Old 05-21-2002, 11:10 AM
HookdUpTeg99 HookdUpTeg99 is offline
What is this noise???
Lately i've been gettin a lot of ambient noise coming through my speakers in my car. It matches with the rev's of my car, like if the rev's are high it is high pitched and so forth. But, the thing is that it only happens randomly. One shop said that it mite be my battery but my batter doesn't seem TOO weak. Could it be anything else like speaker wires or amp and sub wires?? Thanx
'99 Red Integra LS
- Ground Control Coil-Overs
- KYB AGX Adjustable Shocks
- 17" Konig Toxxins w/
205/40/17 Kumho Ecsta Supras
- Mid-Wing Spoiler w/ LED
- Injen Cold Air Intake
- Pioneer Head Unit w/ Animation
- JL Audio 250/1 Amp
- 2 10" Alpine Type-R Subwoofers
- Reverse Indiglo Titanium Face Gauges
- Hyper White Headlights
- Clear Corners
Old 05-21-2002, 11:36 AM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
Re: What is this noise???
are you sure its the speakers?
one thing to try is to mute the stereo and listen for the sound.. if its there... it makes me think a somethign has a bad ground.
Old 05-21-2002, 01:15 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I had that happen once and I was told to replace my spark plub wires and that fixed it, or you can also get a noise filter from radio shack or something and that will work.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 05-21-2002, 02:35 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
it could be a lot of things, check the battery ground, make sure you run your RCA's and speaker wires on seperate sides of the car, could be messed up spark plug wires also known as radio suppression wires, could even be your intake.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-21-2002, 06:29 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
interesting..
yea, a noise filter should fix the problem. if not, then you bought a cheap filter :finger:
I love them sub wufers
Old 05-21-2002, 06:59 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Uhhhh, dont buy a filter -- its a cheap "band aid" fix and a total waste seeing as your problem probably lies in something that is something you can do which costs you nothing -- so why pay to just "patch over" the problem when you can fix it for good?
First off you need to locate the problem... start by checking to see where the amplifier power wire and amp RCA cables are run -- they should be run at LEAST 18" apart but preferably on opposite sides of the car. If the power wire goes down the PASSENGER side near the ECU, have the shop swap sides as this can cause noise.
Now for the real test...
1. Turn your car on
2. Turn your stereo on
3. Listen for the sound, is it there? Rev the motor -- what about now?
4. if the sound is there, unplug the RCA cables on the amp
5. Rev motor again... can you still hear the sound?
- if so, your RCAs need to be moved or replaced with better cables
- also check the alternator, if it is only "temporary" or occasional noise, this could be a sign of impending damage -- make sure its giving out the correct current though all the RPM's
6. Check all your grounds and crimps -- a bad crimp can actually lead to noise entering a system
Good luck! :smoka:
AF's Official Asshole
RIP AUNIE
Old 05-21-2002, 07:26 PM
GSteg's Avatar
or if you wanna go overrated..get one of those Rockford Fosgate "gamma riot" RCA wires. they claim to have no noise
just do wat sparq said. if that doesn't work..then your only hope is to get a filter. and if it still doesn't work..take out your sound system and you should be fine
Old 05-21-2002, 08:18 PM
PaulD's_revenge PaulD's_revenge is offline
Banned
Originally posted by crxlvr
make sure you run your RCA's and speaker wires on seperate sides of the car.
I see that old wives tale is still alive and kicking. To disprove it is easy ...... Turn the volume ALL the way down - is the noise still there ? of course it is ! How much power do you think is going thru the power wire, the RCA's or the speakers wires ? Only what the car is radiating - which obviously NOT coming from any of the stereo components
Old 05-21-2002, 08:24 PM
GSteg's Avatar
what happen to your other username?
Old 05-22-2002, 02:18 AM
Devedander Devedander is offline
I have Riot Gamma wire, I think it only touts no crosstalk cuz of the way it's wired, not that it is shielded any better from other outside sources (apparently wires crossing at near 90 degree angles cause no crosstalk).
Old 05-22-2002, 07:59 AM
Banned
it wouldn't let me on with my old name :zx11pisse
the only (RCA) cables that work are the ones that have NO braided sheilding.
Old 05-22-2002, 09:31 AM
sparq's Avatar
AF Premium User
Oh the only ones that work are the ones with NO braided sheilding? Try telling that to all the people winning SQ tournaments with Definition II RCA cable....
RIP AUNIE
Old 05-23-2002, 09:14 AM
Banned
we were talking about cars that had noise problems ........ some cars/installs don't have that problem, so they are free to use a wider variety of cables
Old 05-23-2002, 12:10 PM
sparq's Avatar
AF Premium User
Um, you said that the only ones that work are the ones with NO braided sheilding... and so you know your CAT5 computer wire RCA cables is a crap idea too man. Stop giving bad advice to peeps :o
http://www.installer.com/tech/cat5.html
j00 my friend, have been OwNzEd! :finger:
RIP AUNIE
Old 05-23-2002, 05:47 PM
Banned
Eddie Runner strikes again .......... I thought I had seen the last of the guy, but I guess he still lives - to anyone who will listen. The reason he was kicked off of carsound is because he flamed pretty much everyone in sight AND the sponsors (manufactures) got a little antsy. The sponsors axed the capacitor thread on there too .... cuz Clark proved certain ones were worthless (and yes, Richard can be rather arrogant in there). It's hard to say whether Eddie's research is genuine, but I have fixed a few cars with home-made UTP's (before I knew about CAT-5) that no coaxial RCA's could rid of the noises.
