Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 10-16-2005, 06:02 PM
melfan melfan is offline
Question 85 Thunderbird power loss, Help!
I have a 1985 thunderbird with 3.8 v6. The engine and just about everything but carb has been replaced but the car still seems to have a hesitation when "stomped on."
Also I noticed the vacume pod on the air intake is broken. This might have something to do with it.
Can anyone help?
Old 10-19-2005, 07:05 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 85 Thunderbird power loss, Help!
Do you have this problem all the time or only when the engine is cold?
The Original 97Bird
Old 10-20-2005, 01:30 PM
coondawg6 coondawg6 is offline
sounds like the accelerator pump in carb is not getting thru--btw whats up bird?
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 10-20-2005, 05:53 PM
97Bird's Avatar
Hey cd6, Where you been? I dug out a 18x25 area in front of my garage to pour a pad just before we had over 7" of rain. Now I have to wait for it to dry out before I can pour!! Just one more speed bump in life's road! I was hinting to Melfan that it could be a choke problem. I can't remember (old age) if the flap in the snorkel stays open or closed with no vacuum. I don't feel like going upstairs in the garage to find an old air cleaner-Do you know cd6?
The Original 97Bird
Old 10-24-2005, 09:53 PM
Can anyone help?
It seems to be worse when the weather is cold. But the hesitation is all the time.
Old 10-24-2005, 10:17 PM
Ok, Fuel systems are not my specialty, could you explain further?
It is a throttle body, I am familiar with standard 2/4 barrel carbs.
I was leaning toward the fuel pressure regulator but I am not sure which way adjusts more/less.
I was also going to replace the injectors even though my mechanic indicated they were fine.
I adjusted the throttle actuator screw so it at least idles fine when warm but when the weather gets cold, especially in the morning it idles rough.
Old 10-29-2005, 01:11 PM
Can anyone help?
I just heard form my mechanic and the problem was the LAST thing I would have thought of.
He told me it was the muffler. It was clogged. The muffler is about a year old how can this happen?
Anyone got any ideas? I don't want this to happen again.
Old 10-29-2005, 07:43 PM
97Bird's Avatar
The insides of the cat converters might be breaking apart.
The Original 97Bird
Old 10-29-2005, 08:16 PM
Re: Re: 85 Thunderbird power loss, Help!
The CAT is hollow. I gutted it insted of replacing it. The preformance improved dramatically after doing it.
