Old 10-17-2005, 03:14 PM
2001bluebird 2001bluebird is offline
Banned
Will not start 2000 S-10 p/u
I have a 2000 Chevy S-10 P/U 2.2L that quite on saturday and will not start it doesn't even crack(no action when it turn to start) I checked all the connections to the battery charged it for 3 hours... nothing. I also noticed that the gauges go to zero( Battery says 9volts fuel goes to Empty temp reads right) when the truck is turn to run but will go up to where they are supposed to be when the key is off and out after like 2 mins of waiting. I know the battery was charging because my trickle charger went from 4 to 2amps almost right away so i don't feel it is the battery because everything else works.
SORRY FOR THE LONG POST....
Old 10-17-2005, 04:16 PM
maxwedge maxwedge is online now
A990 racer
Question Re: Will not start 2000 S-10 p/u
Lot a guess work here, will it start with a jump, have you actually tested the battery is it up to 12.5, do you have know good grounds and pos connections?
Old 10-17-2005, 11:17 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
is it aftermarket batt? other people have said that they needed to put a washer between the posts and cables. personally i wish there was more room to top mount the battery cables, it'd save so much time
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 10-18-2005, 12:45 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
wont crank? 2.2l? head gasket went bad, hydro locked the moter, could be wrong, but see it all the time
Old 10-18-2005, 03:46 PM
Banned
It starts :)
My S-10 Starts now it blew a 40amp fuse but now the ABS is on i did notice that the brakes are really touchy (before this happened)
