Go Back   Automotive Forums Car Chat > BMW > X5
Old 10-17-2005, 12:09 PM
htn46 htn46 is offline
"check brake light/rear light "
Hi,
Could someone please help me to figure out the message on my 2001 X5"Check brake light/rear light". The message is still on even though I have replaced the light bulbs several times. I could not locate the fuse box to see if it is bad. Thanks.
Old 10-18-2005, 02:14 PM
BAVARIANM BAVARIANM is offline
if you've replaced the lamps with the proper bulbs, the problem is most likely the fixture
Old 10-19-2005, 10:51 AM
Thanks for your response, I may have to replace the new light assembly but it costs too much. I found an excellent article on the BMW x5 forum suggesting simple ways to fix the problem. I will let you know if I can get it fixed.
http://www.x5world.com/showthread.php?t=5698
Old 10-22-2005, 08:47 AM
Re:
Hi
I take out the tail light assembly and found a burn spot on the base. By sanding it down and clean it with vinegard, my brake/rear light is back. This saves me $150.00 for a new tail light assembly.
htn46
