Old 10-18-2005, 05:52 PM
Cercion Cercion is offline
General Maintenace Question - Wheel play
I've noticed the steering doesn't feel as tight as it once did and seems to be a bit looser. To remedy this should I tighten up the sway bar and other suspension bolts?
Old 10-18-2005, 07:09 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: General Maintenace Question - Wheel play
How about your ball joints, upper and lowers. Tierod ends, inner and outer's. When were these last replaced on your truck? Do you grease all 11 zirks regularly? Our trucks can eat ball joints for lunch if not maintained correctly. I grease my truck every 1500K-2000K miles with out fail...Steering rag joint could also be worn out?
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 10-18-2005, 07:14 PM
SBlazerNCS SBlazerNCS is offline
Yeah, i would imagine most of that is just general wear over time. mine is the same way.
Old 10-18-2005, 08:00 PM
Honestly, no clue. I need to lube everything up and tighten it up... recently bought the vehicle from a dealer.
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ok, go and put a jack under your front driver side frame section and jack the tire up off of the grond.
Grasp the tire in the 3 and 9 oclock positions and push with you left and pull with your right and viseversa back and forth and look for play.
Do this for the passenger side when the driver's side is back on the ground. Check for play.
Chances are your will have worn out inner tierod ends and your idler and pitman arms will be bad and need replacing.
To check the bearing and balljoints. Grasp at 12 and 6 o'clock and do the same thing.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-18-2005, 09:57 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
how often should all of these items be replaced? My truck has 200,000 miles and i have no idea when they were done or if they were done.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-18-2005, 10:57 PM
BlazerLT's Avatar
AF -Advisor
Have them inspected and make sure you grease all 10-11 fittings every 5000 mile oil change.
Old 10-18-2005, 11:17 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Re: General Maintenace Question - Wheel play
i'll make it a point to get that done. another thing for my to-do list.
Low 11 sec sleeper
My Cardomain
Old 10-19-2005, 05:27 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Look at this thread that was done a while back http://www.s10forum.com/forum/showth...+steering+slop
