Old 10-16-2005, 02:29 PM
stetzz05 stetzz05 is offline
Send a message via AIM to stetzz05 Send a message via Yahoo to stetzz05
97 4.3 engine misfire
im getting a hesitation upon acceleration on my 97 1500 4.3 . it happens under normal acceleration but not when i accelerate hard. recently replaced alternator and problem started after that. getting a p300 code random engine misfire. is this fuel or electrical? any clues?
Old 10-16-2005, 02:35 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 4.3 engine misfire
Make sure you have good grounds, check alternator out put, can you feel an actual miss in the engine like a plug or wire?
Old 10-16-2005, 03:13 PM
grounds to bat. and block are good getting 14 .12 from alt. yes can feel hesitation not misfire no skip more like fuel cut out
Old 10-17-2005, 08:12 AM
A990 racer
You probaly should have it scanned and look for pproper o2 sensor activity, look at fuel trims to see if it is running lean/rich. If it is maf equipeed this could need cleaning, look at baro sensor readings make sure they coincide with your area.
Old 10-18-2005, 04:02 PM
formulaross formulaross is offline
Also check for vacuum leaks - bad grommets, cracked hoses, hoses to sensors, etc. - Had a '96 Lumina with 'random engine misfire' codes and found 1) a crumbled manifold gromet and 2) a leaking hose going to the MAP sensor. Might also check the high voltage plug wires, rotors, plugs to make there in good shape, not shorted, etc.
