Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-19-2005, 02:49 PM
Skylar_Epperson Skylar_Epperson is offline
My 84 Crown Vic LTD's lifters are knocking NEED HELP
My vic's lifters started knockin so i stopped driving it. When we took off the valve cover and turned her on, no oil spryed out, so i went out and bought a oil pump, will this hopefully fix the problem, if not what WILL!!
Old 10-19-2005, 03:36 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: My 84 Crown Vic LTD's lifters are knocking NEED HELP
I answered your private message but I would also get a manual oil prssure gauge hooked up on it and see if you have any oil pressure.
The old squirt out lifter is not a very good check.
What engine and have you heard any rod or main bearing thumping in it?
If the motor is sludged up bad or if you have put any cleaner additive in it your oil pump screen may be clogged up.
And possiable twisted or stripped oil pump shaft.
What kind of oil filter does it have on it?
MT-2500
Old 11-14-2005, 03:51 PM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
the first thing i would do would be to adjust your rockers
[/IMG]
