Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-18-2005, 07:05 PM
Datura99 Datura99 is offline
Send a message via AIM to Datura99 Send a message via Yahoo to Datura99
Angry 96 H22a into 93 prelude body
I Just found out that they are different and things need to be modded in order for it to work. What kind of problems could I have with this kind of swap. Can it be done and the car still run effectively with V-tech and all. Or should I just find another 93 v-tech engine.
Old 10-18-2005, 09:54 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Either way, the h22 wil bolt right in. The problem you're going to run into is the fact that the 96 h22 is OBD2, where as your 93 prelude is OBD1. If you could find a 95 or older h22, then i'd recommend that. If not, the 96 isn't THAT big of a problem.
