Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 10-17-2005, 03:06 PM
iyad iyad is offline
over heat
hello all i have 2 aproblem with my 730i bmw 1994
1:when the car is on but not moving the tempreture will go up it will go back to normal when im driving.
2.the a/c too will start gradually to give hot air when ever the car is on but not moving it will go back to cool air when driving.
i changed the fan clutch,the water pump.the a/c filters and i cleaned the whole a/c sysstem??
any body can helpppppppe
Old 10-17-2005, 10:20 PM
dlog dlog is offline
Overheat
What kind of condition is the radiator in?
Old 10-18-2005, 02:32 AM
Re: over heat
u mean good or bad? in the agarag they said its good..but i have adout in that..u think it maybe the radiator?ill check with another garag
Old 10-18-2005, 09:12 AM
overheating
Well I was just wondering if there’s any minor leaks’ coming from the radiator. But if there aren’t any leaks, check the expansion tank cap. This may not be the problem, but check and make sure the return hose to the expansion tank isn't clogged. Because it sounds like you have some kind of leak/restriction somewhere, maybe it’s so minor that you can't tell. And the leak may not be leaking out coolant but pressure from the system. The best way is to have it pressure tested.
Old 10-23-2005, 10:48 AM
91HO305TPI 91HO305TPI is offline
Re: over heat
check your fan clutch or aux fan (but i dont belive you havean aux fan) runn car to opearting temp and stop fan you can use your hand but make sure you stop it before it starts to over heat. once stoped hold inplace with fingers flat on blade and wait you may want another person to monitor temp and make sure your not overheating the car if car is getting warm and the fan has not engaged(pulled away from your fingers with fource ) if this dosnt occure then your fan clutch is bad and will need to be replaced
