Old 10-16-2005, 04:57 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Finally getting around to the sound system
Hey guy's (and quite possibly gals), I am semi new to this section and just looking for some imput. I finally finished up messing around with my engine and now have turned my interest into my audio system wish was extremely lame with the exception of my Pioneer GM designed din and half head unit (deh-45dh) which I love. However the gm-x972 800 amp I bought a while ago and was planning at some point to just throw a half assed box up on the back ledge of my 94 Pontiac Formula/Firebird but the once I started doing a little research. I decided to pick up all new 4 way Pioneer speakers (TS-A1681S 6 1/2 in front and TS-A1780R 6 3/4 in the back) and I am also putting in a Q-logic custom fit box in the back which is going to hold my 2 12 inch Pioneer subs. So after I bought my subs and just to make sure I wasn't going to run into any snags I double checked the stats of my subs, but after putting in my model number into Pioneers website. I came across this http://www.pioneerelectronics.com/pn..._41275,00.html , So now they gave me the options of another Pioneer amp but they no longer make anything really all that similiar to the stats on my current amp, the only one close is a 600 watt 4 channel (gm-6100F) that if bridged for 2 channel deliver 150 RMS watts to each sub and max 300. Which is the same as the other one but my question with that one is that it gives the options of stereo or mono with the 2 channel , if I go Stereo which would change the ground terminals, does that affect the watts? and is there any other negative effects of bridging, that will effect sound quality?. Like I said I am semi new to this, so any feedbacks on things I should be aware would be appreciated as well as any Pioneer amp you would recommend I take in place of mine. Thanks
Edit- Sorry thats so long , I ramble
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-16-2005, 07:12 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Finally getting around to the sound system
Running your amp stereo will not have anything to do with your grounds. well there is a lot of wrong info there, check this out www.bcae1.com , good place to learn the basics of mobile audio
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 10-16-2005, 08:16 PM
FormulaLT1's Avatar
Fight the powwa!!!
I am talking about the terminals on the amp to the subs, Not the main ground for the vehicle. They have a mono and stereo routing for the sub on the amp. My question is if it will have any effect on watts. Thanks for the reply
Old 10-17-2005, 03:11 AM
Mannyb18b's Avatar
Your amp is 2 channel, so bridging your left output an right output together will create the mono load, and using the channels seperately is stereo. If just to say each channel is 100w, bridged power would be 200w x1. Just make sure you dont go below the ohm load for the amp in Mono.
Alpine H/U-
CDT EF-61's
NSB-100
Old 10-17-2005, 03:32 AM
FormulaLT1's Avatar
Fight the powwa!!!
No, the model amp I am looking to get as a replacement for mine which is a recall is a 4 channel amp. When run as a 2 channel it gives you the option of Stereo or Mono , which use seperate terminals on the amp to ground the speakers/negative side polarity. My question is, do I lose any power from using the stereo versus mono option for the two channel and The power isn't doubled by going to 2 channel to a mono or from a 4 channel to a 2 channel its more than doubled. For instance my current amp that has been recalled is a 800 watt peak amp with 400 watts RMS when used as a single channel/mono amp but when you use it as a two channel it only powers each channel to 300 watt peak power and 150 RMS. Which is less than half per channel.
Old 10-17-2005, 03:17 PM
dantheman8328 dantheman8328 is offline
i understand what your saying. you shouldnt run your subs stereo, you probably want to run them in mono. but either way, there shouldnt be any power loss.
Old 10-17-2005, 03:29 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thanks, that was what I was looking for.
Old 10-17-2005, 04:06 PM
Mannyb18b's Avatar
well if you bench tested your amp the actual watts will be double or somewhere close than each channel when bridged.
Alpine H/U-
CDT EF-61's
NSB-100
Old 10-17-2005, 04:08 PM
i thought it would be closer to between triple and double the amount??
Old 10-17-2005, 04:14 PM
FormulaLT1's Avatar
Fight the powwa!!!
Thanks, I will keep that in mind. I am now trying to decide if I should now use a seperate smaller amp for the front 4 speakers as they can handle alot more power than my head unit is making but if I use two external amps, how does the amp remote signal work from the head unit, do I just splice the wire and run it to both amps if I go that route? Or is there another way people do that. My speakers can handle 50 watts RMS (260 watts peak) and my head unit is only making 17 watts RMS (35 watts Peak).
Old 10-17-2005, 05:11 PM
yea im actually about to do the same thing and add a second amp for my four speakers. but for the remote turn on wire theres two options, you can just splice the wire(which i have now for my crossover and my amp which works fine), or you can do it the safe way and use a relay, but that takes more effort.
or actually you might want to use an inline fuse in the remote wire, and just splice it afterwards, youll probe need a .5 amp fuse.
btw, if you have the money, id use a second amp to power the 4 speakers.
1. it will make the music louder
2. it gives you better sq
3. youll be able to filter out the low frequencies, giving a better overall sound stage and youll protect your speakers from blowing easier.
if you do this though i highly recomend getting an active crossover, which should run you maybe 50 dollars for a decent one.
Old 10-17-2005, 08:45 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Bridging amps doesnt make more power.
Example
100x2@4ohm
200x2@2ohm
400x2@1ohm
200x1@8ohm
400x1@4ohm
800x1@2ohm
the total power output is the same
i didnt read your whole first post...sorry, i feel like shit and just got finished with a latin exam...too much reading bunched togather for me.
Old 10-17-2005, 09:24 PM
FormulaLT1's Avatar
Fight the powwa!!!
Well , all I know is from the pioneer ratings. They rate my current amp that I am sending back at 150 RMSx2 @ 4 ohms but bridged for 1 channel they rate it at 400 RMS x1 @ 4ohm with double the rms as peak for each or are you saying because of the half the ohms being used is why the wattage is different?
Old 10-17-2005, 09:31 PM
right, im confused now too
if you bridge your example amp, you are given twice as many watts(800) as compared to the two channels putting out 200w@2ohms each.
please explain.
Old 10-18-2005, 12:50 PM
CBFryman's Avatar
Banned
look back at my example ratings... 150w doubles would be 300w, however that would be at 8ohm, not 4 ohm. cutting the resistance in half allows for more current so 400w is feasable.
