Old 10-18-2005, 10:58 PM
mxrider4ac mxrider4ac is offline
need some help.
Alright. I just had a new ECU put in my car. It cut off on me while i was driving it a couple weeks ago and wouldnt start back up. The shop replaced they ECU. They said that they didnt know of anything else it could be. It has been running fine. It hasnt cut off and not started back up yet. The only problem I am having is that when i push in the clutch to stop at a stop sign or something the rpms drop so low that the car almost cuts off. the lights on the dash come on it goes so close to cutting off. The idle has also seemed kinda sporatic. it idles higher sometimes and it might go down and the go back up and then go down and settle. i was thinking maybe it needs a new IAC. i'm not really sure though. I hate to buy a new IAC and it not fix it. anybody have any ideas about what the problem could be?
Thanks,
Mods:
K&N FIPK
Accel 8mm Wires
Custom Exhaust
N1 Muffler
Old 10-19-2005, 01:12 AM
AutostradaVR4 AutostradaVR4 is offline
Re: need some help.
maybe when your ecu went it somehow fucked your timing...? Possibly torqued on the timing belt somehow? Sporratic idle can happen if the timing belt is too loose(speaking from experience). Check the tensioner.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-19-2005, 07:20 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: need some help.
Yeah, that sounds to me like an IAC, mine started doing that after I fixed my TPS sensor... though I haven't changed my IAC, b/c my car isn't running right now... but I'd suggest getting that checked... Ebay will be a good place to find one cheap... you can even get one from a DSM...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-19-2005, 07:40 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: need some help.
Try cleaning the IAC before replacing. It may just be gunked up.
Old 10-19-2005, 09:14 AM
Mikelb's Avatar
Re: need some help.
I wanted to suggest that, but I didn't know if it was possible, and/or what to use... I figured that I'd look less stupid with my mouth closed... lol
Old 10-19-2005, 10:07 AM
Re: need some help.
i guess i'm gonna change the IAC. Damn car is really starting to piss me off. It stopped running right almost a month ago. now 3 weeks and $700 later it still aint running right. I'm running out of money.
Mods:
K&N FIPK
Accel 8mm Wires
Custom Exhaust
N1 Muffler
Old 10-19-2005, 02:56 PM
Re: need some help.
So are yall pretty sure its the IAC....I am out of ideas about this thing. I just wanna get it fixed. I want as many opinions as i can get about what it might be. Thanks for the help.
Mods:
K&N FIPK
Accel 8mm Wires
Custom Exhaust
N1 Muffler
Old 10-19-2005, 03:14 PM
Mikelb's Avatar
Re: need some help.
I'm leaning towards the IAC... b/c that's a common problem... I'm not able to tell you straight up... as I'm no mechanic, but opinions from car owners can usually be just as right... and IMHO I'd say the IAC... use some intake cleaner/carb cleaner... and see if that helps first
Old 10-19-2005, 04:31 PM
Beef66 Beef66 is offline
most likely IAC...same problem i had, but on a side note did you check your MAS to make sure its connected snug?
Old 10-19-2005, 10:39 PM
Re: need some help.
yea..i checked the MAS...i talked to a really good mechanic and he says he thinks it is the IAC too. He said if i wanted to though that he would put it on diagnostics just to make sure.
Mods:
K&N FIPK
Accel 8mm Wires
Custom Exhaust
N1 Muffler
Old 10-20-2005, 07:51 AM
Mikelb's Avatar
Re: need some help.
that'd be a good idea,
