Originally Posted by unknownluder69
Ì found a turbo kit from a dealer for $1697 for my 4th gen lude h22a1. its a garrett turbo t3/t04E 60 trim, the housing is .63 A/R, with a 38 mm external wastgate, and a 33.5in x 12in x 3in intercooler. so what do you guys think about this setup in a lude? I think i still need to get oil lines running frrom the turbo and a 10 psi spring and turbo headers which are $279. I dont know much about how to run the oil lines and what is needed for that paert of the project so any help there would also be appreciated.
if you get the greddy oil filter relocation kit for a teg or civic (don't worry it will fit your lude) - it has ports for such an application - you can tap off the ports a send and return for oil for the turbo. i'd probably still run it thru some sorta oil cooler before returning it - but i haven' t really thought that far ahead because i'm not building my turbo yet.
the relocation kit is also supa nice - because it makes changing your oil filter a snap. it's also sorta sexy. not my bay but you can sorta see it here.
http://www.honda-tech.com/zerothread?id=1382150
about 3/4 down the page in a post made by @ries.
