOTH, MED GRAYFERN (B) 42C : TRIM COMBINATIQN, CLOTH, MED GRAYFERN (C) 42D : TRIM COMBINATION, CLOTH, MED GRAYFERN (D) 42E : TRIM COMBINATIQN, CLOTH, MED GRAYFERN (E) 42H : TRIM C0MBINATION, CLOTH, MED GRAYFERN (H) 42L : SECONDARY COLOR, EXTERIOR, SKY BLUE (91) 42P : WHEEL COLOR, TURQUOISE MET (91) 42U : PRIMARY COLOR , EXTERIOR, SKY BLUE (91) 422 : TRIM COMBINATION, LEATHER, MED GRAY FERN (2) 424 : TRIM COMBINATION, LEATHER, MED GRAY FERN (4) 43A : STRIPE COLOR, ACCENT, MED GREEN (91) 43B : TRIM COMBINATION, CLOTH, MED SAGE (B) 43C : TRIM COMBINATION, CLOTH, MED SAGE (C) 43D : TRIM COMBINATION, CLOTH, MED SAGE (D) 43E : TRIM COMBINATION, CLOTH, MED SAGE (E) 43G : TRIM COMBINATION, CLOTH, MED SAGE (G) 43H : TRIM COMBINATION, CLOTH, MED SAGE ( H ) 43I : INTERIOR TRIM, MED SAGE (I) 43L : SECONDARY COLOR, EXTERIOR, SEAFOAM GREEN (91) 43P : WHEEL COLOR, BRT AQUA (92) 43Q : MOLDING COLOR, MED AQUA MET (91) 43U : PRIMARY COLOR, EXTERIOR, SEAFOAM GREEN (91) 44A : STRIPE COLOR, ACCENT, TWO TONE, LT BROWN/DOESKIN 44L : SECONDARY COLOR, EXTERIOR, FOREST GREEN MET (91) 44U : PRIMARY COLOR, EXTERIOR, FOREST GREEN MET (91) 45A : STRIPE COLOR, ACCENT, TWO TONE, MED BEECHWOOD/LT 45Q : MOLDING COLOR, MED GREEN MET (91) 45U : PRIMARY COLOR, EXTERIOR, MED GREEN MET (91) 46A : STRIPE COLOR, ACCENT, TWO TONE, VERMILION/SLATE 46U : PRIMARY COLOR, EXTERIOR, DK GREEN (91) 47A : STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BEIGE 47B : TRIM COMBINATION, CLOTH, DK RED (B) (91) 47C : TRIM COMBINATION, CLOTH, DK RED (C) (91) 41D : TRIM COMBINATION, CLOTH, DK RED (D) (91) 47E : TRIM COMBINATION, CLOTH, DK RED (E) (91) 47G : TRIM CDMBINATION, CLOTH, DK RED (G) (91) 47I : INTERIDR TRIM, DK RED (I) (91) 47L : SECDNDARY CDLOR, EXTERIOR, DK BLUE MET (91) 47Q : MOLDING CDLOR, EURO RED (91) 47U : PRIMARY COLOR, EXTERIOR, DK BLUE MET (91) 47V : TRIM COMBINATION, VINYL, DK RED (V) (91) 47W : TRIM COMBINATION, VINYL , DK RED (W) (91 ) 472 : TRIM COMBINATIDN, LEATHER, DK RED (2) (91) 48A : STRIPE COLOR, ACCENT, SANDSTONE (92) 48B : TRIM CDMBINATION, CLOTH, MED EMERALD (B) 48C : TRIM COMBINATION, CLOTH, MED EMERALD (C) 48D : TRIM COMBINATION, CLOTH, MED EMERALD (D) 48E : TRIM COMBINATION, CLOTH, MED EMERALD (E) 4BH : TRIM COMBINATION, CLOTH, MED EMERALD (H) 48I : INTERIOR TRIM, MED EMERALD (I) 48L : SECONDARY COLOR EXTERIOR, DK RED (91) 48Q : MDLDING COLOR, DK YELLDW GREEN MET (91) 48U : PRIMARY COLOR EXTERIOR, DK RED (91) 482 : TRIM COMBINATION, LEATHER, MED EMERALD (2) 483 : TRIM COMBINATION, LEATHER, MED EMERALD (3) 484 : TRIM COMBINATION, LEATHER MED EMERALD (4) 49A : STRIPE COLOR ACCENT LT ANTELOPE (91) 49B : TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (B) 49C : TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (C) 49D : TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (D) 49E : TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (E) 49H : TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (H) 49U : PRIMARY COLOR, EXTERIOR, VERDORO GREEN MET ( 92 ) 492 : TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (2) 494 : TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (4) 5AN : TIRE ALL, P225/7DHR15/N WS2 R/PE ST TL AL3 5AQ : TIRE ALL, P225/7DHR15/N BL R/PE ST TL AL3 5A1 : PANEL LEFT, ADSCO (#7280-20-1) 5A2 : PANEL RIGHT, ADSCO (#728D-45-1) 5A3 : PANEL LEFT, INTERIOR, PARTITION,TOP SCREEN ADSCO 5A4 : PANEL RIGHT, INTERIOR PARTITION, ADSCO #728D-46-1 5A5 : RADIATOR, H/D COOLING MANUAL TRANS 5A6 : RADIATOR, H/D COOLING AUTO TRANS 5A7 : WHEEL SPARE, DELETION 5BI : PANEL CENTER, FIXED INTERIOR, PARTITION, TOP SCREEN 5B2 : PANEL CENTER, PARTITION PANEL (FIXED} #7280-51-1 5B3 : PANEL CENTER, INT, PARTITION, ADSCO #72BD-52-1 5B7 : PANEL CENTER, INTERIOR PARTITION, HINGED, ADSCO 5B8 : PANEL CENTER, INTERIOR PARTITION, HINGED ADSCO # 5CI : PANEL, LH, PLEXIGLASS, ADSCO #5226-2 5C2 : PANEL, CTR, PLEXIGLASS, ADSCO #5226-2 5C3 : PANEL, RH, PLEXIGLASS, ADSCO #5226-2 5C7 : HOOK, CARGO TIE DN, BODY - I0 FT 5C8 : HOOK, CARGO TIE DN, BODY - 12 FT 5C9 : HOOK, CARGO TIE DN, BODY - 14 FT 5D4 : COOLING SYSTEM, EXPORT H/D 5D5 : FAN, RADIATOR B00STER 5D8 : PAINT PROCESS, BUMPER, FRT, SPECIAL 5D9 : PAINT PROCESS, BUMPER, RR, SPECIAL 5.0 : MARKING, REFLECTIVE BLACK, DEPARTMENT OF DEFENSE 5.0 : MARKING, REFLECTIVE YELLOW ON BLUE, U.S AIR FORCE 5F4 : SPRING REAR, II000 LB 5F5 : DECAL, ADSCO-WEST ELECTRIC STRIPING, (5858/5859) 5F6 : LEVER, PARKING BRAKE ORSCHELIN 5F7 : MARKING, RED ON REFLECTIVE WHITE, U.S. AIR FORCE 5H1 : PANEL, SERVICE, INTERIOR (#10541/lDS42) 5H2 : LAMP, CARGO , ADSCO (SEARS ROEBUCK) (#7799) 5H3 : LAMP, CARGO ADSCO (SEARS ROE8UCK #7798) (2) 5H5 : WINDOW, SCREEN , SI CARGO DR (SEARS-ROEBUCK) (#7797) 5H6 : WINDOW SCREEN, RR DR (SEARS-ROEBUCK) (#7795) 5H8 : CYLINDER UNIT FOR SINGLE KEY SYSTEM, CODED SOLO 5JK : TIRE ALL P225/70HRIS/N BL P/PE ST TL HWY 5J2 : GENERAT0R, DELETE 5J9 : SPRING RR, AUXILIARY ASSIST 5K4 : EQUIPMENT, PARALLEL BAR KIT - FRITO LAY 5L7 : MARKING, VEH, U