Old 10-16-2005, 01:47 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
F.i.c
Well i got some work done to my car. One of those things was a fuel injection cleaning. Its suposed to get of all the carbon and what not in your engine. Anyway I got that done and it smokes when you rev the engine but thats normal. It smoked in side the engine and thats not. I think i have a crack in the exhaust manifold. But after all of that my turbo starts to spool up at 3k instead of 4krpms. So for anyone who hasnt had this done i recomend it highly.
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 10-16-2005, 04:11 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: F.i.c
You should spool a lot before 3k with the 14B.
I'm not trying to ruin your parade, but your car definitely has some more issues.
now - 2000 civic
soon - 2002 is300
Old 10-16-2005, 08:12 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: F.i.c
Yeah, I've heard that removing all the carbon can unclog little cracks that wouldn't be an issue otherwise. Just keep an eye on everything. Best of luck!
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 10-16-2005, 08:19 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Re: F.i.c
Do you mean start to spool, or get to full boost?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-08-2005, 12:57 PM
Re: F.i.c
yes i start to spool at three but it doesn't kick in until 4k
MODS
Old 12-08-2005, 01:06 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: F.i.c
Definetly something wrong there... Maybe you have a large boost leak also? It should start spooling almost immediatly.You said it smokes in the engine bay too? Maybe that is also a problem, you may not have enough back pressure to spool the turbo like it should... I'd definetly check for cracks in your manifold and check for boost leaks.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-11-2005, 08:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: F.i.c
Yup, sounds like exhaust manifold cracks or broken studs. Can you hear an exhaust leak there?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-11-2005, 09:45 AM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: F.i.c
it is diff the exhaust manifold.... or the gasket from manifold to turbo is bad.... it has nothing to do with back pressure though =) i thought that turbo cars don't need back pressure but i could be wrong
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 12-11-2005, 10:27 AM
Re: Re: F.i.c
They do like wide open exhausts, but they do need some back pressure to run good... I'm pretty sure this is how it goes, but someone correct me if I'm wrong... I think it has something to do with velocity, as you funnel air into a smaller opening it moves faster and the bigger the opening it moves slower. So you you have like a 1 inch exhaust on a turbo car, then the exhaust gases are gonna be going fast as hell through it and it should spool the turbo quicker if it's a small turbo. If it's a larger turbo then you need more room to push all that air through. It's all some sort of ratio of CFM to exhaust size or something. That's why it IS possible to have too big of an exhaust and it has a harder time spinning the turbine to a larger turbo. But, if your exhaust is too small then it just can't get rid of all that exhaust quick enough... There was a site that explained it all, I'll find it again and post the link up here when I find it.
***EDIT***
Here's the link to that site I was refering to.
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
Happy reading!
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-11-2005, 02:20 PM
Re: F.i.c
No exhaust leaks in the manifold and all the studs are good for sure. I still have the stock down pipe so i was thinking that might be part of the problem. I drove my friends 1g and his turbo you could feel kick in at 3 and his car is completely stock. When i hit boost mine has more power than his but as far as spool time goes his is for sure faster.
MODS
Old 12-11-2005, 02:27 PM
Re: F.i.c
If its smoking in the engine bay then there has to be something cracked or leaking... Having the stock downpipe shouldn't be a factor because I still have mine too and its fine... If your sure there are no manifold leaks then I'd go onto checking for boost leaks.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-11-2005, 05:26 PM
Re: F.i.c
its not smoking in the engine bay. that happend after i did it but it was the smoke comming from the bottom of the car back into the engine. thats what we determinded. It happens on all of the turbo cars that we do for some odd reason. Even the brand new ones that do it they smoke there.
The exhaust manifold has been checked since then.
Would the stock intercooler piping affect it also?
MODS
Old 12-11-2005, 05:44 PM
Re: F.i.c
The stock intercooler piping shouldn't affect it unless its leaking... If anything, it should make it spool sooner with smaller piping like that.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-11-2005, 06:04 PM
Re: F.i.c
well I'm out of ideas here. Theres no smoke. And it spools just fine when its 30 degrees outside but i live in texas thats not normal weather around here.
MODS
Old 12-11-2005, 06:06 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Re: F.i.c
Turbo cars do NOT need backpressure. You're thinking of n/a. It's been said many times: No exahust is the best exhaust. That's why people run just a giant tube from the turbo straight out the side of the front bumper. Also, I believe it's the pressure diferential (before turine/after) that spins it, along with heat. The bigger the differential the faster it spins. Someone correct me if I'm wrong.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
