Old 10-17-2005, 03:40 PM
louace2 louace2 is offline
Axle locked-up
My 94 s10 does not want to move. Rear wheels seemed to be locked. I can hit all gears, but car will not move.
Old 10-17-2005, 05:05 PM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
jack up the rear axle and put it on jack stands and take off the tires , try and pull the drums off , sometimes it does take a little bit of pursuasion , but if they wont budge one bit , the e-brake cable is probably bound up or soemthing to that effect , if the dums come off easy and the brake looks ok, pull off the diff cover and see if anything in there is munched
Old 10-17-2005, 06:08 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Axle locked-up
Before you pull the diff cover off I would pull the drive shaft just to make sure that it in in the diff.
WT is probably right though, it's probably in the brakes somewhere
Old 10-20-2005, 11:11 AM
Re: Axle locked-up
Thanks, It was the brakes. Had a hard time getting the drums off, installed new shoes now I'm trying to adjust them.