S. MARINE CORPS-REFL BLACK 5N1 : DOOR RR, 38 IN, W/GLASS 5N2 : DOOR RR, 74 IN W/GLASS 5P1 : INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/CR 5P2 : WHEEL, ALUMINUM, SPECIAL 5P3 : TIRES, SPARE, CARRIER 5P4 : NET PACKAGE, ENDGATE 5P6 : INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/AD 5Q2 : CONVENIENCE PKG, CARGO VAN 5R2 : SEAT RR, INTERMEDIATE, DELETION 5R9 : SPEAKER SYSTEM, RR, DELETE 5U9 : COVERING, FLOOR MATS, FRT 5V1 : CARRIER, SPARE WHEEL W/O TIRE 5V4 : APPEARANCE PACKAGE, VEHICLE PROVISIONS #l 5V6 : CONVENIENCE PKG, DELUXE 5V7 : APPEARANCE PACKAGE, VEHICLE PROVISIONS #2 5X8 : CYLINDER UNIT, SIDE CARGO & RR DOOR 5Y1 : CARRIER, I/S P/U BOX, MOUNTED, SPARE 5Y9 : CLUSTER, INST, DELETION 5Z1 : CONTAINER, ENG OIL PAN, 5 QUART 5Z4 : WHEEL & TIRE, SPARE, DELETION 5Z5 : HUBCAPS, DELETION 5Z7 : APPEARANCE PACKAGE, MISC PARTS REQ'D FROM GM T & B 5Z9 : ANTENNA, RADIO, DELETE 50F : COVERING COLOR, FLOOR MAT, LT YELLOW (91 ) 50I : INTERIOR TRIM , LT YELLOW (91) 50L : SECONDARY COLOR, EXTERIOR, BLUE WHITE (91) 50P : WHEEL COLOR, BLUE WHITE (92) 50Q : MOLDING COLOR, FLAX (91) 50T : TOP COLOR, FLAX (91) 50U : PRIMARY COLOR, EXTERIOR BLUE WHITE (91) 503 : TRIM COMBINATION, LEATHER, LT YELLOW (3) 504 : TRIM COMBINATION, LEATHER, LT YELLOW (4) (91) 505 : TRIM COMBINATION, LEATHER, LT YELLOW (S) (91) 506 : TRIM COMBINATION, LEATHER LT YELLOW (6} 509 : SEAT BELT, COLOR LT YELLOW (9) (91) 51A : STRIPE COLOR, ACCENT TWO TONE MED BEECHWOOD/DK 51L : SECONDARY COLOR, EXTERIOR SEDONA TAN (91) 51T : TOP COLOR, DK ANTELOPE MET (91) 51U : PRIMARY COLOR EXTERIOR, SEDONA TAN (91) 52A : STRIPE COLOR, ACCENT TWO TONE BLACK/BEIGE MET 52B : TRIM COMBINATION, CLOTH, LT NEUTRAL (B) (92) 52D : TRIM COMBINATION, CLDTH, LT NEUTRAL (D) (92) 52F : COVERING COLOR, FLOOR MAT, LT NEUTRAL (92) 52G : TRIM COMBINATION, CLOTH, LT NEUTRAL (G) (92) 52I : INTERIOR TRIM, LT NEUTRAL (I) (92) 52L : SECONDARY COLOR, EXTERIOR, SEDONA TAN (91) 52P : WHEEL COLOR, GOLD MET (91) 52Q : MOULDING COLOR, JAMACIA YELLOW (92) 52U : PRIMARY COLOR, EXTERIOR, JAMAICA YELLOW (92) 522 : TRIM COMBINATION, LEATHER, LT NEUTRAL (2) (92) 523 : TRIM COMBINATION, LEATHER, LT NEUTRAL (3) (92) 524 : TRIM COMBINATION, LEATHER, LT NEUTRAL (4) (92) 525 : TRIM COMBINATION, LEATHER, LT NEUTRAL (S) (92) 526 : TRIM COMBINATION, LEATHER, CHAMOIS (6) 529 : SEAT BELT COLOR, LT NEUTRAL (9) (92) 53A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/GOLD MET (91) 53U : PRIMARY COLOR, EXTERIOR, COMPETITION YELLOW, (91) 54A : STRIPE COLOR, ACCENT, MED GOLD (91) 54B : TRIM COMBINATION, CLOTH , TAUPE ( B) (92) 54D : TRIM COMBINATION, CLOTH, TAUPE (D) (92) 54F : COVERING COLOR, FLOOR MAT, TAUPE (92) 54G : TRIM COMBINATION, CLOTH, TAUPE (G) (92) 54I : INTERIOR TRIM , TAUPE (I) (92) 54L : SECONDARY COLOR, EXTERIOR, MED FLAX (91) 54Q : MDLDING COLOR, SUNFIRE YELLOW (93) 54U : PRIMARY COLOR, EXTERIOR, MED FLAX (91) 542 : TRIM COMBINATION, LEATHER, TAUPE (2) (92) 543 : TRIM COMBINATION, LEATHER, TAUPE (3) (92) 544 : TRIM COMBINATION, LEATHER, TAUPE (4) (92) 545 : TRIM COMBINATION, LEATHER, TAUPE (S) (92) 546 : TRIM COMBINATION, LEATHER, TAUPE (6) (92) 549 : SEAT BELT COLOR, TAUPE (9) (92) 55A : STRIPE COLOR, ACCENT, GOLD (91) 55Q : MOLDING COLOR, LT CANYON YELLOW (92) 55T : TOP COLOR, DK BROWN (91) 55U : PRIMARY COLOR, EXTERIOR, LT CANYON YELLOW (92) 56A : STRIPE COLOR, ACCENT, TWO TONE, DK BROWN/ALMOND 56T : TOP COLOR, ALABASTER (91) 56U : PRIMARY COLOR, EXTERIOR, ALABASTER (91) 57A : STRIPE COLOR, ACCENT, DK TEAL (92) 57L : SECONDARY COLOR, EXTERIOR, CAMEL BEIGE (91 ) 57P : WHEEL COLOR, BEIGE MET (92) 57Q : MOLDING COLOR , CAMEL BEIGE (91) 57T : TOP COLOR, CAMEL BEIGE (91) 57U : PRIMARY COLOR, EXTERIOR, CAMEL BEIGE (91) 58A : STRIPE COLOR, ACCENT TWO TONE, BLACK/ORANGE (91) 58L : SECONDARY COLOR, EXTERIOR, LT SANDSTONE MET (91) 58T : TOP COLOR, LT SADDLE (91) 58U : PRIMARY COLOR, EXTERIOR, LT SANDSTONE MET (91) 59A : STRIPE COLOR, ACCENT, COPPER BEIGE (91) 59T : TOP COLOR, BRONZE MET (93) 59U : PRIMARY COLOR, EXTERIOR ORANGE MET (92) 6A2 : STEERING COLUMN, SEO KEYED 6A3 : COVERING, FLOOR MATS FRT & RR H. D. 6A4 : CYLINDER UNIT, SINGLE KEY SYSTEM NO SPECIFIC CODE 6A5 : CYLINDER UNIT FOR SINGLE KEY SYSTEM 6B2 : HANDLE, REAR DOOR, INOPERATIVE 6B4 : TIRE SPARE RELOCATION LH LUG COMPT FL. 6B7 : WIRING PROVISIONS ROOF PNL ACCESS HOLE CENTER 6C1 : SEAT, FRT BENCH, HEAVY DUTY 6C2 : SEAT, RR BENCH, HEAVY DUTY 6C4 : SEAT, HEAVY DUTY, FRONT (46/45) SPLIT 6C5 : LAMP, INTR ROOF, COURTESY AND READING 6C6 : SWITCH, REAR DOOR JAMB, LH & RH 6C7 : LAMP, DOME PASSENGER 6C8 : CA8LE, RG58 A/U COAX RADIO ANTENNA 6C9 : CONDUIT, TWO WAY RADIO CONTROL CABLE 6.0 : CYLINDER UNIT, FOR SINGLE KEY SYSTEM, CODED 37D2 6.0 : CYLINDER UNIT, FOR SINGLE KEY SYSTEM, 6F5 : WIRING PROVISIONS, ROOF 6F8 : TRAY, ASH FRT DR 6G2 : REINFORCEMENT, ROOF PANEL 6H6 : LOCK, AUTOMATIC TRUNK, RELEASE, RT 6J1 : WIRING PROVISIONS, IGNITION AND MAIN POWER SUPPLY 6J2 : WIRING PROVISIONS, HEADLIGHT