Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-18-2005, 03:58 PM
Benag Benag is offline
What the hell is in my vacuum tube!?
So I am installing my MBC and I am using the old tubes to install mine and I take off the one coming from the "Y split" to the compressor part of the turbo. This is the short one about 2 inches. Well I feel it and there is something inside. After pushing it out with a small screwdriver I see it is a small piece of metal like a pipe (about 2-3 mm long. I'm just wondering what it is. Does it slow down the airflow or something? Sorry if this is a stupid question. (Oh yea, and what did you guys without the kits use to plug that port and the two on the BCS?)
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 10-19-2005, 01:32 AM
Re: What the hell is in my vacuum tube!?
Damn I hope I wasn't the only one with this thing... not that it matters anymore because I took out the hose..
'95 Eclipse GS-T
5-Speed
Old 10-19-2005, 07:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
For the BCS, nothing. Just leave the wiring harness plugged in or you will get a CEL. I'm not sure I know what other port you are talking about.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-19-2005, 12:29 PM
Re: Re: What the hell is in my vacuum tube!?
The other port that it says to plug is the nipple going to the compressor housing. I guess I'll try to find something at autozone or somewhere. This is the nipple that had the tube with the object in it.
'95 Eclipse GS-T
5-Speed
Old 10-21-2005, 09:04 PM
giddyup50 giddyup50 is offline
Huh,huh,huh, you said nipple
Old 10-25-2005, 07:23 AM
kjewer1 kjewer1 is offline
AF - Advisor
Probably a restrictor, but I've never seen it, or looked for it for that matter. But it has been 5 years since the stock BCS was used on the 2g, so I may have just forgotten. I'm sure it's perfectly normal though. Restrictors are often used in bleed type boost control systems.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
