Old 10-17-2005, 04:03 AM
off_da_wall4u2nv off_da_wall4u2nv is offline
Arrow E.a.c.v
is it possible clean the eacv. i heard of people cleaning their iacv. and they talk about cleaning the little screen inside. is it the same thing with the eacv? anybody know?
Old 10-17-2005, 07:15 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: E.a.c.v
what is eacv ? i know what iacv is. same thing?
Team Lonely Drivers
Old 10-17-2005, 07:43 AM
Re: E.a.c.v
electronic air control valve.
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: E.a.c.v
EACV is what people call IACV.
EACV = Electronic Air Control Valve
IACV = Intake Air Control Valve
I think manual uses EACV... same thing.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 10-17-2005, 09:20 AM
Re: E.a.c.v
so is it possible to clean it out
Old 10-17-2005, 01:06 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: E.a.c.v
pull it out and clean it.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-17-2005, 03:04 PM
Smoghog Smoghog is offline
Re: Re: E.a.c.v
Yes, but try to not get the cleaner into the motor part of the IACV you might ruin it. just hold the IACV motor up when cleaning it out.
SH
Old 10-17-2005, 06:11 PM
Re: E.a.c.v
you clean the little screen
Team Lonely Drivers
Old 10-17-2005, 06:44 PM
skotman's Avatar
skotman skotman is offline
Re: Re: E.a.c.v
sounds easy enough. i need to try this, but my book doesn't clearly show me where it is or how to get to it. i assume i have to pull down the whole motor, yes?
Old 10-17-2005, 07:54 PM
sblkcamaro70 sblkcamaro70 is offline
pull the motor done? no no the eacv is a little device only 6 inches by 2 inches and it sits on the intake manifold i think there is one or two bolts that holds it on. take it off and clean it. it is only about a 1 minute job.
Old 10-17-2005, 09:52 PM
Tokyo_Drifter's Avatar
Tokyo_Drifter Tokyo_Drifter is offline
Re: Re: Re: E.a.c.v
SH
I bought a couple from a junkyard, soaked them overnight in carb cleaner & they never, ever worked again - listen to the man, he knows what he's talking about.
Old 10-18-2005, 10:16 PM
allstar323 allstar323 is offline
I know this might sound kind of stupid, but how do you take the coolant tubes off without spilling any coolant? or can you just spray it down with the lines attatched?
I tried taking off the coolant lines...they're a pain to remove. Any easy way to do it?
Old 10-18-2005, 11:29 PM
AF - Advisor
Re: E.a.c.v
coolant lines will leak when pulled out. just live with it. to take it out the lines, it will just take some effort. just brush out the screen. no need for spraying anything.
Old 10-19-2005, 08:08 AM
Re: Re: E.a.c.v
You don't have to even disconnect the coolant tubes. You don't even move it that much. Just unbolt the 2 12mm bolts from the back and unplug the electrical plug. Then take a wire brush, toothbrush or even some Q-tips and wipe the crap out of the screen and clean out the small hole where it connects to the intake manifold. Then bolt it back up and plug in the plug. It's not that difficult...
2010 Honda CR-V EX