FLASHER AND GRILLE 6J3 : WIRING PROVISIONS, HEADLIGHT FLASHER, GRILLE LIGHTS 6J4 : WIRING PROVISIONS, HORN/SIREN CIRCUIT 6J5 : WIRING PROVISIONS, ROOF PNL ACCESS HOLE 6J6 : LAMP PACKAGE, EMER VEH R/WDO PNL 6K3 : LOCK, AUTO SIDE CARGO & RR DOOR 6K5 : CONSOLE, FRT COMPARTMENT FLOOR 6K6 : SEAT, BUCKET TYPE, DRIVER 6K8 : SEAT, BUCKET TYPE, DRIVER & PASS 6L2 : LINING, FULL LENGTH 6L8 : MIRROR O/S, STAINLESS 6M1 : MIRROR O/S, RR VIEW, WHITE 6M3 : MIRROR O/S, LH & RH, WIDE ANGLE 6M4 : LINING FULL LENGTH (110 IN WB) 6M9 : TIRE SPARE, DELETE, W/WHEEL 6N1 : HANDLE, INSIDE L.H. DOOR AND LOCK RELEASE 6N3 : HANDLE, I/S, RR DOOR RELEASE ASSIST 6N4 : HANDLE, I/S, RR DOQR RELEASE 6N5 : HANDLE INOPERATIVE, RR WINDOW 6N6 : LOCK CONTROL, RR DOOR, INOPERATIVE 6N8 : HANDLE, REAR SEAT ASSIST 6N9 : MIRROR O/S, STAINLESS STEEL HEADS 6P1 : ARM REST, RH DOOR 6P2 : ARM REST, DELETION 6P3 : MIRROR O/S, PAINTED WHITE 6P7 : MIRROR O/S, RR VIEW L & R REM CONT, CHROME 602 : REINFORCEMENT PICK UP B0X 6R2 : COVER SPARE TIRE 6R6 : TRIM, SEAT SEAMLESS VINYL, FRONT & REAR 6R7 : TRIM, SEAT, SEAMLESS CLOTH, FRONT & REAR 6R8 : TRIM, SEAT SEAMLESS CLOTH-FRT SEAMLESS VINYL-RR 6S7 : TRIM OVERRIDE, CLOTH SEAT TRIM, REPLACING VINYL 6T5 : TRIM EXTR, WHITE 6V6 : MODIFICATION, CHASSIS RECREATION VEHICLE 6Y1 : ORNAMENTATION EXTR MLDG, FRT DOOR BODY SI, ] 6Y2 : SEAT RR, ----DELETE ] 6Y4 : WHEEL & TIRE SPARE DELETE ] 6Z2 : SEAL, SPEEDOMETER SHAFT 60B : TRIM COMBINATION, CLOTH, LT DRIFTWOOD ( B) 60C : TRIM COMBINATION, CLOTH, MED COGNAC (C) (91) 60D : TRIM COMBINATION, CLOTH, LT DRIFTWOOD (D) 60E : TRIM COMBINATION, CLOTH, LT DRIFTWOOD (E) 60G : TRIM COMBINATION, CLOTH, LT DRIFTWOOD (G) 60H : TRIM COMBINATION, CLOTH, LT DRIFTWOOD (H) 60I : INTERIOR TRIM, MED COGNAC (91) 60U : PRIMARY COLOR EXTERIOR, BEIGE TITANIUM (92) 60V : TRIM COMBINATION, VINYL, DK COGNAC (V) (1988 TRK) 60W : TRIM COMBINATION, VINYL, DK COGNAC (W) (1988 TRK) 602 : TRIM COMBINATION, LEATHER, LT DRIFTWOOD (2) 603 : TRIM COMBINATION, LEATHER, LT DRIFTWOOD (3) 604 : TRIM COMBINATION, LEATHER, LT DRIFTWOOD (4) 609 : SEAT BELT COLOR, MED COGNAC (91) 61A : STRIPE COLOR, ACCENT, TWO TONE, ALMOND/DK BROWN 61I : INTERIOR TRIM, DK SIENNA (I) 61L : SECONDARY COLOR, EXTERIOR, TAN (91) 61U : PRIMARY COLOR, EXTERIOR, TAN (91) 62A : STRIPE COLOR, ACCENT, ORANGE (91) 62B : TRIM COMBINATION, CLOTH, LT SADDLE (B) 62C : TRIM COMBINATION, CLOTH, LT SADDLE (C) 62D : TRIM COMBINATION, CLOTH, LT SADDLE (D) 62E : TRIM COMBINATION, CLOTH, LT SADDLE (E) 62G : TRIM COMBINATION, CLOTH, LT SADDLE (G) 62H : TRIM COMBINATION, CLOTH, LT SADDLE (H) 62I : INTERIOR TRIM, LT SADDLE (I) 62L : SECONDARY COLOR, EXTERIOR, LT TAUPE (92) 62N : TRIM COMBINATION, VINYL, LT SADDLE (N) 62Q : MOLDING COLOR, LT 8EECHWOOD MET (91) 62R : TRIM COMBINATION, VINYL, LT SADDLE (R) 62T : TOP COLOR, LT BEECHWOOD MET (91) 62U : PRIMARY COLOR EXTERIOR, LT BEECHWOOD MET (91) 62V : TRIM COMBINATION, VINYL, LT SADDLE (V) 62W : TRIM COMBINATION, VINYL, LT SADDLE (W) 62Y : TRIM COMBINATION, VINYL, LT SADDLE (Y) 62Z : TRIM COMBINATION, VINYL LT SADDLE (Z) 622 : TRIM COMBINATION, LEATHER, LT SADDLE (2) 623 : TRIM COMBINATION, LEATHER, LT SADDLE (3) 626 : TRIM COMBINATION, LEATHER, LT SADDLE (6) 626 : TRIM COMBINATION, LEATHER, LT SADDLE (6) 63A : STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK AUBURN 63F : COVERING COLOR, FLOOR MAT, MED SADDLE (93 E/K) 63I : INTERIOR TRIM, MEDIUM SADDLE (93) 63L : SECONDARY COLOR, EXTERIOR, MED TAUPE MET (92) 63T : TOP COLOR, MED TAUPE (92) 63U : PRIMARY COLOR, EXTERIOR, MED TAUPE MET (92) 639 : SEAT BELT, COLOR SADDLE (1989 PASS V) 64A : STRIPE COLOR, ACCENT, LT AUBURN (91) 64B : TRIM COMBINATION, CLOTH, LT BEIGE (B) (92) 64C : TRIM COMBINATION, CLOTH, LT BEIGE (C) (92) 64D : TRIM COMBINATION, CLOTH, LT BEIGE (D) (92) 64E : TRIM COMBINATION, CLOTH, LT BEIGE (92) 64F : COVERING COLOR, FLOOR MAT, LT BEIGE (92) 64G : TRIM COMBINATION, CLOTH, LT BEIGE (G) (92) 64H : TRIM COMBINATION, CLOTH, BEIGE (H) (92) 64I : INTERIOR TRIM, LIGHT BEIGE (I) (92) 64J : TRIM COMBINATION, CLOTH, LT BEIGE (J) (92) 64N : TRIM COMBINATION, VINYL, LT BEIGE (N) (92) 645 : ROOF COLOR, BRONZE, REMOVABLE PANEL 64T : TOP COLOR, LT AUBURN MET (91) 64U : PRIMARY COLOR, EXTERIOR, LT AUBURN MET (91) 64V : TRIM COMBINATION, VINYL, LT BEIGE (V) (92) 64W : TRIM COMBINATION, VINYL , LT BEIGE (W) (92) 642 : TRIM COMBINATION, LEATHER, LT BEIGE (2) (92) 643 : TRIM COMBINATION, LEATHER, LT BEIGE (3) (92) 644 : TRIM COMBINATION, LEATHER, LT BEIGE (4) (92) 645 : TRIM COMBINATION, LEATHER, LT BEIGE (5) (92) 649 : SEAT BELT COLOR, LIGHT BEIGE (9) (92) 65A : STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK CLARET 65B : TRIM COMBINATION, CLOTH, MED ANTELOPE (B) (91) 65C : TRIM COMBINATION, CLOTH, MED ANTELOPE (C) (91) 65D : TRIM COMBINATION, CLOTH, MED ANTELOPE (D) (91) 65E : TRIM COMBINATION, CLOTH, MED ANTELOPE (E) (91} 65F : COVERING COLOR, FLOOR MAT, MED ANTELOPE (91) 65G : TRIM COMBINATION, CLOTH, MED