Old 10-18-2005, 10:51 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Differeces between
Whats the differences betwenn ls1 ls2 and ls7?
Old 10-18-2005, 11:03 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Horsepower, and cubic inches.
Old 10-18-2005, 11:04 PM
Is eating.
Im sure there's alot more differences between them, BUT I havent been able to read up on like a book, about all the LsX engines, if I had one, I would read that thing.
Old 10-18-2005, 11:09 PM
Matt365's Avatar
Re: Differeces between
i knew the hp part i jus want to know the other specs, primarily i want to know if i can change a ls1 into a ls7 by boreing it or changing bolt ons etc
Old 10-18-2005, 11:13 PM
Is eating.
Well I think that an Ls1 is like 346 ci.. (I THINK) and I know that an Ls7 is a 427. So.. dont think so.
Old 10-18-2005, 11:26 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
*hijacks
Is an LT4 from a grand sport vette on par with a stock LS1?
and what's the difference with an LT4 and an LT1 with LT4 heads?
Old 10-19-2005, 03:04 AM
Morley Morley is offline
LS1 & LS2 are considered 350's, the differences are in the internals and the electronics. The LS7 is 427 cid...the differences are too many to list.
here is a little blurb from GM about it...cylinder heads with computer numerical control (CNC) intake and exhaust ports and combustion chambers - which creates ports with surgical accuracy for maximum power production. In addition, the intake valves and connecting rods are made out of high-strength lightweight titanium. The LS7 engines are assembled by hand at GM Powertrain's new Performance Build Center
Pressed-in steel cylinder liners give a 4.125-inch bore and a 4.00-inch stroke, for a displacement of 7-liters, or 427 cubic inches.
precision-balanced forged steel crankshaft
dry-sump oiling system
LS1 vs Lt4...LS1 has more power and more up to date electronics.
LT1 with LT4 heads vs a true LT4...LT4 has more power, different cam and again..electronics.
Old 10-19-2005, 01:37 PM
kahjdh's Avatar
kahjdh kahjdh is offline
what is an lt4?
Old 10-19-2005, 03:07 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
the super version of the lt1
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-19-2005, 03:22 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
don't forget,
LT4= 4-bolt mains
LT1= 2-bolt mains
the LT4 intake manifold is also slightly more ported than a LT1...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-19-2005, 04:52 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
LS1 is 346 cubic inches. 5.7L 3.898 bore, 3.622 stroke
LS6 is 346 cubic inches. 5.7L 3.898 bore, 3.622 stroke
LS2 is 364 cubic inches. 6.0L 4.005 bore, 3.622 stroke
LS7 is 427 cubic inches. 7.0L 4.125 bore, 4.000 stroke
The blocks are all fairly similar. All aluminum, all Gen III styled. Just looking at them, there are few differences.
Internals and heads are what make the difference in power. For the most part.
There is obviously more time spent on the LS7.
All are basicly brothers to the LS1.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 10-19-2005, 04:56 PM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
the LS7 just being the bigger brother than you dont wanna mess with...
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 10-19-2005, 05:04 PM
Is eating.
Whats car has the LS6?
Old 10-19-2005, 05:06 PM
Mr. Luos's Avatar
Firebird Guy
Corvette C5 Z06.
Some performance Caddy's got them as well.
Stock'ish'
Old 10-19-2005, 05:18 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
and if you are asking for the next the 2006 z06 c6 has the ls7
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
