Old 10-17-2005, 03:42 PM
Tahoe_Sport Tahoe_Sport is offline
cold air intake
I have an Airaid cold air intake and an airaid throttle body spacer on my 97 Tahoe. I keep on getting misfires driving on the interstate. I took it to the dealership and there were no codes in the computer excpept it said the timing was off and the air/fuel ratio was off. They fixed the timing but could not fix the air/fuel ratio because they said they couldn't do it since I had the intake and tbs on. Does anybody have any suggestions on what I could do or what could be my problem? I have replaced all plugs, wires, rotor and dist. cap with ac delco parts and that still hasn't solved the misfire.
Old 10-17-2005, 04:33 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: cold air intake
O2 sensors may be faulty which would collect a bad reading for the computer.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 10-17-2005, 06:59 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: cold air intake
Sounds like bullshit. Your problem lies either in the ignition module?pick up coil or in the fuel pressure (bad pump, presure regulator, bad injector, and such. Or in the map or TPS sensor (O2 possible as well),
1 ignition module
2 pick up coil
3 dad fuel pump
4 bad pressure regulator
5 bad injector
6 bad MAP sensor
7 TPS sensor
8 vacuum leak
9 Plugged up cat or muffler.
10 ?????
Check all these