ANTELOPE (G) (91) 65H : TRIM COMBINATION, CLOTH, MED ANTELOPE (H) (1989) 65I : INTERIOR TRIM, MED ANTELOPE (91) 65L : SECONDARY COLOR,EXTERIOR, LT CAMEL TITANIUM (91) 65Q : MOLDING COLOR, LT CAMEL TITANIUM (91) 65T : TOP COLOR, LT CAMEL TITANIUM (91) 65U : PRIMARY COLOR, EXTERIOR, LT CAMEL TITANIUU (91) 652 : TRIM COMBINATION, LEATHER, MED ANTELOPE (2) (91) 653 : TRIM COMBINATION, LEATHER, MED ANTELOPE (3) (91) 654 : TRIM COMBINATION, LEATHER, MED ANTELOPE (4) (91) 655 : TRIM COMBINATION, LEATHER, MED ANTELOPE (5) (91) 659 : SEAT BELT COLOR, MED ANTELOPE (9) (91) 66A : STRIPE COLOR, ACCENT, DK AUBURN (91) 66B : TRIM COMBINATION, CLOTH, MED BEECHWOOD (B) 66C : TRIM COMBINATION, CLOTH, MED BEECHWOOD (C) 66D : TRIM COMBINATION, CLOTH, MED BEECHWOOD (D) 66E : TRIM COMBINATION, CLOTH, MED BEECHWOOD (E} 66F : COVERING, COLOR, FLOOR MAT MED BEECHWOOD (91) 66G : TRIM COMBINATION, CLOTH, MED BEECHWOOD (G} 66H : TRIM COMBINATION, CLOTH MED BEECHWOOD, (1989 PASS) 66I : INTERIOR TRIM, MED BEECHWOOD (91) 66J : TRIM COMBINATION, CLOTH, MED BEECHWOOD (J) (1989) 66L : SECONDARY COLOR, EXTERIOR, DK AUBURN MET (91) 66Q : MOLDING COLOR, DK AUBURN MET (91) 66T : TOP COLOR, DK AUBURN MET (91) 66U : PRIMARY COLOR, EXTERIOR, DK AUBURN MET (91) 662 : TRIM COMBINATION, LEATHER, MED BEECHWOOD (91) 663 : TRIM COMBINATION, LEATHER, MED BEECHWOOD (3) (92) 664 : TRIM COMBINATION, LEATHER MED BEECHWOOD (4) (91) 665 : TRIM COMBINATION, LEATHER NED BEECHWOOD (5) (91) 666 : TRIM COMBINATION, LEATHER, MED BEECHWOOD (6) (91 ) 667 : TRIM COMBINATION, CLOTH, HD, MED BEECHWOOD 668 : TRIM COMBINATION, LEATHER, MED BEECHWOOD (B) (92) 669 : SEAT BELT COLOR, MED BEECHWOOD (9) (91) 67A : STRIPE COLOR, ACCENT, LT CAMEL MET (91) 67B : TRIM COMBINATION, CLOTH, LT CAMEL (B) (91) 67C : TRIM COMBINATION, CLOTH, LT CAMEL (C) (91) 67D : TRIM COMBINATION, CLOTH, LT CAMEL (D) (91) 67E : TRIM COMBINATION, CLOTH, LT CAMEL (E) (91) 67F : COVERING COLOR, FLOOR MAT, CAMEL (91) 67G : TRIM COMBINATION, CLOTH, CAMEL (G) 67H : TRIM COMBINATION, CLOTH, LT CAMEL (H) (91) 67I : INTERIOR TRIM, LT CAMEL (91) 67J : TRIM COMBINATION, CLOTH, LT CAMEL (J) (91) 67L : SECONDARY COLOR, EXTERIOR, LT CAMEL MET (91) 67N : TRIM COMBINATION, VINYL, CAMEL (N) 67P : WHEEL COLOR, LT CAMEL MET (91) 67Q : MOLDING COLOR, LT CAMEL MET (91) 67T : TOP COLOR, LT CAMEL MET (91) 67U : PRIMARY COLOR, EXTERIOR, LT CAMEL MET (91) 672 : TRIM COMBINATION, LEATHER, LT CAMEL (2j (91) 673 : TRIM COMBINATION, LEATHER, LT CAMEL (3)(91) 674 : TRIM COMBINATION, LEATHER, LT CAMEL (4) (91) 675 : TRIM COMBINATION, LEATHER, LT CAMEL (5) (91) 676 : TRIM COMBINATION, LEATHER, LT CAMEL (6) (91) 678 : TRIM COMBINATION, CLOTH, LT CAMEL (B) (91) 679 : SEAT BELT, COLOR,LT CAMEL (91) 68A : STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/LT 68B : TRIM COMBINATION, CLOTH, DK AUBURN ( B) (91 ) 68C : TRIM COMBINATION, CLOTH, DK AUBURN (91) 68D : TRIM COMBINATION, CLOTH, DK AUBURN (D) (91) 68E : TRIM COMBINATION, CLOTH, DK AUBURN (E) (91) 68F : COVERING COLOR, FLOOR MAT, DK AUBURN (91) 68G : TRIM COMBINATION, CLOTH, DK AUBURN (G) (91) 68I : INTERIOR TRIM, DK AUBURN (91) 68L : SECONDARY COLOR, EXTERIOR, CINNAMON MET ( 92 ) 68R : TRIM COMBINATION , VINYL , RUSSET (R) 68T : TOP COLOR, NEUTRAL BEIGE (91) 68U : PRIMARY COLOR, EXTERIOR, CINNAMON MET (92} 682 : TRIM COMBINATION, LEATHER, DK AUBURN (2) (91 ) 683 : TRIM COMBINATION, LEATHER, DK AUBURN (3) (91) 684 : TRIM COMBINATION, LEATHER, DK AUBURN (4) (91) 685 : TRIM COMBINATION, LEATHER, DK AUBURN (S) (91) 689 : SEAT BELT, COLOR, DK AUBURN (9) (91) 69A : STRIPE COLOR, ACCENT, LT BEIGE (91) 69B : TRIM COMBINATION, CLOTH, MED BEIGE (B) 69C : TRIM COMBINATION, CLOTH, MED BEIGE (C) 69D : TRIM COMBINATION, CLOTH, MED BEIGE (D) 69E : TRIM COMBINATION, CLOTH, MED BEIGE (E) 69G : TRIM COMBINATION, CLOTH, MED BEIGE (G) 69H : TRIM COMBINATION, CLOTH, MED BEIGE (H) 69L : SECONDARY COLOR, EXTERIOR, ROOTBEER MET (92) 69Q : MOLDING COLOR, ROOTBEER, MET (92) 69T : TOP COLOR, ROOTBEER (92) 69U : PRIMARY COLOR, EXTERIOR, MED BEECHWOOD MET (91) 69V : TRIM COMBINATION, VINYL, MED BEIGE (V) 69W : TRIM COMBINATION, VINYL MED BEIGE (W) 692 : TRIM COMBINATION, LEATHER, MED BEIGE (2) 693 : TRIM COMBINATION, LEATHER, MED BEIGE (3) 694 : TRIM COMBINATION, LEATHER, MED BEIGE (4) 696 : TRIM COMBINATION, LEATHER, MED BEIGE (6) 7B3 : SUSPENSION SYSTEM, SPECIAL HANDLING 7B4 : SUSPENSION SYSTEM, SPECIAL RYDER 7B7 : SUSPENSION SYSTEM, HEAVY DUTY, FRONT 7J1 : PACKAGE,HOT CLIMATE 7L1 : GENERATOR , A/C 120 AMP 7L4 : THROTTLE CONTROL,MANUAL ASM 7L8 : COOLING SYSTEM, TRANS, OIL, H D 7L9 : COOLING SYSTEM, STEERING, OIL 7P8 : COOLING SYSTEM, ENG OIL, SEE KC4 7S1 : FUEL TANK, RH MOUNTED, 20 GAL 7T6 : FUEL, FITTING, LINE TAKE 7X6 : SPOTLAMP, LEFT HAND, PILLAR MOUNTED, HALOGEN 7X7 : SPOTLAMP, LEFT AND RIGHT, PILLAR MOUNTED, HALOGEN 7XB : SPOTLAMP, PROVISIONS, LH 7X9 : SPOTLAMP, PROVISIONS, LH W RH 7Y1 : LAMP, ENGINE COMPARTMENT 7Y2 : LAMP, DOOR OPENING WARNING 7Y4 : METER, ENGINE, HOUR 7Y5 : BATTERY , HO, AUXILIARY 7Y6 : SWITCH, DOME LAMP DOOR JAMB INOPERATIVE 7Z1 : HORN, DUAL, HIGH NOTE 7Z4 : CLUSTER, INST, OIL, COOL TEMP, VOLTS SEE U14 7Z5 : CIRCUIT BREAKERS, ADDITIONAL 12 VOLT 7Z7 : CLUSTER INST, KILO, GOVERNMENT LEADED FUEL 7Z8 : SPEEDOMETER, PRODUCTION TYPE 7Z9 : CLUSTER POLICE TYPE-TELLTALE 70A : STRIPE COLOR ACCENT, TWO TONE, RED/DK CLARET (91) 70B : TRIM COMBINATION, CLOTH, DK MAPLE RED (B) (91) 70C : TRIM COMBINATION, CLOTH, DK MAPLE RED (C) (91) 70D : TRIM COMBINATION, CLOTH, DK MAPLE RED (D) (91) 70E : TRIM COMBINATION, CLOTH, DK MAPLE RED (E) (91) 70F : COVERING COLOR, FLOOR MAT DK MAPLE RED (91) 70G : TRIM COMBINATION, CLOTH, OK MAPLE RED (G) (91) 70H : TRIM COMBINATION, CLOTH, DK MAPLE RED (H) (91) 70I : INTERIOR TRIM, DK MAPLE RED (91) 70J : TRIM COMBINATION, CLOTH, DK MAPLE RED (J) (91) 70L : SECONDARY COLOR, EXTERIOR, RED (91) 70N : TRIM COMBINATION, VINYL, DK MAPLE RED (N) 70R : TRIM COMBINATION, VINYL, DK MAPLE RED (R) 70T : TOP COLOR, TORCH RED (93) 70U : PRIMARY COLOR, EXTERIOR, TORCH RED (91) 70V : TRIM COMBINATION, VINYL, DK MAPLE RED (V) 702 : TRIM COMBINATION, LEATHER, DK MAPLE RED (2) (91) 703 : TRIM COMBINATION, LEATHER, DK MAPLE RED (3) (91) 709 : SEAT BELT COLOR, DK MAPLE RED (9) (91) 71A : STRIPE COLOR, ACCENT, TWO TONE, SILVER/RED (91) 71F : COVERING COLO, FLOOR MAT, MAROON (91) 71I : INTERIOR TRIM, MAROON (91) 710 : MOLDING COLOR, RED (91) 8UZ : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 71T : TOP COLOR, RUBY RED (93) 71U : PRIMARY COLOR, EXTERIOR, RED ORANGE (91) 712 : TRIM COMBINATION, LEATHER, MAROON (2) (91) 719 : SEAT BELT COLOR, MAROON (91) 72A : STRIPE COLOR, ACCENT, MED GARNET RED (91) 72B : TRIM COMBINATION, CLOTH, DK CARMINE (B) 72C : TRIM COMBINATION, CLOTH, DK CARMINE (C) 72D : TRIM COMBINATION, CLOTH, DK CARMINE (D) 72E : TRIM COMBINATION, CLOTH, DK CARMINE (E) 72F : COVERING, COLOR FLOOR MAT, DK CARMINE (91) 72G : TRIM COMBINATION, CLOTH, DK CARMINE (G) 72H : TRIM COMBINATION CLOTH, DK CARMINE (H) 72I : INTERIOR TRIM, DK CARMINE (91) 72L : SECONDARY COLOR, EXTERIOR, MED GARNET RED MET (91) 72N : TRIM COMBINATION VINYL, DK CARMINE (N) 72P : WHEEL COLOR, MED GARNET RED MET (91) 72Q : MOLDING COLOR, MED GARNET RED MET (91) 72R : TRIM COMBINATION, VINYL, DK CARUINE (R) 72T : TOP COLOR, MED GARNET RED MET (91) 72U : PRIMARY COLOR, EXTERIOR, MED GARNET RED MET (91) 72V : TRIM COMBINATION, VINYL, DK CARMINE (V) 72W : TRIM COMBINATION, VINYL, DK CARMINE (W) 72Y : TRIM COMBINATION, VINYL, DK CARMINE (Y) 72Z : TRIM COMBINATION, VINYL, DK CARMINE (Z) 722 : TRIM COMBINATION, LEATHER, DK CARMINE (2) (91) 723 : TRIM COMBINATION, LEATHER, DK CARMINE (3) (91) 724 : TRIM COMBINATION, LEATHER, DK CARMINE (4) 726 : TRIM COMBINATION, LEATHER, DK CARMINE (6) 729 : SEAT BELT COLOR, DK CARMINE (9) (91) 73A : STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/CARMINE 73B : TRIM COMBINATION, CLOTH, FLAME RED (B) (91) 73C : TRIM COMBINATION, CLOTH, FLAME REO (C) (91) 73F : COVERING COLOR, FLOOR MAT, FLAME RED (91) 73I : INTERIOR TRIM, FLAME RED (I) (91) 73U : PRIMARY COLOR ,EXTERIOR, YELLOW RED MET (91) 732 : TRIM COMBINATION, LEATHER, FLAME RED (2) (91) 733 : TRIM COMBINATION, LEATHER, FLAME RED (3) (91) 734 : TRIM COMBINATION, LEATHER. FLAME RED (4) (91) 739 : SEAT BELT COLOR, FLAME RED (91) 74A : STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED (91) 74I : INTERIOR TRIM , CARMINE (I) 74L : SECONDARY COLOR, EXTERIOR, FLAME RED MET (91) 74Q : MOLDING COLOR, FLAME RED MET (91) 74T : TOP COLOR, FLAME RED MET (91) 74U : PRIMARY COLOR, EXTERIOR, VICTORY RED (91) 742 : TRIM COMBINATION, LEATHER, CARMINE (2) 744 : TRIM COMBINATION, LEATHER, DK CARMINE (4) SSV 75A : STRIPE COLOR ACCENT, RED (91) 75B : TRIM COMBINATION, CLOTH, BORDEAUX RED (B) (93) 75F : COVERING, COLOR FLOOR MAT, BORDEAUX RED (94) 75G : TRIM COMBINATION, CLOTH, BORDEAUX RED (G) (93) 75I : INTERIOR TRIM, BORDEAUX RED (93) 75L : SECONDARY COLOR, EXTERIOR, BRILLIANT RED BET (91) 75Q : MOLDING COLOR , BRILLIANT RED MET (91) 75U : PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91) 752 : TRIM COMBINATION, LEATHER, BORDEAUX RED (2) (93) 753 : TRIM C0MBINATION, LEATHER, BORDEAUX RED (3) (93) 754 : TRIM COMBINATION, LEATHER, BORDEAUX RED (4) (94) 759 : SEAT BELT, COLOR, B0RDEAUX RED (93) 76A : STRIPE COLOR, ACCENT, DK GARNET RED (91) 76L : SECONDARY COLOR, EXTERIOR, DK GARNET RED MET (91) 760 : MOLDING COLOR, DK GARNET RED MET (91) 76T : TOP COLOR DK, GARNET RED MET (91) 76U : PRIMARY COLOR, EXTERIOR, DK GARNET RED MET (91) 77A : STRIPE COLOR, ACCENT, VICTORY RED t92) 77B : TRIM COMBINATION, CLOTH, DK MAPLE tB) 77C : TRIM COMBINATION, CLOTH, DK MAPLE (C) 77D : TRIM COMBINATION, CLOTH, DK MAPLE (D) 77E : TRIM COMBINATION, CLOTH, DK MAPLE (E) 77G : TRIM COMBINATION, CLOTH, DK MAPLE (G) 77H : TRIM COMBINATION, CLOTH, DK MAPLE (H) 77I : INTERIOR TRIM, DK MAPLE (I) 77L : SECONDARY COLOR, EXTERIOR, DARK CHERRY MET (92) 77Q : MOLDING