Old 10-17-2005, 08:58 AM
sixdog sixdog is offline
Power Window problem
My passenger side window will not go up on my 98 Firebird. It will go down but not back up at all. When you try to roll it up it shakes and makes a clicking noise, it slowed down noticably in the days prior to failing. I want to fix it myself any links to instructions on how to replace the motor or switch?
Thx
Old 10-17-2005, 09:55 AM
ladybird ladybird is offline
same problem
Wish I knew. Probebly need new gears or a new motor.
Old 10-17-2005, 01:57 PM
razor26047 razor26047 is offline
Question
is it possible it may just be off track, you may want to check that, its just an idea. probably a motor or something though just trying to help
Old 10-17-2005, 03:48 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Power Window problem
Odds are it's your window motor going bad. Happened to me on my driver side. Does it go up at all? Mine went up, then would stop, so I had to let it rest for a minute then try it again. If that's the case, then I can definately guarantee you that it's your motor.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 10-17-2005, 04:48 PM
MidwayAvenue MidwayAvenue is offline
my window motor just died..bought a new one put it in and went up and down then a day later it's making this click noise going up then got stuck..so today i took it apart to look at it the motor, its alright(hopefully) but the gear, one of the teeth i think is chiped or something so i'm going to be getting a new gear..grr too much pain..so maybe it could be the gear..usually when the motor fails it will slowly go up then stop..wait a while, then try and roll it up again and should do the same thing....or it will just stop working completly which mine did...
Old 10-17-2005, 10:44 PM
and heres some instructions for the window motor
http://shbox.com/page/windowmotor.html
