Old 10-16-2005, 03:33 PM
jcarter5 jcarter5 is offline
Need help with ABS light on 95 Blazer
Hoping someone can help. I put a new battery in my Blazer (95 LS) and soon as I started to drive the antilock brake light came on. Light was not on before I changed the battery. While I was working on the battery I also removed the computer (ECM?) to clean out leaves & junk underneath it. Anyone know of a way to reset the light? Thanks for any help.
Old 10-16-2005, 09:31 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
maybe with a scan tool.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-17-2005, 04:08 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Need help with ABS light on 95 Blazer
I would remove the negative battery terminal and remove and reattach all the computer connections again.
I hope the battery was still disconnected while you were removing the ECM the first time right?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-17-2005, 05:46 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Trace your ABS wires as well and make sure they aren't damaged or the plug was pulled when you pulled your ecm harness.
Old 10-17-2005, 11:42 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Interesting response. Here's a few more questions, because I neven had a problem with mine, just wondering:
1) will the ABS light come on if you disconnect the ABS?. (not a damaged wire, just unplugging the unit)
2) Isn't the ABS self supporting and not tied to the EEM\ECM|PCM?.
Old 10-17-2005, 12:09 PM
rlith's Avatar
Re: Re: Need help with ABS light on 95 Blazer
1: Yes
2: In the 94 and below it was a manual unit with only the output going to the BCM ... In 95 to current it's tied to both the BCM and the ECM
Old 10-17-2005, 08:11 PM
JA no Y's Avatar
JA no Y JA no Y is offline
If disconnecting the negative battery post does not help the ABS light to go off, you will more than likely have to have the light turned off with a scan tool. Might as well have the codes scaned while you have the scan tool connected.
Old 10-18-2005, 12:06 AM
BlazerLT's Avatar
AF -Advisor
but also reconnecting the computer connections would be a good thing to do.
Old 10-21-2005, 11:53 PM
jefferylj jefferylj is offline
Check the dealership for recalls. I know there was a recall done on my 95 blazer. The recall is TSB 99046 Dec 99.
