Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-17-2005, 02:19 AM
Tokyo_Drifter's Avatar
Tokyo_Drifter Tokyo_Drifter is offline
Any 15" OEM wheels fit a 4th gen Civic?
Question: I see Honda has factory alloys but are they compatible with older Civics? Are there any OEM 15" 4x100, 56mm hub, 40mm (or so) offset rims available? I looked around the net, but can't find the answer.
I'd also be curious as to what Civic rims are swappable, or more importantly what aren't. I know 88-91 Civic / CRX / some tegs, but are 92-95 the same?
Background: I bought some 15" wheels & they worked fine on my '89 Civic, until I defided to fix the suspension. Was: Accord (maybe?) nosebleed front springs & worn out junkyard rears. Car looked like I had a body in the trunk. Car had slammed 3" drop coils when I bought it & I did the cheapest coil spring swap to get me through winter. Now: 1.5" lowered Tein coils.
The rear wheels scrub the guards constantly, so I'm running 14" steelies. I want to swap rims since I paid good money for the tyres. I like the idea of OEMs cos they look pretty good & I figure they might be cheaper than aftermarket rims!
Old 10-19-2005, 06:01 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Any 15" OEM wheels fit a 4th gen Civic?
All Civic wheels are interchangeable except of course the Civic Type R (which we don't get in the US).
If you have a 99+ Civic Si (US) some 14s might not fit on the car because of caliper/wheel clearance issues.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-19-2005, 06:26 PM
Ah, thanks for the reply. This helps a lot in tracking down some wheels, as I was never sure if they changed bolt pattern, offset etc. Thanks again!
Old 10-23-2005, 10:56 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
I have some OEM wheels if you want a set....they're GS integra Webs. They're 15" and in good condition!! PM if you want them.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
