Old 10-17-2005, 08:20 PM
speedphreak speedphreak is offline
fuzzy texture
when I airbrush, sometimes I get a fuzzy texture on the paint. Is this cuz I put to much thinner in or not enough? Thanks everyone in advance!
-Chris
Old 10-17-2005, 08:31 PM
mozli's Avatar
mozli mozli is offline
Re: fuzzy texture
fuzzy? sounds like the paint is drying in mid-air, in that case it is the classic "orange peel"... adding more thinner will cause the paint to dry slower but i'd try to boost the psi a bit first... what psi are you working at? are we talking about body or engine/interior?
Also, check out this link on scalewiki which concerns problem with paint surfaces:
http://www.scalewiki.com/wiki/index....Spray_Painting
Regards, Roy
p.s dont forget to thank Vric
finished: BRG Morgan 4/4
RoY
Old 10-17-2005, 08:50 PM
Re: fuzzy texture
I work at ROUND 35 psi and i use HOK paint . So add more thinner? What psi should i shoot at?
Old 10-17-2005, 08:54 PM
Vric's Avatar
Vric Vric is offline
Good read about Airbrush Troubleshooting on ScaleWiki
This article cover your problem. You can also read the article that mozli suggested, but the Airbrush Troubleshooting is exactly what you want.
Edit: There is also the article by Tamiya Paint Troubleshooting that might help.
Old 10-17-2005, 09:41 PM
Re: fuzzy texture
I think I was spraying at too high of a pressure. I was using 35.......I think I need to tone it down and use a 15-20 psi i guess. Thanks alot for your replies guys!!! And I'll try to spray closer to the model next time.
-Chris
Old 10-17-2005, 10:18 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: fuzzy texture
does it look like cotton candy? if so, you need to thin it more, it is too thick. I had the same problem
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 10-17-2005, 10:44 PM
Re: fuzzy texture
Yah, when its on the model it has a funny tesxture. Its not spider webbing, like what happens wit clearcoating. Its on the model, and I think it dries to fast, like, before it hits the model. I going to take a shot and turn down the pressure and spray closer to the model.
-Chris
Old 10-18-2005, 07:57 AM
white97ex's Avatar
Re: fuzzy texture
I tried everything while I was spraying. It got a little better when I got closer to the model. but automotive paint needs to be thinner than model paint...from what I have found
Old 10-19-2005, 05:21 PM
Fastphil's Avatar
Fastphil Fastphil is offline
Re: fuzzy texture
i don't know muc habout using an airbrush, but it sounds to me like you're spraying from too far away.
Edit: I just read your last post. Maybe you should get even closer. Airbrushes spray much finer particles than spraycans, so the particles dry quicker while "in flight."
Old 10-20-2005, 08:09 AM
RallyRaider's Avatar
Zomby Woof
Re: fuzzy texture
Could be what I call "powdering", I get it some times. If what you're experiencing is similar, I think is caused by the paint drying to much before it reaches the surface of the model. Can fix it any number of ways, playing with the pressure, consistency, distance from the model. If it isn't too bad a light sand of the surface can smooth it out.
