Old 10-18-2005, 09:31 PM
Mglai1987 Mglai1987 is offline
what glue do u use for the windows??
i heard people use Krystal Klear but i cant find it anywhere... is there a store that sells this?
Old 10-18-2005, 09:36 PM
Vric's Avatar
Vric Vric is offline
Re: what glue do u use for the windows??
White Glue. 100% clear, don't fog, and if you do mistake, it's water washable.
Old 10-18-2005, 10:17 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Alene's Tacky Glue/Super Tacky Glue. It's basically white glue but it bonds very well and remains slightly flexible. It's about a buck at craft stores.
I actually use it elsewhere, including to 'tack weld' my models together to check fit and proportions. It's probably strong enough to use permanantly in places where it won't be seen: A single dot on each of three attachment points in a Datsun Safari rally car and I could pick up the whole chassis (With white metal wheels) by the roll cage.
Old 10-18-2005, 10:43 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
super glue
j/k
Old 10-18-2005, 10:49 PM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
I use testors window glue?
Works like a charm
Old 10-19-2005, 03:05 AM
klutz_100's Avatar
try this :
It's a jeweller's/watchmaker's cement. Dries very strong in about 5 minutes, dries clear and doesn't fog clear parts. Tube has built-in needle for application.
HTH
PS Got mine on ebay
Old 10-19-2005, 06:33 AM
ZoomZoomMX-5's Avatar
Hobby shops should carry Micro Krystal Klear or Formula 560 Canopy Glue; both are thicker/much stronger variations of standard white glue which dries too soft and not strong enough for much of any handling. I use Formula 560 all the time, I also use it to attach clear lenses and external trim items; any excess wipes off and cleans up w/water before it dries. Same goes for 5 minute epoxy, but that's a bit of overkill for glass, but great for side mirrors. It sometimes yellows w/age though.
And as for superglue, I do use it sometimes to install glass but I'm very careful w/it and where it's applied-I sometimes use it to tack the glass in place before applying a bead of Formula 560 around the perimeter to seal the glass in place. Not recommended if you are inexperienced.
My Fotki Album
Old 10-19-2005, 07:32 AM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
Originally Posted by klutz_100
try this :
I use the same stuff. Works great, really strong too. You can also get it from Micro-Mark and I've bought it a Michaels Craft store.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Old 10-19-2005, 02:48 PM
WasteGas's Avatar
WasteGas WasteGas is offline
Re: Re: what glue do u use for the windows??
Works like a charm
100%
