Old 10-17-2005, 11:06 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
hard starting
my blazer has had a hard time starting the last few days, where when i fire it up, the RPMs drop below 500 and then it kind of shudders and stalls. this happens a few times until i have to rev it up after starting, just long enough for it not too stall. is my bad devil simply in need of a tune-up?
[154k miles, 97 LT 4X4 - last tune up was at 135k miles]
Old 10-18-2005, 08:19 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: hard starting
List Exactly what was done on your last tune up.
What kind of spark plugs did you use and what was the gap on em.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 10-18-2005, 08:57 AM
djd99's Avatar
djd99 djd99 is offline
Howdy I had the same issue with my blazer last year it turned out to be a corroded coil wire. you might give that a check. Don
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 10-18-2005, 08:30 PM
Re: Re: hard starting
i didn't do the tune-up. i purchased it last may at 138k miles and the tune-up was done at 135. Fuel and air filter are getting changed tomorrow along with changing the oil.
Old 10-18-2005, 08:54 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: hard starting
Do you have proof as to what was fone during the tuneup when you bought it?
Not all tuneups are the same. Some people think an oil change is a tuneup item.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-19-2005, 06:49 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Another thing to check is the condition of all your vac hoses. This can cause low or high idle and stalling. Check them all for dryrot/cracks/holes. Replace as necessary. Check the connection at the vaccume ball and make sure the ball itself has no cracks. Replace hoses as needed...Hell, at 10cents a foot it's not expensive.
Old 10-19-2005, 10:57 PM
Re: hard starting
checked that. all looks square. however, i did replace the fuel filter and the air filter today and my rough starting, shuddering, low idling, seems to have been solved.
To BlazeLT, yeah there was documentation of new spark plugs, wires, car, rotor, and pcv but not for fuel filter so who knows. maybe that wasnt replaced sometime and this could have been long overdue.
anyhow, thanks guys, hopefully problems fixed!
Old 10-19-2005, 11:24 PM
BlazerLT's Avatar
AF -Advisor
Awesome, yea, the fuel filter should be replaced anyways.
Also, an air filter might not hurt.
Old 10-20-2005, 09:01 AM
Re: hard starting
yeah, i replaced the air filter too. both that and fuel filter were Purolator brands. decent, right? i have heard the advantages of a K&N airfilter, but didn't feel like dropping that much money with all the other expenses i had yesterday.
Old 10-20-2005, 05:48 PM
BlazerLT's Avatar
AF -Advisor
Purolator are completely fine, I really respect their quality and workmanship. Better than Fram any day.
