Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-17-2005, 08:33 PM
shudson shudson is offline
1999 Saturn SC2
My Saturn takes spells were it will not start. DEAD. The chime and radio fuse has to be pulled and put back in for it to start again. Why is it doing this?
Old 10-28-2005, 03:16 PM
ASE_Tek0312 ASE_Tek0312 is offline
does it happen on humid days?
Old 10-29-2005, 07:12 AM
Re: 1999 Saturn SC2
I can't recall if it was humid when this has happened, except for the last time, which was about 10 days ago. It wasn't humid. Could the humidity have something to do with it?
Old 10-31-2005, 02:58 PM
well it could if the wire insulation has been torn or maybe a mechanic poked a hole in it with a T pin or something. where do you live?
Old 11-01-2005, 04:13 PM
Re: 1999 Saturn SC2
Kentucky
Old 11-02-2005, 03:08 PM
Re: 1999 Saturn SC2
well if kentucky is normally humid then it might cause it but Im not a weather man. You have to take out fuses and put the same ones back in for it to start? when it doesnt start, does it seem like the batteries dead?
Old 11-02-2005, 07:43 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 1999 Saturn SC2
the chime fuse control the stock secaruty system, perhaps there is a fault there.
inspect the fuse holder for a loose fuse terminal.
also do you have a aftermarket radio?
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 11-03-2005, 09:25 PM
Dennyav Dennyav is offline
Re: 1999 Saturn SC2
Hi Shudson,
I'm curious about how you found out that pulling the chime and radio fuse caused the car to start. Did you pull the fuse and then it started? My daughters car '98 SL would do that because the battery wasn't fully charged by the alt. and the starting load was too high unless she pulled the fuses.
Old 11-03-2005, 09:31 PM
Re: 1999 Saturn SC2
BTW, how dead is dead? Could be that the technician who worked on the car didn't tighten up the battery connection well.
