Old 10-16-2005, 08:13 PM
9c3 9c3 is offline
grind grind click grind grind click...
...is the sound my the passenger side front wheel makes on my '99 when I turn left slowly, with the steering wheel cranked all the way to the left.
When I do this at a higher speed, it makes a a really nasty noise that I can only liken to a rhino giving birth.
A bad CV perhaps?
Old 10-17-2005, 12:51 AM
ocjmakaveli ocjmakaveli is offline
eziest check jack that wheel up put it in neutral and turn the wheel by hand if the joint makes the noise youll know.
Old 10-18-2005, 10:54 AM
meuhus meuhus is offline
Re: grind grind click grind grind click...
A bad CV perhaps?
could be a bad wheel bearing too
Old 10-18-2005, 11:51 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Id' bet it's a hub bearing, a cv axle making that kind of noise would vibrate like mad at speed.
Old 10-18-2005, 03:47 PM
9c3 9c3 is offline
If it's a wheel bearing then why does it only make that noise when the wheel is turned all the way to the left?
Old 10-19-2005, 07:02 AM
Re: Re: grind grind click grind grind click...
could also be a bad brake
best to get the front end of the car
up
and take the wheel off
and look
for metal shavings
or a broken cv joint boot
put the car in nuetral and spin the wheel
that you suspect is bad
and listen
or look for excessive play in the hub assembly
if there is a lot of play in your wheel hub
its the bearning gone bad
you'll have to replace the whole hub unit
or it could be cv joint
or it could be a bad brake possibly
take it a part check it out
