Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-18-2005, 10:12 PM
Ramblin Fever Ramblin Fever is offline
Are all 4 O2 sensors the same?
on the 97 V6?
I found all 4, finally - does it take specific tools to remove/replace these sensors?
Do I need to disconnect the battery?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 10-18-2005, 10:30 PM
Cat Fuzz Cat Fuzz is offline
An easy way to find out is to call up a parts store and ask them to look them up. If they are different, they will be able to tell you.
They do make O2 sensor sockets, its a good idea to use one.
Yes, its usually a good idea to disconnect the battery when working with anything electrical.
Old 10-18-2005, 11:59 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: Are all 4 O2 sensors the same?
Originally Posted by Ramblin Fever
on the 97 V6?
Yes.
22 mm wrench or O2 sensor (slotted) socket.
No.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 10-19-2005, 12:53 AM
It's actually THAT simple??
Just pop the old one's out and put new one's in? WOW!
Nothing on this truck has ever been that easy.
Do I need to have the codes cleared - or will it clear automatically?
1997 3.2L V6 Rodeo
Old 10-19-2005, 06:28 AM
rodeo02 rodeo02 is offline
All 4 oxygen sensors are the same p/n on your 1997 3.2L. You will need an oxygen sensor socket to r/r them and they will be in there VERY tight. You may even need heat and/or penetrating oil. You unplug the wire connector slip the slotted socket over them and r/r them much like a sparkplug. I bought the 3pc tool kit from oxygensensors.com It worked out real well. Why are you replacing all 4!!!! or any of them for that matter? What was the code? Don't waste your time & $$ changing out the sensors downstream of the cats!!!!!!! They don't do a thing but tell you if the cats work or not. The downstreamers dont manage air/fuel ratio at all. You should only replace an oxygen sensor on a 1996+ if you are getting a slow or no activity code from them, or a heater circuit malfuntion. Any other codes likely has nothing to do with the O2 sensor itself.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-19-2005, 07:09 AM
Re: Re: Are all 4 O2 sensors the same?
The code should clear automatically after a certain number of "cycles" or you can clear it by pulling the 15A ECM fuse, in the engine compartment fuse/relay box, for 30 seconds or so.
2007 Honda CR-V
Old 10-19-2005, 11:49 AM
The guy didn't give me the code - mainly cause I forgot to right it down.
But he said something along the line of 1 of 2 & 2 of 2.
To be honest, that Check engine light came on 10 minutes before I had to pick up one of the kids from school and I just happened to be right next to an Autozone.
I'm going back tonight to double check the code - but the guy said it was definitely an O2 sensor. And they've never been replaced, so it doesn't surprize me really.
To be honest, when I found out how cheap they were - for this particular year, anyway - and that they were so easily accessible, there's no reason not to do all 4 of them.
I ordered the Walker brand, and $190 for all 4 with overnight shipping - can't complain.
I'm sure I'll have more questions when they arrive - THANK
you greatly for your help.
1997 3.2L V6 Rodeo
Old 10-19-2005, 12:10 PM
The guy didn't give me the code - mainly cause I forgot to right it down. ...
To be honest, when I found out how cheap they were - for this particular year, anyway - and that they were so easily accessible, there's no reason not to do all 4 of them....
Ramblin, I give up!
Oh well.. good luck with it!
Joel
Old 10-19-2005, 12:29 PM
Re: Re: Re: Are all 4 O2 sensors the same?
Originally Posted by rodeo02
Ramblin, I give up!
Joel
Yeah, I know, I was complaining initially that I didn't have the money - but I also don't have the time for down time or vehicle doubt either. This is the only vehicle we have for daily commuting and we can't afford any days lost at work either.
Not only that we were calculating just how much MORE gas this truck has been using lately - and it's been quite a bit, so we speculated something was coming, just didn't know what.
If I made the wrong move, I'm sure the truck'll let me know. Otherwise, you can't really fault one if that's their only vehicle.
1997 3.2L V6 Rodeo
Old 10-24-2005, 01:25 PM
ing_erika ing_erika is offline
Send a message via Yahoo to ing_erika
on the 97 V6?
Hey, were did you found the 4 sensors, I haven't found them yet ! I need to change only one, (1,1) I read on another post that is on the passengers side.
Egm
Old 10-24-2005, 01:59 PM
Egm
Bank 1 Sensor 1 is located on the passenger's side between the exhaust manifold and the passenger's side catalytic converter (if you have an auto) if you have a 5 spd it is between the exhaust manifold that the flex pipe.
2007 Honda CR-V
Old 10-27-2005, 06:05 PM
Ok, I just found them, but one last question, which sensor is the one making the truck waste a lot of gas ? is it before or after the catalityc converter ????
Egm
Old 10-27-2005, 06:12 PM
Re: Re: Re: Re: Are all 4 O2 sensors the same?
Egm
Before.
The After-Cat sensors monitor Catalytic converter efficiency.
2007 Honda CR-V
Old 10-27-2005, 06:26 PM
Re: Re: Re: Re: Re: Are all 4 O2 sensors the same?
Before.
I'm down the truck and I can see the catalytic converter, is has 3 sensors on a side and one sensor in the other side, the before-cat sensor is the one alone right ??? the 3 left are after-cat ... ?
Egm.
Old 10-27-2005, 06:54 PM
Re: Re: Re: Re: Re: Re: Are all 4 O2 sensors the same?
Egm.
I figure it out now ! ! ! stdr has only 3 sensors, I know which one has to be changed now ! thanks a lot for your helpppp. ! !
Egm
