Old 10-16-2005, 09:37 PM
bdr1 bdr1 is offline
1996 S10 Starting Problem
Hey guys,
I have a '96 S10 pickup, 4.3, 5 spd, CSFI, 120,000 miles. Its starting problem has been getting worse recently. At first it would have trouble starting, and I would have to crank it for several minutes at a time before it would catch. Once it is running it does fine. The times when it has trouble starting have now outnumbered the times when it's fine, but every now and then it'll start right up no problem. I have replaced the fuel filter and done all the usual tune-up stuff. Any suggestions?
Old 10-17-2005, 07:45 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: 1996 S10 Starting Problem
Have you done a fuel pressure check yet, could be a bad fuel pressure regulator, bad fuel pump, stickie poppits?
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 10-18-2005, 08:17 PM
msgc95 msgc95 is offline
Re: same problem
I just came on here tonight looking to see if anyone else was having this problem. I have a '99 S-10 and my problem is identical. Do you notice that yours seems to do a little better depending on how full the gas tank is? That's wild, mine has about 120,000 miles too.
Old 10-18-2005, 08:29 PM
spivey-1 spivey-1 is offline
s-10 starting problem
man my 97 s-10 had the same symptoms u spoke of and it was my starter that went out dont rule that out also
Old 10-22-2005, 11:45 PM
jgaona002 jgaona002 is offline
Re: Re: 1996 S10 Starting Problem
Hello, I have the same problem Found the pressure to be none existant. fule pump went bad.
Old 11-03-2005, 02:53 PM
hammer6924 hammer6924 is offline
I have a 96 S10 pu V6 and I have the same problem. My milage is only 67 and change. Does anyone have any suggetions?
