Old 10-18-2005, 01:39 PM
Achirigotis1 Achirigotis1 is offline
Unhappy 2003 lasabre tranny problem
I have a 2003 lasabre, 32,000 miles,and the warranty just went off. The transmission is starting to slip when shifting only from first to second, when tranny is cold. After it gets hot, slipping is less. Never changed the filter or fluid. Any sugestions?
Old 10-18-2005, 04:19 PM
maxwedge maxwedge is offline
A990 racer
Re: 2003 lasabre tranny problem
Slippage can be detected by a thorough scan with a trans capable scanner, sometimes a code will set but at minimum slippage errors or percentage will be noted.
Old 10-18-2005, 05:58 PM
Re: Re: 2003 lasabre tranny problem
Thanks.
I called my local Buick dealer, and they want $65-75 per hour to just check it. Then whatever the cost would be to repair.
Is there some one else I can go to for the scan?
Old 10-18-2005, 06:23 PM
A990 racer
Unless you are under warranty, any good trans shop has this type scanner. Forget a non trans capable type scanner such as Autozone, or other ones that are not specially equipped with trans cartridges and trouble shooters.
Old 10-18-2005, 07:00 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Re: Re: 2003 lasabre tranny problem
Originally Posted by Achirigotis1
Thanks.
I would ask the dealer if Buick will help since the mileage is so low despite its being out of the time warranty -- if there is a problem. I would tend to stick with the dealer unless they've been real nasty. And call Buick at 1800---- in your owners manual AFTER the dealer checks to find out what the problem is.
I would be real surprised if they or someone else doesn't already know what happens that is causing this. You might try checking with another dealer if you feel uncomfortable with the one you're at.
Old 10-18-2005, 10:18 PM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
Did u check your fluid levels? Could be a little low.
Unless trans is in limp mode.
