Old 10-16-2005, 03:42 PM
sue severson sue severson is offline
hesitation when accelerating
car hesitates when accelerating new plugs, new wires also ran hi test and chevron cleaner but cont. to hesitate. Engine light dose not come on either. Any suggestions out there?
Old 10-17-2005, 12:03 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: hesitation when accelerating
Air Filter, Fuel Filter, Fuel pressure regulator maybe... Could be a lot of things. Did you do the plugs and wires?
I see from your profile it's a 1999 I'm assuming 3.8L V6? Always try to give year and engine information if you can helps us help you...
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 10-17-2005, 07:08 AM
Re: Re: hesitation when accelerating
Thank you for the tips. Yes new wires and spark plugs were put on we will check the fuel filter and air filter. Do you think it my be the coil pack? yes its a 3.8v6 w/almost 80,000 miles
Old 10-17-2005, 12:52 PM
I don't know that it would be a coil pack, I'm not even sure what kind of ignition is on the 3.8's though so maybe. But usually a spark problem will cause a miss or cause the car not to run at all, and I would assume if it's a coil pack or ignition module it would just stop running when the ignition stuff gets hot.
I meant did yo do the plugs and wires yourself, sorry I wasn't very clear with my question... I was thinking maybe a bad connection somewhere between the coil and the plug, or maybe incorrect gap...
2006 Hyundai Sonata
Old 10-17-2005, 03:54 PM
I spoke with the mechanic that did the wires and plugs, he said that a camero came in friday with the same problem and the computer read out #5 cylinder and he changed the coil pack and it is running good so I told him I would like the filter changed and all wires and plugs checked and put on a coil pack. If that dosnt work we will do something else. Thank you so much will let you know how it comes out.
Old 10-29-2005, 07:47 PM
Talking r/t hesitation.
changed the coil pack on my 99 camero and the hesitation has quit it runs good now. Thank you for the input and suggestions.
