Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-17-2005, 01:22 PM
roncoemd roncoemd is offline
Suburban Brakelights not working
My 2003 Suburban brakelights are not working. All three are out. I checked the fuse box inside and under the hood. All the fuses seem to be okay. What could be my problem?
Old 10-17-2005, 06:55 PM
baxterday baxterday is offline
Re: Suburban Brakelights not working
Seem to be ok? Did you pull each fuse and check it? If you fail to find a blown fuse, check the wiring harness, but really sound like a fuse or the brake light switch. Have you checked it yet?
Old 10-17-2005, 06:56 PM
Re: Re: Suburban Brakelights not working
How do I check the brake light switch? Thanks
Old 10-17-2005, 07:40 PM
Re: Re: Re: Suburban Brakelights not working
Found the brake light switch under the dash attached to the brake pedal. I moved the connection around and my wife noticed the brakelights came on. At times it would come on and then I would move it around and then it would not come on with pressing the brake. So I moved it again and now it seems to come on when pressing the brake. Should I go ahead and change it or do you think it is okay. If I was to change it, is it difficult? Thanks, Ron
Old 10-18-2005, 02:06 PM
It's easy to change and I would change it.
Old 10-18-2005, 03:37 PM
Thanks, Ron
