Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-17-2005, 01:13 PM
p_run p_run is offline
Question 1992 Bonneville headlight problem
Good Day, Own a 1992 Pontiac Bonneville with a rebuilt starter, alternator. It also has a one year old battery. Problem I am having when I acclerate the headlights get brighter and when I lay off the gas the headlights go dimmer. I just checked the battery and the alternator and both check out OK. The battery terminals are clean, if that matters. Any suggestions? Thanks-
Old 10-20-2005, 09:56 PM
markwb's Avatar
markwb markwb is offline
Re: 1992 Bonneville headlight problem
Voltage fluctuations. Alternator speed is proportional to voltage output. do you have a voltmeter on the instrument panel? Does voltage increase & decrease with engine speed? Maybe voltage regulator malfunction.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
