Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 10-17-2005, 12:59 PM
bigdan18 bigdan18 is offline
Unhappy 01 Accent Died, won't start
My 01' Accent died on the highway and won't start. Not the timing belt, not the fuel pump relay, fuel pump spins, changed the fuel filter, there is gas at the injector manifold, the injectors have 8.6 VDC signal. Car will run if starting fluid is sprayed into air cleaner box. Don't know what the fuel pressure is, not sure where to check? Don't know what else to do?
Old 12-02-2005, 12:16 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: 01 Accent Died, won't start
Don't use that engine starter, that stuff will kill your motor fast. It definately sounds like a fuel problem to me. Some cars have a fuel shut off switch that is supposed to kill the fuel in the event of an accident, and I've heard of these getting tripped by going over a bump. I'm not familiar with Accents but it is usually located in the trunk behind an interior pannel. Good luck.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
