engine temp
i have a 97 blazer and my temp gage only reaches 150 to 160 degrees at the max (the needle is on the hash mark between 100 and 210)... is this normal????
thanx for the help
1997 blazer lt Powerdyne s/c Snow Performance water/meth injection Wait4me tune B&M shift plus Corvette servo Flo-Pro MX muffler BF Goodrich All-Terrain T/A - winter 87 corvette wheels - summer |
No it is not. Sounds like your thermostat is stuck open, better the stuck closed! I would recomend a reverse poweflush to make sure the coolant is fresh and replacing the thermostat with a 195 degree one. Also replace the rad cap if it is stock ACDELCO with a Stant rad cap, the ac delco ones are known for having there issues and letting air in which will cause rust. Your temp should sit just about 2 clicks to the left of 210. Good luck
please guys if I missed anything help him out!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
Re: engine temp
Your temp guage should be around the 200-210 mark. Your truck seems to be running too cool (not good). When was the last time you put a new thermostat in the truck. If it's been a while, you really should flush out your cooling system and install a new 195 degree thermoatat with some fresh anti-freeze.
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
i have 135,000 miles on the truck and i dont think the thermostat has ever been replaced. i will get a new one tomorrow, replace it, and do a reverse flush.. thanx
Re: engine temp
Re: engine temp
Make sure you get a 192-195 stat for Michigan.
don't get a 180 or a 160, they are too cold for your location.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: engine temp
I'm not trying to interupt on anybody's thread but I have recently had the same problem. I replaced the rad cap about a month ago. Yesterday i did a complete reverse flush and filled with a fresh 50/50 mix of antifreeze and replaced the stat with a 195.
My problem is, it is still running exactly between the 100 and 210 mark. I seen something in the auto part store that you pore in your rad and it is spose to make it heat up easier or something. Does anyone know anything about this? |
Re: Re: engine temp
If you can get a live scanner, hook it up and look at the sesnor information from the ECM vs your gauge. They are actually 2 different sensors. If the one from the ECM is reading normal, and the gauge isn't you know that you have to replace the sensor. If both are in line somewhere, you may still have a prob with the thermostat or even thehousing itself.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: Re: engine temp
2003 Honda Element EX 2002 Kia Spectra (can't "Improve" or wife will kill me) 1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot) ![]() " Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White" http://www.myspace.com/officer_redneck |
Must be a fairly common problem, here is mine http://www.automotiveforums.com/vbul...d.php?t=471171
Temp reading with scan tool 198 F cannot get dash gauge to read proper even with new sending unit, yes I verified I relaced the dash unit and not the ecm sensor. I guess it may be in the wiring or the actual gauge in the dash, but I do not know how to trouble shoot further. |
Re: engine temp
my temp gauge is doing the same thing. It stays about one mark to the right of the midpoint. I will try changing the thermostat to see if that helps. Also, what do you guys mean by reverse flush? Can you do this yourself or do you need to take it to a shop? One last question should I get a 195 thermostat. I live in CA and the temperature only drops to about 30F degrees in my area. Thanks
Re: Re: Re: engine temp
Re: Re: engine temp
Re: engine temp
What about the reverse flush. How is that done. One other thing I forgot is what does the stock acdelco radiator cap look like. My cap does not have any brand on it so I am not sure if it is acdelco or another brand. Thanks
