Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-19-2005, 09:57 AM
sprayedlude93 sprayedlude93 is offline
Send a message via AIM to sprayedlude93
95 vtec head on a 00 block
I am about to swap my 95 obd1 h22a head on my new 2000 h22a4 block. I have a few questions first. I am going to be taking the head this weekend to get a complete redo and mil'd. Then once I get it back I will be putting it on the a4 block. Now since there were diffrence with internals to produce more power in the 93-96 vtec and 97-01 vtec, do I have to get the head worked to certain spec? Also are there any problems that I might potentially run into?
<just a thought>
I want to put a set of new h22 type S piston on this block that I have in my gerage before I slap the head on. Now that's going to bump up the compression quite a bit. Is the 11:1 compression good for every day driving or will I have problem. I understand that with the std h22a type S pistons that they should just bolt right up to the stock rods etc., but when I slap the head on will I have any issues?
thanks alot in advance for any and all help........
Old 10-19-2005, 05:33 PM
AllmotorBB6 AllmotorBB6 is offline
Re: 95 vtec head on a 00 block
it depends on how much you mill the head. I would clay the pistons to make sure the clearance was good. Just put the head on there. There's no spec to be done.
Considering the type S pistons came factory in the type S prelude, i would think that it is perfect for DD.
Old 10-19-2005, 06:15 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Yep, you shouldn't have any problems.
And yeah, those pistons will be fine...just use good gas.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 10-20-2005, 12:28 AM
so no issues with the high compression since it will be a daily driver and i can use the h22a4 stock connecting rods ?
thanks to you both
Old 10-20-2005, 12:29 AM
o and whats the diffrence between the type S std pistons and the type S over sized? please let me know b/c theres 2 types. I have the std..
