Old 10-18-2005, 07:26 PM
molsonbrador molsonbrador is offline
fan speed switch
have 99 silverado. recently lost speed 5 in fan switch. now have only speed 3 & 4. air and heat work fine as do the flow directers.
looked at control box, switch 'seems' okay.
any help?
Old 10-18-2005, 08:32 PM
2000CAYukon 2000CAYukon is offline
Re: fan speed switch
Probably the resistor pack. AC Delco 15-8770.
//2000CAYukon
Old 10-18-2005, 09:50 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Personally, I would think it is the contact on position 5 in the HVAC controls either burned or broken off
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-18-2005, 10:35 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
I agree with the resistor theory. At speed 5, the most current is flowed to the fan through the resistor. GM's have high current blower motors, so it is not uncommon to have one go out. You should be able to test with a meter at the fan if current drops out at the high speed, but current is at the high speed switch, that means you lose current at the resistor. Vwala!! Change it out
Old 10-19-2005, 01:00 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Mine went out on me 2 years ago. Only had high (5) though , no lower speeds. The blower motor was seizing and blew the resistors. At that time the blower motor assembly was a dealer only item and was almost $200 , plus i think about $40 for the resistors.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 10-19-2005, 03:23 PM
fire24resque's Avatar
fire24resque fire24resque is offline
2000CAYukon is right, it's the blower motor resistor. I had the same problem in mine, I lost 1, 2 and 3, only had 4 and 5. I talked to a couple GM people and they said it's common for them to burn up.
WATCH though when you go to order your part!!! Chevy changed the design of the part but never changed the part number. There are two different style parts listed as 15-8770!!
AC Delco carries the right one, Advance Auto and Auto Zone don't have the right ones, even tho they say they are for your year vehicle.
I ended up buying mine off www.rockauto.com and paying $5-$10 less then everyone else wanted. GM Parts Direct doesn't stock it anymore. Search the part number and get the AC Delco one, not the Standard one listed. The price for it is $14.65. I put a picture of the standard one below, that's the new model and it won't fit your truck!
They are fairly simple to get to, hardest part is removing the large cover that covers the blower motor itself, it goes from passenger door to almost the gas pedal, I think it was 3 or 4 screws. Once that is off remove the cover for the fan motor, it's right there, you take out two screws and pull down on it (mine sealed itself with the foam a little bit). There is a plug that goes into it from teh back of the fan motor, push on the little clip to release it.
YOU DON'T WANT THIS ONE!!
http://www.smpcorp.com/web_app/catalog/images/RU61.jpg
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 10-19-2005, 07:26 PM
Thumbs up fan speed switch
thanks everybody, sure beats hearing the dealer say, 'i don't know, you'll have to bring it in'.
Old 10-21-2005, 04:48 PM
Smile
Just wanted to say thanks again. I found the switch at a local AC Delco dealer ($16 and change no shipping), looked a bit different at the business end (made in Slovenia) but it mounted and works!
fire24resque , right on about the four screws. Only put 3 back for now, the one under the hump is a real bear but I'll get it.
