Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-17-2005, 05:34 PM
stovallcm stovallcm is offline
1985 F150 stalls instantly
1985 ford pickup 300 in-line 6 cyl. starts and runs just fine but when you are going along sometimes it cuts out and dies. when it dies it is hard to start again and if it does start will not stay running long until it cools down and start over. new distributor cap, rotor cap, wires, plugs, ignition module, and rebuilt carb, however i rebuilt the carb myself and cannot guarantee it is perfect.
Old 10-17-2005, 08:22 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 1985 F150 stalls instantly
Your in a GM forum!
Old 10-17-2005, 11:41 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Check your fuel pressure, your alternator, and your battery voltage when cranking.
Old 11-03-2005, 06:09 PM
eleyebee eleyebee is offline
Try heating the ignition control module with a hair dryer while it is running. I'll bet you it will die on you. The module is mounted on the inner fender well, and is approximately 5x5 inches square. It should also have two plugs that hook to the wiring loom. They fail frequently, and are not too expensive.
eleyebee