COLOR, DK MAPLE RED MET 77T : TOP COLOR, DK CHERRY MET (92) 77U : PRIMARY COLOR, EXTERIOR, DARK CHERRY MET (92) 77V : TRIM C0MBINATION, VINYL, DK MAPLE (V) 77W : TRIM C0MBINATION, DK MAPLE (W) 772 : TRIM COMBINATION, LEATHER, DK MAPLE (2) 773 : TRIM C0MBINATION, LEATHER, DK MAPLE (3) 774 : TRIM COMBINATION, LEATHER, DK MAPLE (4) 78A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK RED (92} 78B : TRIM C0MBINATION, CLOTH, GARNET RED (B) (91) 78C : TRIM COMBINATION, CLOTH, GARNET RED (C) (91) 78D : TRIM C0MBINATION, CLOTH, GARNET RED (D) (91) 78E : TRIM COMBINATION, CLOTH, GARNET RED (E) (91) 78F : COVERING COLOR, FLOOR MAT, GARNET RED (91) 78G : TRIM COMBINATION, CLOTH, GARNET RED (G) (91) 78H : TRIM COMBINATION, CLOTH, GARNET RED (H) (91) 78I : INTERIOR TRIM, GARNET RED (91) 78J : TRIM COMBINATION, CLOTH, GARNET RED (J) (91) 78L : SECONOARY COLOR, EXTERIOR, DK YELLOW RED MET (91) 78X : MOLDING COLOR, DK RED (91) 78T : TOP COLOR, DK MAPLE, RED MET (91) 78U : PRIMARY COLOR, EXTERIOR, DK YELLOW RED MET (91) 782 : TRIM COMBINATION, LEATHER, GARNET RED (2) (91) 783 : TRIM COMBINATION, LEATHER, GARNET RED (3) (91) 784 : TRIM COMBINATION, LEATHER, GARNET RED (4) (91) 785 : TRIM C0MBINATION, LEATHER, GARNET RED (5) (91) 786 : TRIM COMBINATION, LEATHER, GARNET RED (6) (92) 788 : TRIM COMBINATION, CLOTH, GARNET RED (B) (92) 789 : SEAT BELT COLOR, GARNET RED (91) 79A : STRIPE COLOR, ACCENT, DK CLARET (91) 798 : TRIM COMBINATION, CLOTH, RUBY RED (B) (93) 79C : TRIM COMBINATION, CLOTH, RUBY RED (C) (93) 79D : TRIM COMBINATION, CLOTH, RUBY RED (D) (93) 79E : TRIM COMBINATION, CLOTH, RUBY REO (E) (93) 79F : COVERING COLOR, FLOOR MAT, DK CLARET (1989 PASS D) 79G : TRIM COMBINATION, CLOTH, RUBY RED (G) (94) 79H : TRIM COMBINATION, CLOTH, DK CLARET (H) 79I : INTERIOR TRIM, RUBY RED (93) 79J : TRIM COMBINATION, CLOTH, RUBY RED (J) (93) 79N : TRIM COMBINATION, VINYL, DK CLARET (N) 79R : TRIM COMBINATION,VINYL, DK CLARET (R) 79U : PRIMARY COLOR, EXTERIOR, BURGUNDY MET (91) 79V : TRIM COMBINATION, VINYL, DK CLARET (V) 79W : TRIM COMBINATION, VINYL, DK CLARET (W) 792 : TRIM COMBINATION, LEATHER, RUBY RED (2) (93) 793 : TRIM COMBINATION, LEATHER, RUBY RED (3) (93) 794 : TRIM COMBINATION, LEATHER, RUBY RED (4) (94) 799 : SEAT BELT COLOR, RUBY RED (93) 8A3 : GENERATOR, 124 AMP, CS144 8A8 : TACHOMETER, 8B2 : MIRROR O/S, RH & LH, WIDELOOP, PAINTED 8B3 : COOLANT, ETHELENE GLYCOL) (-34 DEGREES) 8B5 : RADIO PROVISIONS, INSTALLATION 8B7 : HOSE, RADIATOR & HEATER (SPECIAL) 8B8 : ODOMETER, SPECIAL INSTRUMENT CLUSTER 8C5 : JACK, C9 ELECTRICAL OUTLET 8C9 : SEAT, FRT/LAP & SHOULDER BELT DELETE 8D2 : FUEL, ADDITIONAL (I GAL) 8D5 : HEADLAMPS, SINGLE RECTANGULAR ASSIST 8D6 : REINFORCEMENT, RR FRAME RAIL 8.0 : FUEL, ADDITIONAL - 3 GALLONS 8.0 : SEAT, DELETION, FRONT 8.0 : BUMPER RR, PAINTED 8.0 : BUMPER FRT, PAINTED 8F1 : FUEL, ADDITIONAL TWO GALLONS 8F4 : BUMPER RR, STEP 8GB : LAMP, PASSENGER-DOME 8G9 : MIRROR O/S, RH & LH, WIDELOOP, STAINLESS 8H1 : INSULATION, EXTRA-FLOOR 8H3 : FLOOR, 3/4' PLYWOOD UNION CITY BODY 8H5 : BUMPER FRT, DELETE 8H9 : FLASHER, HEAVY DUTY TURN SIGNAL 8K3 : SPEAKER SYSTEM, RADIO, INSTRUMENT PANEL 8M3 : SWITCH, DOME LIGHT, R . H . DOOR OPERATED 8M5 : BUMPER FRT, PAINTED, BLACK, WRAP AROUND 8M7 : HEADLAMPS, SUBSTITUTION 8MB : HANDLE, I EA ON INSIDE OF RR HANDLES 8M9 : HANDLE, I EA MOUNTED INSIDE OF DOOR 8N1 : SALES PACKAGE, COLD CLIMATE, DIESEL USED WITH 8N4 : SPEAKER SYSTEM, INSTRUMENT PANEL (COAXIAL) 8N9 : SPEAKER, RDO DELETE 8P3 : INDICATOR, TRANSMISSION FLUID 8P5 : WINDOW, PARTITION 13 X 18 INCH 8P6 : BUMPER RR, SPECIAL PAINT 8Q2 : VENT, STATIC TYPE ROOF 8Q5 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS 8Q7 : VENT, ADSCO, ROOF (DRIVERS COMPARTMENT#10540) 8Q9 : VENT, ROOF ADSCO-EVANS(STATIC) (#S999) 8R6 : FUEL, SENDER ASM, HIGH TEMP 8R9 : CONTAINER, INSTRUMENT ADSCO(SEARS) (#5969) 8S4 : MIRROR O/S, LH 6 RH, WEST COAST TYPE, LARGE, W/6 IN 8S9 : CHASSIS, SPECIAL, UTILITY 80DY 8U4 : HEATER ENG, BLOCK (SEO) 8W5 : GENERATOR, 105 AMP 8W7 : SEAT, BUCKET TYPE, DRIVER & PASS, LOW BACK FRT 8W9 : SPRING, FRONT SUSPENSION 8X4 : PARTITION, PLYWOOD, W/CTR SLIDING DOOR 8X7 : SHOCK ABSORBERS, FRT & RR, GAS PRELOADED, DELCO/BILS 8X8 : VANITY, MAINTAINENCE (OPER SI CARGO DOOR) ADSCO(#6135 8Z1 : ENGINE, DELETE 8Z2 : TRANSMISSION, DELETE 8Z3 : GENERATOR, IOO AMP, HEAVY DUTY, PENSKE/RYDER 8Z5 : CAP, METAL VALVE STEM 80A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE 80B : TRIM COMBINATION, CLOTH, SAND (B) 80C : TRIM COMBINATION, CLOTH, SAND (C) 80D : TRIM COMBINATION, CLOTH, SAND (D) 80G : TRIM COMBINATION, CLOTH, SAND (G) 80I : INTERIOR TRIM, SAND (I) 80Q : MOLDING COLOR, MED QUASAR BLUE MET (91) 80U : PRIMARY COLOR, EXTERIOR, MED QUASAR BLUE MET (91) 81A : STRIPE COLOR, ACCENT, TWO TONE, RED/BLACK (91) 81P : WHEEL COLOR, BRIGHT RED (91) 81Q : MOLDING COLOR, BRIGHT RED (91) 81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91) 82A : STRIPE COLOR, ACCENT, LT SAPPHIRE TITANIUM (91) 82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91) 82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91) 82D : TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 ) 82E : TRIM COMBINATION, CLOTH, MED DK GRAY (E) (91) 82F : COVERING COLOR, FLOOR MAT, MED DK GRAY (91) 82G : TRIM COMBINATION, CLOTH, MED DK GRAY (G) (91) 82H : TRIM COMBINATION, CLOTH MED DK GRAY (H) (91) 82I : INTERIOR TRIM, MED DK GRAY (91) 82J : TRIM COMBINATION, CLOTH, MED DK GRAY (J) (91) 82L : SECONDARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM 82N : TRIM COMBINATION, VINYL, DK MED GRAY (N) 82Q : MOLDING COLOR, LT SAPPHIRE TITANIUM (91) 82R : TRIM COMBINATION, VINYL , DK MED GRAY (R) 82T : TOP COLOR, LT SAPPHIRE TITANIUM (91) 82U : PRIMARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM (91) 82V : TRIM COMBINATION, VINYL, DK MED GRAY (V) 82W : TRIM COMBINATION, VINYL, DK MED GRAY (W) 82Y : TRIM COMBINATION, VINYL, DK MED GRAY (Y) 82Z : TRIM COMBINATION, VINYL, DK MED GRAY (Z) 821 : INTERIOR TRIM (DARK MEDIUM GRAY) 822 : TRIM COMBINATION, LEATHER, MED DK GRAY (2} (91) 823 : TRIM COMBINATION, LEATHER, MED DK GRAY (3) (91) 826 : TRIM COM8INATION, LEATHER, DK MED GRAY (6) 829 : SEAT BELT COLOR, MED DK GRAY (91) 83A : STRIPE COLOR, ACCENT, TWO TONE, GUNMETAL/GARNET RED 83L : SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM 83Q : MOLDING COLOR , MED SAPPHIRE BLUE FM (91) 83T : TOP COLOR, MED SAPPHIRE BLUE FM (91) 83U : PRIMARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM (91) 84L : SECONDARY COLOR, EXTERIOR, HAWAIIAN ORCHID (92) 84P : WHEEL COLOR GRAY (91) 84Q : MOLDING COLOR, HAWAIIAN ORCHID (92) 84U : PRIMARY COLOR, EXTERIOR HAWAIIAN ORCHID (92) 85A : STRIPE COLOR, ACCENT, MED SLATE GRAY (91) 85L : SECONDARY COLOR, EXTERIOR MED SLATE GRAY MET (91) 85P : WHEEL COLOR, MED SLATE GRAY MET (91) 85Q : MOLDING COLOR, MED SLATE GRAY MET (91) 85T : TOP COLOR, MED SLATE GRAY MET (91) 85U : PRIMARY COLOR, EXTERIOR, MED SLATE GRAY MET (91) 86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91) 86P : WHEEL COLOR, GRAY METALLIC 86U : PRIMARY COLOR, EXTERIOR, WHEATLAND YELLOW (91) 87A : STRIPE COLOR, ACCENT, GUNMETAL MET (91) 87L : SECONDARY COLOR, EXTERIOR GUNMETAL MET (91) 87Q : MOLDING COLOR, GUNMETAL MET (92) 87T : TOP COLOR, GUNMETAL MET (91) 87U : PRIMARY COLOR, EXTERIOR, GUNMETAL MET (91) 88A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91) 88L : SECONDARY COLOR, EXTERIOR, TANGIER ORANGE (91) 88T : TOP COLOR, DK PLUM MET (92) 88U : PRIMARY COLOR , EXTERIOR, TANGIER ORANGE (91) 89A : STRIPE COLOR, ACCENT, TWO TONE, RED/LT GRAY (91) 89U : PRIMARY COLOR, EXTERIOR, AUTUMN MAPLE MET (91) 8NL : COMPUTER SELECTED REAR LEFTHAND SPRING 8UX : COMPUTER SELECTED FRONT LEFTHAND SPRING----(ALONG WITH 6XW/6ZX) 9A4 : SALES PACKAGE, REC VEHICLE, MARK III 9A5 : SALES PACKAGE, REC VEHICLE, DELETION 9A6 : SALES PACKAGE, REC VEHICLE, STARCRAFT 9A7 : SALES PACKAGE, RECREATIONAL VEHICLE 9B8 : MODIFICATION, RYDER TRUCK VEHICLE 9C1 : SEO VEHICLE, POLICE CAR 9C2 : GOVERNOR, ELECTRONIC SPEED SENSOR - 85 MPH 9C6 : SEO VEHICLE, TAXI CAB 9C7 : MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE, 9D2 : RACK, SHELVES, ROLL OUT 9D9 : MIRROR I/S, R/V, DELETION 9F2 : MIRROR O/S, DELETION 9G4 : TIRE REAR, DELETE 2 O/S (SPL ORDER) 9G6 : SWITCH, DOME LAMP, RH RR DR JAMB 9G7 : SWITCH, D0ME LAMP, FRT SIDE CARGO, RR DR JAMB 9H2 : FUEL TANK, DELETION 9H5 : LAMP, DELETION, ROOF MARKER 9H7 : CARRIER SPARE TIRE, WITH HOIST, DELETION 9J4 : BUMPER, RR DELETE 9J6 : STEERING COLUMN, TILT TYPE (SEO) 9J7 : MIRROR AUX O/S, 6.5 X 6 DUAL SPOT, CONVEX 9K3 : AIR CLEANER 'OFF ROAD' PACKAGE 9K6 : RADIO PROVISIONS, AM/FM STEREO RADIO, MISC MOUNTING****** 9K9 : RUSTPROOFING, (OUTSIDE SOURCE) (TROPICAL) (MEETS 9L1 : RUSTPROOFING, (OUTSIDE SOURCE) (MEETS FED STD 297) 9L5 : FUEL SCREEN, ANTI-SYPHON 9L7 : RADIO PROVISIONS, MISC. MOUNTING REQ. 9L8 : RESTRAINT SYSTEM, FRT SEAT, W/DUAL MODE RETRACTOR 9L9 : CYLINDER UNIT, DUAL KEY SYSTEM 9M2 : CYLINDER UNIT, CURTIS BURNS - C0MM0N KEYS 9M3 : COVERING, MAT, RUBBER, STEP WELL 9M6 : SUSPENSION SYSTEM, STEERING MODIFICATION 9NL : COMPUTER SELECTED REAR RIGHTHAND SPRING 9UX : COMPUTER SELECTED REAR RIGHTHAND SPRING 9Q1 : DECAL, ADSCO-SEARS 9Q3 : CONVENIENCE PKG, SPECIAL 9Q4 : SPRING REAR, LOWERED 9Q7 : END GATE, DELETION, ASSEMBLY 9R7 : INTERIOR PACKAGE SEAT RED 9S6 : WIRING PROVISIONS, TAIL LIGHT, HEAVY GAGE 9T1 : DOOR RR, 74 IN STRAP HINGES - UCB 9T2 : DOOR RR, 66 IN OVERHEAD, SLIDING W/WINDOW - UCB 9T3 : PARTITION, SLIDING, PLYWOOD W/CENTER SLIDING WOR - 9T4 : PARTITION, EXPANDED METAL, W/CTR SLIDING WOR - UCB 9T5 : DOOR, RR,60 IN, CTR SLIDING WOR 9T7 : SALES PACKAGE, PLUMBING, HEATING, AND A/C 9T8 : SALES PACKAGE, ELECTRICAL CONTRACTOR 9T9 : SALES PACKAGE, GENERAL SERVICE CONTRACTOR 9U2 : CYLINDER UNIT, CITY OF BOSTON/STATE OF TEXAS - 9U7 : CYLINDER UNIT, HERTZ-PENSKE 9U9 : CYLINDER UNIT, RYDER-COMMON KEYS 9V1 : COLOR, BLACK 9V2 : COLOR, ORANGE 9V4 : COLOR, WHEATLAND