Old 10-16-2005, 06:10 PM
jsntarrant jsntarrant is offline
Angry 98 windstar...all kinds of elec probs
I have a 98 ws, 3.0l, 100k miles....like many others here, i had the interior lites staying on because the switch wasnt working. I sprayed wd-40 in all the latches, trying to fix the problem that way. it didnt work...tried pulling the overhead bulb out-but it was too hot...so i tried prying it out with my key-not a good idea i know but it was 11 at nite and i was trying to get the lite off so my wife didnt have a dead battery in the morning.
I hit the metal prongs with the key, it sparked and the light went out-thought that i had just blew the light...now i find out i have no horn, no brake lights, wipers(front or rear), no pw, no pl(but the lights still illuminate controls), power mirrors work, radio works...
checked all the fuses with test light and there appears to be no bad fuses...
any one else done anything stupid like this....need some help so i dont have to go tracing wires from the battery
thanks for any help
Old 10-17-2005, 11:54 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 98 windstar...all kinds of elec probs
thanks for any help
You may of blown a maxi link. They're under the hood on your right when you're looking under the hood. Check them out.
I found that the rear hatch latches are the trouble aira for the lights coming on. The lube from when it was new gets old and the switch starts sticking on. I pulled both of mine and cleaned them well with a spray cleaner. Then I lubed them with a spray lube. They seem to be working well.
Regards
Dan
Old 10-17-2005, 05:13 PM
thanks Dan! got pw, pl working, 3rd brake lite works now...but i have some chiming tone now for about 1 min after i start it....i have grown to hate all fords....
Old 10-21-2005, 11:38 PM
mjc8850 mjc8850 is offline
Send a message via AIM to mjc8850
Re: Re: 98 windstar...all kinds of elec probs
You want to focus on the drivers door, the chiming is from the drivers door thinking it is open. clean the latch mechanism or do what i did load it up with WD-40. there is a ton of information look under "door ajar light in 98 windstar. Good luck!
Old 10-22-2005, 06:46 AM
Re: Re: Re: 98 windstar...all kinds of elec probs
You're very welcome! Fix Or Repair Daily
Dan
Good point!
Dan
