Go Back   Automotive Forums Car Chat > Ford > Festiva
Old 10-17-2005, 07:27 PM
little festiva little festiva is offline
bad fuel mileage
92 ford festiva fuel injected auto,only getting 27 miles to the gallon.runs good no misses but only 27 mpg.whats wrong?allready tuned up.
Old 10-26-2005, 07:18 PM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: bad fuel mileage
I guess you should start with the little stuff. Air filter, fuel filter, injector cleaner, and grease everything up. You would probably see something of an increase.
Old 11-16-2005, 08:48 AM
IdealSociety IdealSociety is offline
Send a message via MSN to IdealSociety
Re: Re: bad fuel mileage
also try a new o2 sensor... that helps determine how much fuel is dumped into your engine and if it hasnt been replaced in many years, its readings can be off causing milage to go down...
