Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 10-17-2005, 08:36 AM
janandkyle janandkyle is offline
someone plz help
Hi everyone,
I have a 1989 Dodge Daytona with a 2.5 and an A520 Manual Transaxle
and I need to Know the Easiest Way to add Oil to the tranny.
Any help will be greatly appreciated so i can get my car back on the road again!
Old 10-17-2005, 11:28 AM
AWP9521 AWP9521 is offline
Re: someone plz help
Jack the car up enough to remove the drivers side wheel, if you look on the other side if the inner fender you will see a cover on the back of the transaxle, there should be a plug on that cover, the Oil goes in there, remove the plug and fill with the factory recommended lubricant until oil starts running out of the hole then replace the plug. You will probably need to use a funnel with a long piece of hose attatched to it in order to fill it.
Old 10-17-2005, 10:25 PM
Thanks sooo much for your help i will be adding fluid in the morning
Again Thanks Veeery Much
Old 10-19-2005, 03:04 AM
DaYtOnAt2's Avatar
DaYtOnAt2 DaYtOnAt2 is offline
Send a message via AIM to DaYtOnAt2
Re: Re: someone plz help
That should be 5w30 engine oil to be exact. It's not ATF or Gear oil.
