Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 10-18-2005, 06:43 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Bad Vibrations
I finally finished my trunk mounted audio setup in my spyder. I have an 800 watt Orion 250r amp and a 12" Orion HCCA 12d sub in a custom made enclosure. So, I put it in the trunk and hooked everything up. I wasn't expecting it to sound too good because it is a convertible. The system knocks but the trunk vibrates like hell. It sounds like some kind of ghetto system. When I am in my driveway with the trunk opened up I can turn the volume to like 10 and all of the kinda high beats vibrate the trunk really bad. The lows sound pretty good but thats about it. When I close the trunk it is 3 times as bad and irritates the hell out of me. I turned it up today and opened the trunk and tried to find out if any of the interior panels were making the noise but i dont htink they are.
I don't really know what to do about the problem. I was thinking about Dynamatting the whole trunk, especially the trunk lid. But what material should I go with and how would I do it? Would I just take out all of the panels in the trunk and apply the mat to the metal or what?
Thanks for the help.....and I may post some pictures if anyone cares.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-18-2005, 06:49 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Bad Vibrations
Use the basic dynomat stuff. Works like a charm. Yeah, take off the panels and add a layer or 2 to the whole thing. Pretty easy.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-18-2005, 10:07 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
If you wanted to be cheap, you could always just go out and buy a bunch of industrial carpet and spray adhesive and cover your truck with that shit. Not quite as effective as dynamat, but helllllluva lot cheaper. Take your time and make it look nice, you won't want to stare at a sloppy job.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-19-2005, 12:33 PM
cx500honda81 cx500honda81 is offline
Send a message via AIM to cx500honda81
Re: Bad Vibrations
don't know if the spyder is made the same way. but suggestion if the trunk side panels are made the same way, there are air vents in them which have flaps on the back of them, block off or remove flaps. Only one of the things that are vibrating, but a start.
Green 98 eclipse RS 2.0 non-turbo
Old 10-19-2005, 10:58 PM
Re: Bad Vibrations
No, there aren't any air vents back there. And I dont think I want to be cheap and use carpet . So I guess when ever I get around to it I will just order up a bunch of dynamat and put a couple layers throughout the trunk.
Caleb
vanilla gorilla
Old 11-01-2005, 01:34 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Bad Vibrations
I used some thin rubber shims on the trunk lid where it was vibrating... you know the little gaps inbetween the outer piece and the frame.... not sure how to describe it....look at the underside of your trunk lid and you should see what I mean...but anyways.. it worked like a charm. Still had some rattle but not near as bad as before.
Ultimate cure... Dynamat
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
