Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-16-2005, 07:13 PM
chezbayman chezbayman is offline
Car starts then stalls??
1994 olds cutlas supreme. I was driving down the the road it started bucking then shut off.. car would start for 1-2 seconds then shut right off . had little to no pressure in the fuel rail, replaced fuel pump -- result -- no change --3.1--ltr any help would be great thanks ray
Old 10-17-2005, 12:16 PM
SupremeCutlass's Avatar
SupremeCutlass SupremeCutlass is offline
Is this car eqipped with VATS??
if so,
http://www.likeabigdog.com/column/VATS.htm
Old 10-18-2005, 04:03 PM
94 yes it does have VATS.. i bypassed the reader and there was no change. starts then stalls....where is the vats module. can it be bypassed ? is it a dealer item aftermarket or junk yard.. help,, ready to sledge this thing ---thanks
Old 10-18-2005, 04:40 PM
maxwedge maxwedge is offline
A990 racer
Re: Car starts then stalls??
Sounds like you only have fuel presssure during cranking, power up the pump and see if it keeps running, the Vats will not kill the engine once running on the road. I am assuming this is not a problem with spark/injector pulse. Check the fuel pump relay also.
Old 10-18-2005, 08:47 PM
I energized the fuel pump and the car starts then stalls. Could it possibley be the computer??
Old 10-26-2005, 05:48 PM
Question
Come on guys! I need help ASAP!!!
Old 10-26-2005, 07:04 PM
A990 racer
Check 20a ecm battery fuse. If ok, check for injector pulse/spark when it dies and won't start, post back results.
