Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-17-2005, 09:01 PM
angela5503 angela5503 is offline
Replacing fuel filter
Is it really necessary to remove the fuel pump fuse to replace the fuel filter ,since Im going to disconect the battery anyway what is the purpose. It seems like a 1-2-3 maneuver , am I being naive?
Old 10-17-2005, 09:52 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Most manuals probably say that just for a safety thing. By doing that instead of disconnecting the battery you dont lose power to the radio, clock, computer so they keep their memory.
The main reason for doing it in the real world is once it removed, start the engine and let it run till it dies, that will remove the pressure from the system. You will still get fuel comming out but it wont be under pressure. I recommend picking up a couple fuel line blocks (they clamp down on the rubber line on each side of the filter) that will keep any excess fuel from comming out on you.
Old 10-17-2005, 11:45 PM
megavolt121 megavolt121 is offline
Re: Replacing fuel filter
You can also just use vice grips on each side of the fuel line
Old 10-19-2005, 03:44 PM
php php is offline
The main reason for pulling the fuel pump fuse and then running the engine until it dies is, as gizmo42 said, to relieve the pressure. The fuel line pressure is usually around 40-50psi. It's not a lot of pressure, but when your underneath the vehicle, struggling to remove hoses, it would be pretty easy to have gasoline fly all over the place (in your eyes).
1993 Rodeo, V6, 3.2L,
4x4, 5 speed
130,000 miles
Chicago, Illinois
Old 10-19-2005, 08:25 PM
Cat Fuzz Cat Fuzz is offline
Its not alot of pressure but it is enough to squirt gasoline a good 20 feet or so. Don't ask me how I know this.
