Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-18-2005, 01:02 PM
badgervine badgervine is offline
dim headlight on 99 ram
my 99 ram has a dim headlight on the drivers side only even after changing the bulb passenger side is fine any ideas? thank you
Old 10-18-2005, 06:44 PM
dss56 dss56 is offline
Re: dim headlight on 99 ram
you have a bad chassis ground on the headlight look for a pig tail ground wire from the headlight to the chassis i bet it broke or is corroded/bad connection. Usuall the wire will have a lug on it and screwed to the radiator support or some part of the chassis ground. Good luck.
Old 10-19-2005, 10:47 AM
Re: Re: dim headlight on 99 ram
i cut behind the light socket into the ground wire and grounded it and it worked but now head lights stay on all the time any help. thank you
Old 10-19-2005, 01:44 PM
might of gotten the wrong wire to ground. Should be a wire going to the ground by a pig tail with a lug like i said Try to look real good FOR THE WIRES TO THE CHASSIS. The wire you grounded might be from relay that controls that headlight a wire befor the relay. Try to get awiring schematic for the headlight wiring and you should see the ground wires fir the headlight wiring. I had a problem yrs ago on my 1969 GTO that only one head light lit dim had to remove the bumper to get to the groung wire and low and behold a corroded lug from the one headlight that was bad.
Well good luck and look good and hard for that wire.
