Old 10-17-2005, 03:43 PM
Tahoe_Sport Tahoe_Sport is offline
cold air intake
I have an Airaid cold air intake and an airaid throttle body spacer on my 97 Tahoe. I keep on getting misfires driving on the interstate. I took it to the dealership and there were no codes in the computer excpept it said the timing was off and the air/fuel ratio was off. They fixed the timing but could not fix the air/fuel ratio because they said they couldn't do it since I had the intake and tbs on. Does anybody have any suggestions on what I could do or what could be my problem? I have replaced all plugs, wires, rotor and dist. cap with ac delco parts and that still hasn't solved the misfire.
Old 10-17-2005, 04:20 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: cold air intake
First, throw that TBS away. They do practically nothing for our engines.
Second, disconnect the battery for about 5 minutes. Once you reconnect the battery it is supposed to force the PCM to reset. Drive it a couple times. The PCM takes down all the new info and makes adjustments accordingly. You should notice better driving quality within 2-3 trips.
If that doesn't work, let us know and we will go from there.
Jake
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 10-17-2005, 04:21 PM
Re: cold air intake
I just noticed you said 97 Tahoe..... The TBS may not be a POS for your engine....
FYI this is the 99 and up forum...
  • Hypertech PP III
-Nineball
Old 10-17-2005, 06:16 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: cold air intake
yeah, from what I understand, the TBS works well for all top induction engines
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
