Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-17-2005, 09:16 AM
essikr essikr is offline
Question 99 Ranger brakes
Does anyone know the brake bleeding proceedure with the ABS brake system? Brake system was completly re-done front and rear and the system was bled with new fluid.On occasion during a slow stop it feels like the ABS sytem is being activated and the pedal pushes back. Any suggestions?
Old 10-17-2005, 07:27 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Sounds like you have a wheel speed sensor that is not reading correctly. You can pull the wheels and rotors again and see if the front sensors are clean. Rust buildup or metal pieces will screw with the readings. It needs to have an ABS capable scanner installed to pinpoint which sensor is causing the problem.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-17-2005, 11:51 PM
Re: 99 Ranger brakes
Thanks for the reply. That makes sense being a speed sensor as it happens when coming to a stop. I will check it out and get back.
Old 10-25-2005, 02:26 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
you might need to have the truck running when you bleed due to the ABS valves being electric. most new cars are like this.proper bleeding is back to front in a criss cross pattern.(back right,front left,back left, then front right)
Old 10-28-2005, 05:24 PM
Well I pulled the rotors and tried to remove the wheel sensor.The sensor would not come out.I removed the screw that held it the housing and tried to remove it . It broke and came out in pieces. I have looked on several auto part sites and can't find the wheel sensors listed. Are they an after market item? I'm going to pull the fuse for the ABS system as I need the truck. Can anyone share their experience with these sensors?
Old 10-28-2005, 07:09 PM
way2old's Avatar
TOKEN HILLBILLY
We just use OEM sensors. Haven't looked for any aftermarket.