YELLOW 9V5 : COLOR, WOODLAND GREEN 9V9 : COLOR, DOESKIN TAN 9W2 : COLOR, POLAR WHITE 9W3 : COLOR, WHEATLAND YELLOW, LEAD FREE 9W4 : COLOR, TANGIER ORANGE, LEAD FREE 9W7 : HEADLAMPS, ON-WARNING SYSTEM 9X5 : TRIM OVERRIDE, CLOTH 90A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91) 90C : TRIM COMBINATION, CLOTH, MED SMOKE GRAY (C) (91) 90E : TRIM COMBINATION, CLOTH, MED SMOKE GRAY (E) (91) 90I : INTERIOR TRIM, MED SMOKE GRAY (91) 90L : SECONDARY COLOR, EXTERIOR, GRAY MET (91) 90U : PRIMARY COLOR, EXTERIOR, GRAY MET (91) 90V : TRIM COMBINATION, VINYL , MED SMOKE GRAY (91) 903 : TRIM COMBINATION, LEATHER, MED SMOKE GRAY (3) (91) 909 : SEAT BELT COLOR, MED SMOKE GRAY (91) 91L : SECONDARY COLOR, EXTERIOR, DK POLO GREEN MET (91) 91Q : MOLDING COLOR, DK POLO GREEN MET (91) 91T : TOP COLOR, DK POLO GREEN MET (91) 91U : PRIMARY COLOR, EXTERIOR, DK POLO GREEN MET (91) 92U : PRIMARY COLOR, EXTERIOR, DAWN GRAY MET (91) 93Q : MOLDING COLOR, WHITE DIAMOND (91) 93U : PRIMARY COLOR, EXTERIOR, WHITE DIAMOND (91) 94B : TRIM COMBINATION, CLOTH, LT QUARTZ (B) 94C : TRIM COMBINATION, CLOTH, LT QUARTZ (C) 94L : SECONDARY COLOR, EXTERIOR, BLUE RED MET (91) 94U : PRIMARY COLOR, EXTERIOR, BLUE RED MET (91) 942 : TRIM COMBINATION, LEATHER, LT QUARTZ (2) 943 : TRIM COMBINATION, LEATHER, LT QUARTZ (3) 95L : SECONDARY COLOR, EXTERIOR, LT ANTELOPE FM (91) 95O : MOLDING COLOR, LT ANTELOPE FM (91) 95T : TOP COLOR, LT ANTELOPE FM (91) 95U : PRIMARY COLOR EXTERIOR, LT ANTELOPE FM (91) 96L : SECONDARY COLOR, EXTERIOR, DK SMOKE GRAY MET (91 ) 96T : TOP COLOR, DK DRIFTWOOD MET (92) 96U : PRIMARY COLOR, EXTERIOR, ULTRA SILVER MET (91) 97A : STRIPE COLOR, ACCENT, TWO TONE, WARM GRAY MET/DK 97K : AUX TOP COLOR, DK GRAY (91) 97L : SECONDARY COLOR, EXTERIOR, DK GRAY MET (91) 97U : PRIMARY COLOR, EXTERIOR, DK GRAY MET (91) 98K : AUX TOP COLOR, BLACK SAPPHIRE (91) 98L : SECONDARY COLOR, EXTERIOR, VERY DK SAPPHIRE MET 98U : PRIMARY COLOR, EXTERIOR, ULTRA BLUE MET (91) 99A : STRIPE COLOR, ACCENT, DK SLATE GRAY (91) 99B : TRIM COMBINATION, CLOTH, BLK CHERRY (B) 99C : TRIM COMBINATION, CLOTH, BLK CHERRY (C) 99D : TRIM COMBINATION, CLOTH, BLK CHERRY (D) 99E : TRIM COMBINATION, CLOTH, BLK CHERRY (E) 99G : TRIM COMBINATION, CLOTH, BLK CHERRY (G) 99H : TRIM COMBINATIDN, CLOTH, BLK CHERRY (H) 99I : INTERIOR TRIM, BLK CHERRY (I) 99L : SECONDARY COLOR, EXTERIOR , DK SLATE MET (91 ) 99Q : MOLDING COLOR, DK SLATE GRAY MET (91) 99T : TOP COLOR, DK SLATE GRAY MET (91) 99U : PRIMARY COLOR, EXTERIOR, DK SLATE MET (91) 992 : TRIM COMBINATION, LEATHER, BLK CHERRY (2) 993 : TRIM COMBINATION, LEATHER, BLK CHERRY (3) ILC : TRIM- INTERIOR DESIGN IL2 : TRIM- INTERIOR DESIGN U18 : SPEEDOMETER, INSTRUMENT PANEL (KILOMETER) 7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XN : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND YS1 : SEAT,RR CUST 8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 8NN : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 7XM : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XR : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XS : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XT : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 8UX : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 8UY : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 1SA : Option Package 01 1SB : OPTION PACKAGE 02 1SD : OPTION PACKAGE 04 1SE : OPTION PACKAGE 05 19Q : MOLDING COLOR (BLACK) 37U : EXTERIOR COLOR, PRIMARY (DARK BRIGHT TEAL METALLIC) (92) 6DB : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XM : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XN : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XR : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XS : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XT : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XU : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6XY : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6ZY : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 6ZZ : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND 7XU : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7XY : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 7ZY : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND 8UZ : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 8WA : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 8YB : SPRING, COMPUTER SELECTED, REAR, LEFT HAND 9NB : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9NN : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9UX : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9UY : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9UZ : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9WA : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 9YB : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND AH3 : ADJUSTER, 4-WAY MANUAL, DRIVER SEAT A4G : OVERRIDE CANADIAN REQUIREMENTS Last edited by ncso911; 10-19-2005 at 07:24 PM. |
