Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-17-2005, 08:19 PM
robandpattiann robandpattiann is offline
Question strange happenings with my aurora
I was driving around all day in my 95 and on the way home the car started dying the trans wouldn't go in drive the warning lights all stared coming on, the first low coolant, the last before I stoped said check charge system. It would not recrank so I was going to jump it off, when I opened the hood I discovered I had left the coolant lid off the nite before, but the car never ran hot, after I refilled coolant and jumped off all systems go, it's back to normal, what sould I check for damage?
Old 10-18-2005, 08:58 AM
tjm's Avatar
tjm tjm is offline
Re: strange happenings with my aurora
i wouldnt be too concerned about damage - maybe replace the air filter as it may have been somehow drenched with coolant as well as the belts. - give the engine compartment a good soapy bath.
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
Old 10-18-2005, 03:14 PM
sbronzell sbronzell is offline
I actually did that by accident one time when I was having coolant leaks, I forgot to put the cap back on after filling it up and it stayed like that until I had to fill it up the next time!
I have no clue how nothing bad happened, no warnings, no overheating, but it's not a pleasant site to see your coolant cap sitting there when you pop your hood.
Old 10-18-2005, 08:06 PM
zimaad zimaad is offline
as long as the level is full, you should be ok. Sensors probably tripped due to pressure not being there when the cap was off as well as loss of volume. Hey, at least the car was smart enough to let you know something was wrong BEFORE anything bad happened. Imagine if no sensors were there and you kept on driving for a while....bye bye aluminum block/heads!!
