Old 10-18-2005, 11:02 AM
Dave S. Dave S. is offline
92 cav no spark, good crank sensor
I would like to change the right part, not all the parts$$$.
The car cranks fine, with no spark at any plug. The coil packs are newer, about a year old. the ecm is from a junk yard, in service for about a year. there is power at the ignition module, so it isnt a bad fuse. It has 12 volts while cranking, so it isn't loaded down by a short.
there are no obvious visible defects on the coil packs or ignition module and the connections are good. I hooked a o scope up to the crank sensor which gives a good output to the ignition module.
I suspect the ignition module, but a new one is $250.
is there a way to determine the ignition mod is bad and not the ecm module?? btw, the check engine light never came on when the car last ran. it stays on when I try to start it but I believe that is normal.
Also has a new o2, tps, map sensors.
Ideas?
Old 10-18-2005, 11:24 AM
Re: 92 cav no spark, good crank sensor
I just connected a noid to one of the injector wires, no pulse. Now I assume I must change the ecm!
Old 10-18-2005, 12:50 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
That's a good assumption, let us know...
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 10-19-2005, 08:55 PM
gina_666 gina_666 is offline
me too!!
I am having the same problem, so I resorted to chaning the ECM. I put the new one in and it doesn't work or something. The directions that came with the ECM/PCM say something about a crank re-learn procedure, but the directions to do that may as well have been written in latin. Let me know what you do and how it turns out!!
Old 10-20-2005, 12:47 AM
I will post the results when I install the module, it may be a few days....
The last one I installed was from a like model cav, no programming required. I don't know if you can tweek a 92 ecm anyway.
Old 11-14-2005, 08:24 AM
I changed the ecm with a junk yard unit.
still no start, no injector firing.
Old 11-14-2005, 01:09 PM
Have you tried a junkyard ignition module?
Old 11-15-2005, 12:29 AM
The ignition module is next, too busy to go get it right now....BTW, which cars would have the same module as a 92 cav? baretta?sp
Old 11-15-2005, 12:48 PM
I'm not sure on the Barettas, if they we're all V6s or not. I know that if you get one off another 2.2 Cavalier from 94 back to 91 or maybe earlier, it should work.
Old 11-26-2005, 11:28 AM
Woo hoo! she lives!
I replaced the ignition module with a junk yard unit.
It has been garaged since May and it fired right up.
The moral of the story: the ecm unit is smart enough not to fire the injectors if it doesn't see a spark.
Now to renew the liability ins.
